Results 1 to 11 of 11
    Aug 27 2018
    Mesa, AZ
    Homelink issues...grrrrr
    So I was able to program my Garage door opener on the first try. I then tried to program the gate opener to button 2...no go. Itís not rolling code, and should learn from my small remote. My S3 and the wifeís CX5 had zero issues. Anyone else have issues with this? Maybe I just need to call them? Hoping thereís a simple solution.
    Thanks in advance!
    Jason
    Jul 09 2018
    Little Rock, Arkansas
    I have no idea what type of system our neighborhood gate uses, but NONE of our cars will work with it.
    Sep 13 2017
    Morgantown WV
    Quote Originally Posted by jkeith72 View Post
    Thanks in advance!
    Jason
    I just moved and I canít get mine to program. Couldnít get it to program at my house before I moved. Different brand of openers. When itís time for my service, I reckon Iíll see if the techs can figure it out.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    I had to refer to the manual for the correct sequence but this I know it's different from year too year, 2017 and 2018 are not the same.
    Gone 2013 B8.5 S4 Ice Silver, DSG, Uni 2+TCU, Prestige Model, MMI, B&O, Fine Napa, Sports Diff, audi assist, 19" Peelers, Carbon Atlas Inlays.
    2017 Q5 3.0 Ibis W/ BO with S-line
    2018 SQ5 Ibis Prestige Red Calipers Fine Napa Leather
    Established Member Two Rings Akoby9's Avatar
    May 02 2007
    Denver, Colorado
    I cannot connect either. From lots of research it seems that specific garage door openers use a different frequency that some cars have issues picking up because of sensors on the car. If your garage door has the 'purple' learn button chances are likely that you have issues connecting. I contacted homelink and they advised that Audi has an update for this that should correct the homelink system to pickup the other frequency. Not sure if anyone has tried this 'update' or if it even exists? I have an appointment tomorrow to see. Fingers crossed it works and isn't just one company pointing the finger at another.
    Apr 11 2012
    I had to pull a fuse to prevent the lane assist signal from interfering during the learning phase, then you can plug it back in afterwards.
    https://www.audiworld.com/forums/aud.../#post25074870
    Aug 27 2018
    Mesa, AZ
    Awesome!
    Quote Originally Posted by will13k7 View Post
    Oh hell yes. Worked! I thought about a fuse, but didnít want to get an error I couldnít clear. Thanks for the solution!
    May 02 2007
    Denver, Colorado
    ha. Dealership didn't have an actual software update. They LITERALLY did the above. He also gave me a print out similar to the picture above of how I can do this again.
    Sep 13 2017
    Morgantown WV
    I did the fix listed above and got mine to program as well. The car really wasnít happy about that fuse being gone lol.
    Active Member Two Rings InfamouS4's Avatar
    Oct 14 2018
    Los Angeles, CA
    Quote Originally Posted by AWDYEAH View Post
    Where is the fuse box located?
    Sep 13 2017
    Morgantown WV
    Quote Originally Posted by InfamouS4 View Post
    Trunk, drivers side behind the storage net in the fender well area.
