Results 41 to 80 of 116
  1. #41
    Feb 15 2018
    Do you guys know if cooling via HX even helps?
    How does Methanol Injection help - would it satisfy DP charge cooling?
    Basically I wonder if just dealing with the charge air temperatures is the problem and cooling of the engine is not
    Therefore wouldn't meth injection just solve the DP problem with no need for a HX?
  2. #42
    Stage 2 Banner Advertiser Four Rings Chris@EPL's Avatar
    Jun 23 2011
    Yes cooling with a heat exchanger does help and so does water/meth. Once the IATs get above about 70C the car will switch to a lower timing map. And that will happen after a few WOT gear pulls. At Stage 2 when it is hot at it would happen as well. You can do a couple full 3rd gear WOT pulls to the 4th gear change and see what the IATs look like.
    European Performance Labs
    http://www.facebook.com/EPLabs
    https://www.instagram.com/eplabs/
    (203-345-6499)
    Chris@eplabs.net
    Please feel free to contact us with any questions!!
  3. #43
    Feb 15 2018
    Quote Originally Posted by Chris@EPL View Post
    What is the pre inter cooler IAT and post intercooler IAT - do you know?
    Because my coolant temperature is always hotter than 70C so if the air is going through a charge cooler with 100C coolant how on earth could it cool it?
    I am trying to know which cooling option would be best for me. I can sense a large difference in power based on ambient air temperature. I think water/meth is the only way to solve it?
  4. #44
    Feb 15 2018
    My coolant temperature doesn't seem to change much when I drive fast or slow last time I checked which makes me think hx does not much and only true way is methanol injection
  5. #45
    Jun 23 2011
    Coolant temp is not related to IATs
    (203-345-6499)
    Chris@eplabs.net
  6. #46
    Senior Member Two Rings Indskyz's Avatar
    May 31 2016
    Virginia Beach
    Quote Originally Posted by NickLim View Post
    Nick, I was able to scan these items with the torque pro app.
    IAT - intake air temp - air temp in the intake manifold.
    CAC temp 1 and temp 2 - charge air cooler temp - Not sure if this is the coolant or air being measured.
    ECT - engine coolant temp
    This should be included with rpm and load when scanning so you know what’s going on.
    You always have the ability to monitor ambient air temp as well in the dash and possible on the scanner.
    2010 A6 Prestige 3.0T
    GIAC Stage 2+ w/AWE Pulley 93 & 100 Octane files
    Roc Euro Intake
    2.5" Custom Cat-back Exhaust w/Magnoflow Resonated X-Pipe and Mufflers
    ST Coil Overs, H&R Rear Sway Bar
  7. #47
    Feb 15 2018
    If IAT is the only problem and coolant temp doesn't affect IAT the only way to solve high IAT is methanol injection O_O
  8. #48
    Feb 15 2018
    Quote Originally Posted by Indskyz View Post
    I have IAT on torque lite also and it doesn't give me any data
    Would torque pro give me data?
  9. #49
    May 31 2016
    Virginia Beach
    Yes. It did for me
    Roc Euro Intake
  10. #50
    Jun 23 2011
    Get in on the C6A6 introductory deal. Email or PM for a package deal not listed.
    Stage 1 and a cable for $999
    Stage 2, SC pulley, belt and cable for $1475
    all prices shipped in the USA except for CT.
    (203-345-6499)
    Chris@eplabs.net
  11. #51
    Jun 23 2011
    Cables, SC pulleys, belts, 183mm Fluidampr Crank pulley kits are all in stock and ready to ship.
    (203-345-6499)
    Chris@eplabs.net
  12. #52
    Jun 23 2011
    More Stage 1 and Stage 2 cars flashed today.
    (203-345-6499)
    Chris@eplabs.net
  13. #53
    Feb 15 2018
    Shout-out to EPL! Best tune for c6
  14. #54
    May 31 2016
    Virginia Beach
    EPL C6A6 Stage 1, Stage 2 and soon Dual Pulley tunes
    NickLim what tune did you get? Any Dyno numbers of before and after?
    Roc Euro Intake
  15. #55
    Feb 15 2018
    I went stage 2 with supercharger pulley!
    No Dyno yet
  16. #56
    Jun 23 2011
    (203-345-6499)
    Chris@eplabs.net
  17. #57
    Jun 23 2011
    Cables, SC pulleys, belts, tablets and 183mm Fluidampr Crank Pulley kits are in stock and ready to ship.
    (203-345-6499)
    Chris@eplabs.net
  18. #58
    Jun 23 2011
    We will be closed on Monday Oct 8th in observance of Columbus Day.
    (203-345-6499)
    Chris@eplabs.net
  19. #59
    Jun 23 2011
    We are working on the DP files. And we will keep the introductory pricing in effect until we release the DP files. After that point the pricing will go back to normal.
    (203-345-6499)
    Chris@eplabs.net
  20. #60
    May 31 2016
    Virginia Beach
    Cost for DP tune with pulley?
    Roc Euro Intake
  21. #61
    Jun 23 2011
    Shoot me a PM or email and with the 183mm Fluidampr crank pulley kit?
    (203-345-6499)
    Chris@eplabs.net
  22. #62
    Jun 23 2011
    Beginning this week we are reintroducing our pulley tool rental program on a very limited trial basis. The rentals tools we are having made are the simplest and most well-constructed we have seen to date.
    Terms for tool rental are as follows:
    -$200 deposit is required
    -A $25-dollar charge is deducted for each 5 business day cycle the tool is out (cycle ends when you provide tracking information back to us showing movement, not when we receive the tool).
    -The tool is ONLY to be used with hand tools taking care to properly clean and lubricate before use (we will be supplying lube)
    -Tell us if you broke it! You likely won’t loose your whole deposit if the tool has been in service for a while. If we receive a broken tool back with you contacting us, you forfeit any chance of your deposit being returned.
    -US shipping only
    -And just for EPL customers
    This is a test run to see if this is going to work…. last time we offered this service, the tools were returned damaged more often than not.
    Shoot us an email if you would like to rent!
    (203-345-6499)
    Chris@eplabs.net
  23. #63
    Jun 23 2011
    Just got our first SC pulley tool back from a customer and everything looks great. Lets keep it up.
    (203-345-6499)
    Chris@eplabs.net
  24. #64
    Jun 23 2011
    We have the tools in stock and can ship them out with a SC order. More cables are arriving today.
    (203-345-6499)
    Chris@eplabs.net
  25. #65
    Jun 23 2011
    Cables, SC pulleys, belts, tablets, SC pulley removal tools and 183mm Fluidampr Crank Pulley kits are in stock and ready to ship.
    (203-345-6499)
    Chris@eplabs.net
  26. #66
    Jun 23 2011
    Let us know if you are interested in the SC pulley removal tools at the time of purchase and we can include it when we ship out the cable, pulley and belt.
    (203-345-6499)
    Chris@eplabs.net
  27. #67
    Feb 15 2018
    Vouch
  28. #68
    Jun 23 2011
    (203-345-6499)
    Chris@eplabs.net
  29. #69
    Feb 15 2018
    Vouch
  30. #70
    Jun 23 2011
    More SC pulley removal tools are making their rounds with great results.
    (203-345-6499)
    Chris@eplabs.net
  31. #71
    Feb 15 2018
    If IAT is always under 70*C is there a pulley ratio after which no more HP will be generated on pump gas?
  32. #72
    Feb 15 2018
    Basically at which point is boost limited by octane rather than IAT ?
  33. #73
    Jun 23 2011
    Boost is limited by the pulley ratio and elevation mostly.
    (203-345-6499)
    Chris@eplabs.net
  34. #74
    Feb 15 2018
    But is there a boost level after which point any more boost is futile because pump gas can't handle it?
  35. #75
    Jun 23 2011
    No not really. If you have good 93 and the IATs are in check. But that would not be until DP and a high ratio.
    (203-345-6499)
    Chris@eplabs.net
  36. #76
    Jun 23 2011
    More Pulley removal tools were shipped out and getting rave reviews.
    (203-345-6499)
    Chris@eplabs.net
  37. #77
    Feb 15 2018
    By iats in check does that mean anything under 70c or does even that treshold depend on boost level
    Ex: higher boost means lower IAT point at which performance is rate limited
  38. #78
    Jun 23 2011
    Higher boost does not mean lower IAT. IAT and boost are not connected at all. The lower the IATs are, the higher timing map that the car can run to a point. Under 70 is good, under 65 better and probably under 60 the best.
    (203-345-6499)
    Chris@eplabs.net
  39. #79
    Aug 24 2014
    Newport Beach, CA
    Now that it's cooling off out in Socal, it's amazing how much more responsive this car is power-wise. Looking forward to getting a few lingering issues fixed with the car then pulling the trigger on an EPL tune.
    Imola 2001 Stage 3 S4: 313K - 2.4sec FATs - Completely Refreshed/Built Motor - SRM K24s w/ Custom Turbosmart wastegates - Ringer Racing 4+ - Etspec - Cinesnow WG/Oil Lines - SRM V3 Intercoolers - AA built trans - 4:1 Diff - JHM Trio - 034 - H&R Coilovers - FCP - Bosch Motorsports - OZ Racing - SRM/SSAC exhaust - Tons of New OEM parts
    2009 C6.5 A6 3.0T Prestige - stock, daily driver
  40. #80
    Senior Member Two Rings delz05's Avatar
    May 16 2014
    2013 Volcano Red S5 Cabriolet, 93 Mustang 5.0
    Boston area
    You will not be disappointed!!!
    Family comes First!.... Nice cars a close second.
    2017 SQ5 Ibis White, Black Optics P+ with Tech, Nappa, 21" wheels, Milltek exhaust, EPL Stage 2... more to come
    And for topless Summer fun... 2013 Volcano Red S5 Cabriolet Prestige, Black Optics Grill, Rear Valance, Tint, Unitronics Stage 3 with DP and TCU, IE Down Pipes... doesn't get any better!
    2018 Manhattan Grey Q5 Premium Plus with Nav, Hot & Cold packages, 20" wheels, B/O sound... wifey's new ride
