Results 1 to 8 of 8
    Dec 15 2019
    Santa Rosa .ca nor cal
    Unsure if it's a 2006 A4 quattro cabriolet b6 or b7
    Have 2006 A4 quattro cabriolet (convertable). Just not sure if it's a B6 or B7?
    When looking for headlights (xenon) I always shown lights that aren't the same shape? Although I see xenon lights that look the same that are for a 2005 A4? The only part # i can see is 8H0 941 003 BC.
    Sent from my SM-T550 using Audizine mobile app
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    B6: https://www.auto-data.net/en/audi-a4...0v-170hp-26633
    B7: https://commons.wikimedia.org/wiki/F...t_20100519.jpg
    The headlights are significantly different as you can see. 8H0941003BC is for a B6. Your car is a B7 if its a 2006.
    Jul 10 2015
    Colorado
    Quote Originally Posted by jeerweezer View Post
    Which engine do you have? I believe that some of not all 2006 cabriolets kept the 1.8t and 3.0 engines. Those probably fall under the B6 designation.
    Veteran Member Four Rings Kevin C's Avatar
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Google used 2006 audi A4 convertible and all you will get is a B6' front grills. It does look like they got the newer cup holder.
    https://www.cargurus.com/Cars/l-Used...let-AWD-t24197
    https://www.cargurus.com/Cars/invent...edEntity=c5274
    2003 02X Six speed swapped, RS4 RSB, H&R FSB, B7 brakes, 2.0T stroker, DSMIC's, B7 CTS K04 turbo.
    Dec 15 2019
    Thanks for your responses. The question I have now. It has 3.0 by the way. So it's a b7 even though the headlight that came with it have 8ho 941 003 bc imprinted on them?
    I'm really just trying to find either whole light replacements or lense cover replacements?
    Thanks again
    Dec 15 2019
    Kevin speaking of grills? I also can't seem to find lower 2 fog grills that fit? And lower center grille doesn't seem to match any others I've found?
    I read there might have been some type of limited front end used on the 3.0 convertible?
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Well my bad, looks like B6 cabrio carried on into '06. I deleted my original post and part numbers to clear up any future confusion. Just post a picture of your front end and all will be clear, any number of front bumpers could have been swapped over if you aren't the original owner.
    Dec 15 2019
    Ok. I'll get a picture and post it. Again thank you for the help
