Results 1 to 40 of 45
Hybrid View
    Active Member One Ring in_an_instant's Avatar
    Aug 22 2018
    poconos
    EMD RS5 Grill Installed > B9 S5 Prestinge
    Howdy folks, I decided to create a post on how I made out installing the EMD RS5 style grill. I was initially skeptical, so much so that on a few occasions I simply decided I didn't want to risk something going wrong. Some folks were reporting camera and/or sensor issues while others had great results. This will be the 6th bumper cover I've removed. I do basic stuff here while taking anything suspension, clutch or electronic related to a pro. I had reached out to EMD with a few questions after completing my order and their response was very fast. I had asked about an install video or guide that I could print up. They provided me with a link to a grill installation on a B9 S4. Actually, here is this link: https://www.youtube.com/watch?v=jeMW-EowOHo
    While it was very similar, there were a few differences worth noting:
    - There are 4 T25 screws holding the inner fender liner to the bumper, the S4 has 3.
    - There is an additional trim piece on the inside top portion of our grill unlike the S4. This was not re-used but must be taken off.
    Some additional tips:
    - They aren't kidding about needing an extension for the T30 above the inner fender liner. That was very tricky, I've got magnetized bits, not sure if I could have done it otherwise.
    - When installing the camera stand in front of your bumper and push it from the back while tightening the screw. Some have had alignment and/or fitment issues. With the included bracket it's very straight forward but if you're installing it from the back (without actually looking at the camera alignment as it relates to the hole) I could see how someone could angle it incorrectly.
    - The tabs to remove the actual grill portion are an epic test of patience. The dude working on the S4 in the video is either a hacker, mage or has removed 1MM tabs. I spent nearly 50% of the entire install time working the old grill insert out. Take your time for sure.
    - The proximity sensors are truly plug and play. 2 seconds and done.
    - Prepare for a very wobbly and flexible cover once the grill is out. It can get very awkward pretty quickly.
    - Tape the lower portion of your headlights and the fenders just above the bumper cover on both sides. When unplugging and pulling it off, it's very easy for the corners to twist up and scratch things. I learned this the hard way with my 4Runner seen in the background of the side shot.
    - The S5 badge itself looks WAY more complicated to remove than it is. For some reason, they stuffed as much engineering as you'd do for a mile long bridge into that badge. It literally just slides out frontwards with some coaxing of the array of cross tabs and angled not sure whats.
    - Don't bother notching your crossbar's foam insert as some posts mention, even with clearance for the camera it pushes against the grill too much. You end up having to essentially bend the grill around the foam. No go in my book. Prep and paint your crossbar and you're good to go.
    - I personally would not take this to a shop unless I was certain that they could dedicate someone to it for 2 hours minimum. It's simply not something that can be rushed. There are too many steps and too much patience needed for 80% of the shops out there. I could easily see someone screwing something up and then calling me stating there is some random problem with the car or insert. Either do it yourself or find a darn good (borderline OCD) shop.
    TL;DR
    Results:
    The result is truly transforming. I've got about 100 miles on it since the install. I wanted to make sure there wasn't any weird whistling. I have zero camera or sensor issues and it feels rock solid. I'd do this again in a heartbeat.
    Mid install shots:
    All done:
    Took the opportunity to add the 10mm spacers from ECS in preparation for some H&R adjustable springs going on Tuesday. Nice and flush:
    2018 S5 SB Prestige in MBM: Bone stock for now
    Dec 03 2009
    Florida
    The best detailed write up this install I've read. I wish I had this before I did mine.
    Aug 22 2018
    poconos
    Quote Originally Posted by DBS View Post
    Thanks man, after I saw your photo in another related post I kind of regreted not going with the silver trimmed version like yours. The gloss on the grill is far shinier than that honeycomb in the fog-light/brake duct air damn area. It looks like the silver trimmed version breaks it up enough so visually the difference is nearly undetectable.
    Active Member Two Rings Hondaciviceg's Avatar
    May 25 2019
    Toronto, Canada
    Hey, do you have a full photo of your car? Mine is a black one and I don’t have the blacked out exterior package so I have been going back and forth trying to decide if I should go with a black surround or a silver surround grille. Cheers
    Oct 20 2017
    '14 Audi Q5
    CT, USA
    Quote Originally Posted by Hondaciviceg View Post
    Without the black optics package, I'd recommend the silver surround. ties the accents together. also breaks up the fact that the honeycomb grill is gloss black, and the black in the fog light grills is more of a matte.
    2018 A5 Sportback 2.0T S-line - Scuba Blue | Unitronic Stage 1+ | ECS 3" downpipe | 034 Strut Brace and Transmission Mount
    - 3 season: VFF-110 20x10ET30 w/ DWS06 275/30R20
    Dec 03 2009
    Florida
    Oct 20 2017
    '14 Audi Q5
    CT, USA
    Goregeous @DBS!
    I have one going on my A5 as well. Did you paint the crash bar or vinyl wrap it?
    Dec 03 2009
    Florida
    Quote Originally Posted by shadowgooner19 View Post
    Goregeous @DBS!
    Thanks, I painted the crash bar. Its been on over a year with no sign of chipping or coming off
    Dec 29 2020
    Phoenix/AZ/
    Where did you purchase your grille? Looks good!
    Established Member Two Rings ThetaB8A4's Avatar
    May 17 2014
    Hendersonville/Tennessee/USA
    Awesome write up. Will absolutely consider doing the install myself now. One question, can the quattro letters be removed?
    2018 S5 Sportback Prestige
    Ara Blue crystal / Black Nappa S sport seats
    19" Cavo wheels / Carbon Atlas inlays / Dynamic Steering / S Sport pkg / Driver Assistance pkg / Audi Beam Rings
    Aug 22 2018
    poconos
    Quote Originally Posted by ThetaB8A4 View Post
    I'd have to say yes because they are affixed via an adhesion pad. Maybe just soak them down with adhesion remover and yank them off after a few minutes then another soak to clean up the residue. The grill plastic itself is very rigid so I could see it scratching easily if pressure was applied. I've had good luck with regular ol' turtle wax label and sticker remover for dealer emblems on the back.
    Active Member Two Rings chuck.lleshi's Avatar
    Jul 30 2018
    Parlin NJ
    Looks good. Just installed mine.
    Was thinking about plasti-dip in the Audi rings and s5 chrome with clear coat this way it comes out looking brushed to match everything else. Have to go buy a bottle lol
    Junior Member Two Rings Nikon1's Avatar
    Apr 15 2018
    Is For Cars Only
    South Jersey
    Can anyone tell me if the Audi Rings in the RS style grille are the same size as the stock / “genuine” rings?
    I bought the Audi Black Rings From Audi for the back deck and front grille - and I’m hoping that I can use the Black Rings on the EMD RS style grille. My grille will be arriving on Wednesday so this isn’t a Make or Break situation.
    I just think the black Audi Rings on the rear deck look so much better on my Daytona Gray.
    Thank You in advance!
    —John
    Dec 21 2017
    San Diego, CA
    I did not get my RS style grille from EMD...but for what it's worth the rings on mine unfortunately are a touch bigger than stock.
    Hope it works out for ya on the EMD.
    Established Member Two Rings wam22's Avatar
    Feb 23 2017
    chicago
    Rings on the front are bigger than the OEM S5 rings, not sure if they are OEM RS sized.
    2020 F82 BMW M4 l San Marino Blue l Silverstone Leather
    20" Brixton Forged RF10 Wheels l M Performance Exhaust w/ Carbon Fiber Tips l Stage 1 Tune l Carbon Fiber Spoiler and Mirror Caps l DCT
    Retired: B9 S5 Coupe with lots of AWE and 034 parts
    B8 A5 with APR Stage 1 Tune
    Current BMW Sales/Former Audi Sales
    Apr 15 2018
    Is For Cars Only
    South Jersey
    Thanks, guys!
    Established Member Two Rings rbjones21's Avatar
    May 13 2018
    Cleveland, OH
    Thumbs up
    Great write-up. Helped with my install today.
    2023 RS3
    xx2021 RS5 Ascari Launch Edition
    xx2018 A5 Sportback SLine Prestige
    Feb 12 2006
    Ontario
    Curious how the finish is holding up on these grills? Any input? Are they just as good in the long term with pitting etc? Does the paint or anything chip off?
    Dec 21 2017
    San Diego, CA
    Had mine about 7 months and probably 7,000 miles its holding up great! I mean a little pitting here and there but I would say consistent with all the other plastic bits n pieces up front.
    May 29 2018
    B9 S4
    831 CA
    Is it possible to remove the bumper without removing the wheels? Ive had my EDM grille for like 3 weeks now but been too lazy to throw it on :(
    I have S4 btw...
    Feb 12 2006
    Ontario
    Quote Originally Posted by Paintedblack View Post
    I have S4 btw...
    You can keep the wheels on, just need to turn the wheel left and right to remove and re-install the fasteners in the wheel well
    Dec 21 2017
    San Diego, CA
    Nope, need to get to some fasteners that wheels inhibit.
    Registered Member One Ring Jay9757's Avatar
    Feb 07 2019
    Texas
    Installed mines last night, love it! The left parking sensor in the grill intermittently goes off though. Not a deal breaker as it still keeps me a safe distance from scraping my bumper up.
    Sep 02 2017
    2016 Audi TT
    Georgetown, TX
    Hey Jay9757 did you resolve the left parking sensor problem. I have the same problem going on.
    Dec 16 2015
    This looks great. Has anybody attempted to attack a license plate to these yet? How did it go and which bracket did you use?
    Aug 25 2009
    Minnesota
    Quote Originally Posted by subtle147 View Post
    https://www.audiworld.com/forums/audi-a5-s5-rs5-coupe-cabrio-b9-220/a5-s5-rs5-style-grille-v2-%7C-camera-mount-3d-print-file-stl-2970520/page3/
    See post #24. Only difference is the EMD grill is the earlier version 1 with two different honeycomb patterns.
    Jun 04 2019
    NC
    Hey guys I know this thread is over a year old and is probably not being checked but has anybody experienced any camera distortion issues with the front camera after the grill install? The front camera when looking at the 360 arial view is warped inward almost as though the camera needs to be tilted up a little bit to straighten the image back out. Pls help with any advice!
    May 25 2019
    Toronto, Canada
    Great right up, this clears things up a lot, I have been searching for a front grille that doesn’t give issues for camera and sensor install for months now. Lol. Great job!
    May 25 2019
    Toronto, Canada
    Hey, is EMD out of those grilles? They don’t have them on the website!
    Aug 16 2018
    Oakville, Canada
    Was told they were asked by Audi to stop selling them. We're stuck looking on Ebay for a suitable one to install. I've spent some time trying to find one that works, but the descriptions are written in broken English and it's tough to decipher the meaning. I have a Technik with the Advanced Driver package and it's tough to find one with provisions for the camera mounts. Let me know if you find one, as I'm still looking.
    Sep 28 2010
    NW NC / DE
    I spoke with them a few weeks ago and they had 3-4 left. I've sold two since then. I can check if you like.
    Established Member Two Rings cthan3o3's Avatar
    Mar 11 2011
    Colorado
    Can you check for me if they have the black Audi rings specifically for the RS style grille? Mine came with silver, wanna switch to black.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by cthan3o3 View Post
    Yep, I know they do. I'll PM you info.
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Can you check for me on a front grille and shoot me a pm? Black optics. Thanks.
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by rayray View Post
    Hey hey ray ray - they have (3) black and no silver for the S5. I just sold one S5 black this AM. $445 shipped. Hit me at [email protected] if you'd like to scoop one and we'll get it done.
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Just seeing this...My day got slammed. Thanks I’ll let you know soon.
    Aug 25 2009
    Minnesota
    All the info on installing the Chinese ver 2 grill with the camera mount.
    https://www.audiworld.com/forums/aud...e-stl-2970520/
    Established Member Two Rings Omychron's Avatar
    Dec 18 2018
    Belgium
    Just installed mine. I had ordered it a few months ago, but hadn't gotten around to it.
    Picture is before I managed to reinstall the S5 logo. Such a shame I need a front plate in my country...
    Up!
    Current: 2017 Audi S5 (B9)
    Previous: 2015 Audi TT (8S)
    Sep 28 2010
    NW NC / DE
    Two silver ones left, guys.
    May 07 2019
    Has anyone found another company that had the black RS5 and chrome Quattro. Did EMD give anyone there supplier?
