Results 1 to 10 of 10
    Senior Member Two Rings Saifxnyc's Avatar
    Oct 19 2012
    Pittsburgh, PA
    Post Is the 2G MMI display screen plug and play?
    Hi, I have no idea why my MMI screen is not working right it's just blank display of light. I made a post a while back about it https://www.audizine.com/forum/showt...goofy-emoji854 but I got no replies.
    I am trying to figure out does the MMI screen have component protection on it? The dealer could not find any codes and recommended replacing the
    MMI screen Part # 8T0-919-603-C and the harness part # 4E0-971-086D. I would just like some help deciding what to do here. I want to get it fixed, I just want to be sure. I don't want to buy the screen and it end up not working if the harness was faulty so I will get both. Is there a good tutorial on replacing the screen and the harness? Can someone please help me out. I don't want to throw parts at it.
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    1994 Volvo 850 Turbo
    Quote Originally Posted by Saifxnyc View Post
    I would lean towards an intermittent issue with MMI or the screen itself. I also noticed that in your images, it seems to be working at night and having issues during day. Could be just coincidence or it could be usage/conditions related/exacerbated.
    Do you have access to VAGCOM?
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Oct 19 2012
    Pittsburgh, PA
    Quote Originally Posted by cal3thousand View Post
    Thank you for replying cal3thousand. Ever since the MMI did that the screen was displaying lines and blank white for 6 days straight. Then on the 6th night when I parked the car and took the key out the MMI screen was working. But it only worked for that moment and the next day it was back to the way it was again. It doesnít work at night at all that was just one random occurrence. When you say and intermittent issue with the MMI you mean the center console area with all the buttons I assume. Nothing has been spilled there or anything irregular happened to it. For the past 7 years I have been driving it just the way I was when this happened. Itís beyond me. I do have a VAGCOM I scanned the car and there were no codes. Iíll scan it again right now and update the post if there are any errors. Even the dealer could not find any logs in the car when it went for an airbag recall on September 5th. My main question was if needed to replace the screen or MMI is there component protection on the screen? Iím pretty sure the MMI has to be recoded I have been doing some research. Thanks again for your response I greatly appreciate it.
    Oct 19 2012
    Pittsburgh, PA
    So right after I made that post above about scanning the car I took it for a drive. Before the car went in for an airbag recall it had no codes except for the one that has been there since I disabled the TPMS sensors other than that there were none. The MMI screen went bad on its own on a hot day on August 28, 2018. It worked intermittently when the car was turned off 6 days later.
    Today the screen was still messed up. I drove it for 5 minutes and as usual tried to reset the MMI everytime I get in the car several times since this issue.
    I reset the MMI by using the three buttons on the console. What do you know this time it did fix it... It is working for now. I have reset this MMI over a 100 times in the last two weeks...
    I scanned the car once I got to my destination and there were only 2 codes. Both were related to the airbag recall performed. One was for glove box motor and the second one was for them removing the AMI from the car. These codes were not there when the MMI was bad It is most likely they are due to the service performed by the dealer. I cleared them for now. I have no idea what to do except keep my fingers crossed. 2 weeks later the thing decides it wants to work on its own. I am at loss for words right now I don't know if the screen will work when I get back in the car in 2 hours and drive it again.
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 223278 km
    Time Indication: 0
    Date: 2018.09.06
    Time: 10:29:51
    My next step is to do a OPTICAL scan of everything I will update the results here.
    Feb 19 2013
    Good luck and let us know what you find out.
    As for your original question, I'm fairly certain that the screen does not have component protection. You can get new ones for fairly cheap on AliExpress. You can also get the MMI panel circuit board over there too. (as well as eBay)
    Dead:
    Oct 19 2012
    Pittsburgh, PA
    I did a full scan of the vehicle after clearing the codes and as expected there were no new faults except the TPMS sensor. I also did a optical bus scan and everything came back fine. The screen worked after the MMI reset on Tuesday and when I got in the car on Thursday it looked like this again.
    After leaving it running for 2 minutes I removed the key and waited another 2 minutes. The screen was working this time flawlessly. I have no idea why is it doing that and how often will it not work and work when it feels like it. Also I am not sure if i should only replace the harness or the screen. Something is definitely acting up.
    https://www.youtube.com/watch?v=tJ1y...&index=50&t=0s
    This person on youtube had a similar issue but his MMI screen actually displayed some information. According to his comments replacing the screen fixed it for him.
    Tuesday,11,September,2018,16:01:09:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Control Module Part Number: 4F0 910 468 A
    Component and/or Version: Gateway H11 0070
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(High/D3)OK OK
    0E-Media Player 1 OK OK
    77-Telephone OK OK
    47-Sound System OK OK
    56-Radio OK OK
    Tuesday,11,September,2018,16:12:13:62939
    VIN: WAUDH74F27N003624 License Plate: HXV5412
    Mileage: 223440km-138839mi Repair Order: 9/11/2018
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
    62 72 77
    VIN: WAUDH74F27N003624 Mileage: 223440km/138839miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 4F2 910 559 HW: 4F1 907 559 E
    Component: 3.2l V6 FSI 0020
    Revision: --H19--- Serial number:
    Coding: 01050109190F0120
    Shop #: WSC 02325 785 00200
    VCID: E9D9DB2FC08CB956A3D-80BC
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 G HW: 09L 927 156 C
    Component: AG6 09L 3.2 FSI USA 0010
    Revision: --H01--- Serial number: 4179617
    Coding: 0000002
    VCID: 29591B2F800CF956E3D-807C
    Address 03: ABS Brakes
    Cannot be reached
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0210
    Revision: 27120501 Serial number: 10601000410184
    Coding: 0000011
    Shop #: WSC 02323 785 00200
    VCID: E3C5C90722A0E306691-80B6
    Subsystem 1 - Part No: 4F0 910 131 J
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 220 A
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 Q HW: 4E0 035 729
    Component: Interfacebox H43 4610
    Revision: 00000000 Serial number: 303E6067523000
    Coding: 0030003
    Shop #: WSC 02335 785 00200
    VCID: 3169F34FA8DC81962BD-8064
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    Subsystem 2 - Serial number: 00000000416935
    Subsystem 3 - Serial number: 0115.05.060000000100010550ˇ
    Subsystem 4 - Serial number: 010550ˇ
    1 Fault Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 223442 km
    Time Indication: 0
    Date: 2018.09.11
    Time: 16:02:08
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000030 Serial number: 00000030126282
    Coding: 0524326
    VCID: DBB5F1E71AD0DBC6211-808E
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0010103
    VCID: 326BFC43ADDABA8E527-8067
    Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H05 0210
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH12 0090
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
    Part No SW: 4E0 035 785 HW: 4E0 035 785
    Component: SG ext.Player H09 0170
    Revision: 00000000
    VCID: E5C1D71FEC949D36875-80B0
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
    Component: 66 AIRBAG AUDI8RH29 0300
    Revision: 14H29000 Serial number: 00359D0B82BJ
    Coding: 0013878
    VCID: 2A5BE423850AF24EEA7-807F
    Subsystem 1 - Part No: 4F0 910 339 A
    Component: BF-Gewichtsens. H02 0050
    Subsystem 2 - Serial number: 6332CSME0F195C58G
    Subsystem 3 - Serial number: 6342CSME0F195D16C
    Subsystem 4 - Serial number: 6352QSME0D121E29J
    Subsystem 5 - Serial number: 6362QSME101B38316
    Subsystem 6 - Serial number: 63734SME0D033F03
    Subsystem 7 - Serial number: 63834SME0E663243/
    Address 16: Steering wheel Labels: None
    VCID: 55A167DFBCF48DB6975-8000
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 C HW: 4F0 920 950 S
    Component: KOMBIINSTR. M73 H12 0070
    Revision: 00100000 Serial number: 5F539EC56
    Coding: 2049203
    Shop #: WSC 45431 001 104857
    VCID: 204F060BF336381EB43-8075
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 130080651080A7
    Coding: 6CFE53C41B1104
    Shop #: WSC 02334 785 00200
    VCID: 275D1D179618CF26F59-8072
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00-00000
    Coding: 0035435
    Shop #: WSC 25655 002 1048576
    VCID: 2C57E23B8FFEEC7E18B-8079
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01013567170000
    Coding: 4618397
    Shop #: WSC 45178 001 1048576
    VCID: 2E53E833B9E29E6E36F-807B
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H10 0350
    Revision: 41S00001 Serial number: 02704060264192
    Coding: 0000006
    VCID: 224B0C03FD3A2A0EA27-8077
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 B
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000023731
    Coding: 0002014
    VCID: DEB3F8F309C2CEEE46F-808B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00-00000
    Coding: 0035435
    Address 53: Parking Brake
    Cannot be reached
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 394EZ067642827
    Coding: 0000002
    Shop #: WSC 02324 785 00200
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000027224
    Shop #: WSC 00000 512 00290
    VCID: 23450907E2202306A91-8076
    Subsystem 1 - Part No: 000 915 10D L
    Component: von VA0 35070550A6
    Coding: 3030303931353130444C2056413033353037303535304136
    Shop #: WSC 12345 512 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0035370
    Shop #: WSC 02327 785 00200
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0035370
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4F0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H13 1130
    Revision: 00000000 Serial number: 00000007530177
    Coding: 0010970
    Shop #: WSC 00000 000 00000
    VCID: 285F1E2B9B06C05EFC3-807D
    End ---------------------------------------------------------------------
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    When I bought my a6 in 2009 it had a bad screen and looked like that...
    At the time I was scared to work on it myself, so I bought a used mmi 7" Hi res screen on Ebay and let my dealer install it. Been fine for 9yrs and 160k miles.
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Oct 19 2012
    Pittsburgh, PA
    Quote Originally Posted by JPJ2007 View Post
    Thank you JPJ I am selling the car. I will be sure to inform them about the problem. Itís good to know itís just the screen. I just donít understand why it works sometimes flawlessly then it doesnít. Thanks everyone for your reply I do greatly appreciate it.
    Dec 28 2017
    Poland
    How did you fix it?
    I have the same issue but my screen is all the time black&white ...
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
    Dec 28 2017
    Poland
    Solution: Replaced the screen
