Results 1 to 4 of 4
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    :: EuropaParts.com :: Meyle HD Control Arm Kits
    Installation Note: It is imperative that the suspension be compressed to static ride height before any suspension pivot bushings are tightened, as per the factory installation procedure. If this is not done, the bushings will tear prematurely as the twisting forces on them will be much higher than is intended. Meyle's Limited Warranty on Heavy-Duty products does not cover premature failure due to improper installation or use. We highly recommend professional installation for this product.
    CONTROL ARM KIT (M12, EARLY, MEYLE HD)
    This upgraded, 12-piece, heavy-duty OEM control arm kit includes all eight (8) front control arms, two (2) sway bar links, two (2) upgraded ball joints, and all of the hardware needed to complete the control arm job on your Early Audi A4 S4 A5 S5 A6 A7 Q5 on the B8 & C7 chassis. The quality of this kit greatly exceeds Audi OEM specs to improve durability and longevity. Your car will handle like new or even better. Designed by Meyle in Germany.
    Important: This kit is suitable for early Audi models with M12 curved lower control arms. The Late M14 kit can be found here. If in doubt, please contact us with your VIN and we'll tell you exactly which kit to order. New and upgraded outer tie rod ends are sold separately. See related products.
    GUARANTEED TO FIT THE FOLLOWING MODELS:
    • 2009-2010 Audi A4 B8 (up to prod. 11/02/2009)
    • 2008-2010 Audi A5 B8 (up to prod. 11/02/2009)
    • 2010-2010 Audi S4 B8 (up to prod. 11/02/2009)
    • 2008-2010 Audi S5 B8 (up to prod. 11/02/2009)
    • 2012-2013 Audi A6 C7 (up to prod. 07/01/2013)
    • 2012-2013 Audi A7 C7 (up to prod. 07/01/2013)
    • 2009-2010 Audi Q5 (up to prod. 10/31/2009)
    CONTROL ARM KIT (M14, LATE, MEYLE HD)
    This upgraded, 12-piece, heavy-duty OEM control arm kit includes all eight (8) front control arms, two (2) sway bar links, two (2) upgraded ball joints, and all of the hardware needed to complete the control arm job on your Late Audi A4 S4 A5 S5 RS5 A6 S6 A7 S7 RS7 Q5 SQ5 on the B8 & C7 chassis. The quality of this kit greatly exceeds Audi OEM specs to improve durability and longevity. Your car will handle like new or even better. Designed by Meyle in Germany.
    Important: This kit is suitable for late Audi models with M14 curved lower control arms. The Early M12 kit can be found here. If in doubt, please contact us with your VIN and we'll tell you exactly which kit to order. New and upgraded outer tie rod ends are sold separately. See related products.
    • 2010-2016 Audi A4 B8 (from prod. 11/02/2009)
    • 2013-2016 Audi A4 allroad B8
    • 2010-2017 Audi A5 B8 (from prod. 11/02/2009)
    • 2010-2016 Audi S4 B8 (from prod. 11/02/2009)
    • 2010-2017 Audi S5 B8 (from prod. 11/02/2009)
    • 2013-2015 Audi RS5
    • 2013-2018 Audi A6 C7 (from prod. 07/02/2013)
    • 2013-2018 Audi S6 C7
    • 2013-2018 Audi A7 C7 (from prod. 07/02/2013)
    • 2013-2018 Audi S7 C7
    • 2014-2018 Audi RS7 C7
    • 2010-2017 Audi Q5 (from to prod. 11/01/2009)
    • 2014-2017 Audi SQ5
    Hubert
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 800.877.7033 x 101
    Email: hubert@europaparts.com
    Facebook: Like Us on Facebook
    Aug 22 2010
    Piscataway, NJ
    Hubert
    Jun 07 2007
    Livermore, CA
    Any discount codes?
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by milpitas2.7T View Post
    Any discount codes?
    Unfortunately no.
    Hubert
