Results 1 to 40 of 85
    Senior Member Three Rings keninblaine's Avatar
    Nov 06 2016
    Blaine, Wa
    @VeryBadman: That is an excellent, comprehensive and very clearly presented DIY. Thanks for taking the time to document this for others. It is these types of threads that make these forums so helpful and useful. I was OK with everything up to the coding part, which I have no experience with. What equipment did you use for the coding, and what is the cost of it?
    PS: FWIW, I think I'd rather source the parts myself rather than buy them from someone in Russia. You didn't include a part number for the RDKS wiring harness. Do you happen to know the part number?
    2018 RS3 Florett Silver
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by keninblaine View Post
    Codings were done through VCDS and with RS3/TTRS on new MMI, you would need the Hex-Net/Hex-V2 cable from Ross-Tech for the job. The cost is running from $199 for the most basic Hex-V2 cable that works with 3 VINs. It may not sound much but it's plenty for home use.
    For RDKS wiring harness, I really can't find the part number but you can search for the cable to buy from that name. I think it's a common cable used in multiple VW/Audi models. Probably even the super pricey Bugatti Chiron uses the very same cable too.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
