Results 1 to 18 of 18
    May 02 2018
    Chicago
    key-fob long click to close windows?
    So I recently purchased a 18 S3 and I've really been enjoying the car thus far.
    Only thing that bugs me is the key-fob. If you long click the open button it will roll all the windows down, but when I try the same for closing it doesn't do it.
    My brother has the vagcom/thing you plug into the car and if its possible I'd like to get the code or how exactly I can put the same functionality on the close button that is currently present on the open button long click.
    Senior Member Three Rings CronicPAIN's Avatar
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    I have the same problem I used vagcom and activated the function but no luck my windows still roll down but not up with the key-fob but if I insert the key in the door lock and turn left holding it will roll up it weird I cannot find a solution
    I have an Audi A3 2015
    Sent from my SM-G950U1 using Audizine mobile app
    May 02 2018
    Chicago
    Yes same here if I long hold the touch sensor on the door to lock it the windows will roll up as well, only thing is if its raining i'm really not trying to go outside to close the windows.
    Find it very strange they only have the option for them to go down... who thought that was a good idea?
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    The attorneys are the ones responsible for not being able to roll up the windows. There are some tweaks are some Vag com tweaks that are in the B8 forum that still pertain to the newer models.
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    You still have to go into the MMI and select what you want to open and close with your fob.
    Hope this helps.
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I've had plenty of cars that will roll down the windows in this manner, but never up.
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    it works, but takes some screwing around - took me a while on my 15' to get it to work anyway.. there's like 3 places you have to set stuff in VAGCOM. Google on it you'll probably find the thread where somebody told me how to do it - I don't recall the exact steps off the top of my head.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    Quote Originally Posted by Kczach View Post
    Bit 2 - Set to 1
    Hope this helps.
    Don't work I get this No response from controller- Audi A3 2015
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Carista enabled open / close on my 18 RS3 with just a couple clicks.
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    Jul 02 2017
    Irvine, CA
    Bit 2 - Set to 1
    Hope this helps.
    This is definitely wrong. On the MQB cars, it's done with adaptations in 09. 46 hasn't been used for years.
    May 02 2018
    Chicago
    Quote Originally Posted by MichiganRS3 View Post
    Carista? Care to explain what you did to enable this...
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    i have done all tutorial and still no luck to roll up windows last hope is try carista
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    I was able to do mine with OBD Eleven apps
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Apr 30 2015
    Michigan
    Quote Originally Posted by rob24g View Post
    Carista is a dongle / app that allows you to program your car like OBDEleven, but with a simple to use iOS app.
    I think the OBD2 dongle is about $40us, and comes with 1 months of app. 1 year is another $40 or something.
    Dec 04 2016
    Northern California
    Used OBDEleven. Had to roll windows up and down a few time to "reset" them after the applying app.
    Veteran Member Three Rings S3_Miles's Avatar
    Jun 13 2018
    Paso Robles CA
    +1 to Carista. Was super simple to set up on my 15 S3. Was a menu choice. I long click the lock button and it rolls everything up, and closes my roof if its open. Love it. Works as an OBD tool as well
    Dec 10 2004
    R8_LS400
    Dallas, TX
    ok, found my notes. In Vagcom:
    09 Cent Electric/ Adapation / Access Control / Comfort Closing and also "funk comfort schleissen" Have to do both or it doesn't work
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    Quote Originally Posted by Spinnetti View Post
    Awesome it works I did not have activated funk comfort scheleissen once I activated windows roll up with the fob thank you so much
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by CronicPAIN View Post
    Cool.. this stuff can be a pain sometimes, but fun to tweak just how you want it :)
