Results 1 to 5 of 5
    Established Member Two Rings diggy79's Avatar
    Nov 01 2017
    2006 CCSB D-max 2004 Suburban D-max swap 2000 RCSB 8.1L swap
    Salmon Arm, BC, Canada
    2.7T motor timing
    Hey guys.
    I'm posting is this section because the question is specific to the 2.7t. I has recently swapped a 2.7 into a B6 S4 and is up and running. I managed to source a second engine for cheap and started to tear it done in preparation for a future build.
    I got all accessories off the motor, and rotated into time for timing belt bar and crank pin. All looked good. Timing bar slid right on.
    Removed value covers to inspect and replace gaskets. Look like they stretched those oil changes.
    Anyways in looking at the timing of the cams I noticed all cams arrow markers where in the slot but one. I'm looking for feedback as I have not tore too deep into these motors. But assumed that is slightly out of time. ? This was pulled from a running car.
    The first 3 pictures are from cams that look in time the last 2 are the same "out of time" ?
    I was thinking of taking the heads off anyway. But if that cam is out of time it would solidify the decision
    Any help would be great cheers 20180908_135642.jpeg20180908_135623.jpeg20180908_135619.jpeg20180908_135710.jpeg20180908_135540.jpeg20180908_135604.jpeg
    Sent from my SM-G955W using Audizine mobile app
    2011 Audi S4 premium 6mt (stock)
    2018 VW Tiguan Highline 4motion 2.0TSI (stock)
    2006 Chevy Silverado 2500HD CCSB 4x4 Duramax- 10in Lift Custom WFO SAS on 18s with 37s
    2004 Chevy Suburban 2500 4x4 D-max swap 6in Lift on 20s with 35s
    2000 Chevy Silverado 1500 RCSB 2wd w/ 8.1L 4l80E swap on 20s 285 55 R20 Goodyears
    2004 GMC Sierra 3500HD RCLB Duramax 4x4 Ugly duckling, winter beater.
    New Project: 2004 Audi S4 B6 4.2L ->2.7T swap just starting
    Jul 04 2012
    Woodbridge, VA
    Looks like the tensioner didnít pull up the slack. You might have a bad pad or tensioner. Did you spin the motor around a few times?
    Feb 23 2010
    Lehigh Valley
    Without oil pressure, they won't line up perfectly turning the motor by hand. If it was a tooth off, you would almost certainly get an implausible signal code. Best way to be sure is to count links. There should be 16 pins, sprocket to sprocket.
    B5 S4- K24s, built bottom end, E85
    B8 S4- GIAC Stage 2
    150cc Chinese Scooter of Doom
    Jul 04 2012
    Woodbridge, VA
    This is how you count the rollers
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If it was fine before, put the cover back on and quit provoking them.
    This is an area of major fkery that you dont need or want in your life.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesnít move and it should - WD40.
