Page 5 of 5 FirstFirst ... 345
Results 161 to 179 of 179
Hybrid View
    Senior Member Two Rings jcpowell's Avatar
    Oct 18 2017
    Somewhere, GA
    If I'm tuned APR stage 3 and install these will it adapt to the increased flow or is a more specific tune like DS1 required?
    2018 Brilliant Black S6 Prestige | APR Stage 3+TCU & downpipes | SRM RS7 Turbos | H&R Sway Bars | RS Grille | Sport & Black Optics Package, Alcantara Headliner
    Senior Member Three Rings robocop47's Avatar
    Oct 21 2019
    Cincinnati, OH
    Quote Originally Posted by jcpowell View Post
    They won’t do anything. It’s not a matter of ds1 specific use but the tune isn’t taking advantage of that bottleneck being freed up
    Junior Member Two Rings
    Nov 25 2018
    2016 Audi S6 : DS-1 Stage 3 : EPL TCU : SRM Long Intake : SRM RS7 Turbos : AMS Catted DP
    Anchorage, AK
    Just did this. I followed the OP's guide for much of the install, but instead of pulling the throttle body hoses, I just loosened them at the turbo's and pulled the throttle body/hoses together. There is plenty of wire/hose length to get everything out of the way.
    As with some, my biggest issue was the passenger side rear screw for the throttle body, I had to shorten mine to get everything back together. There was no way it would go in at the original length, even though it was installed prior to placing the throttle body in position.
    Somewhere along the line, I managed to put a small dent in one of the pipes, but what's done is done. All in, it probably took about 1.5hrs, but I took my time. Reading everyone else's posts really helped.
    Currently running DS-1 Stage 3 w/ RS7 Turbos, AMS Downpipes w/high flow cats, EPL TCU Tune and SRM Intake................ :D :D :D
    Still chasing O2 Sensor issues, so I'll probably look into the adapters/spacers for the rear sensors. I was hoping the AMS downpipes w/cats wouldn't need them, but it appears my setup does.
    2016 Audi S6 Prestige DS-1 Stage 3 w/AMS Catted DP, SRM RS7 Turbos, SRM Long Intakes, EPL TCU
    2022 Audi e-tron Prestige Plus (delivery expected the week before x-mas 2021) ;)
    Senior Member Two Rings audis4culver's Avatar
    Mar 07 2016
    2016 S7, 2011 S4, 1985 VW Vanagon, 2015 Q7, BMW 2004 X5 Manual, 1966 Jaguar E-Type
    Georgia
    I read this entire thread - maybe I missed it but..... does anyone actually have accurate numbers for power gains?
    I have a stock S7 and am considering adding an intake of some kind - CTS Turbo, SRM... but I certainly dont want to waste my time if they dont actually increase power. Thanks.
    2016 Audi S7
    Dec 05 2020
    Newark
    Quote Originally Posted by audis4culver View Post
    If you are stock you won't really see any power gains. You need a tune to increase boost before the inlets really become a restriction.
    Oct 21 2019
    Cincinnati, OH
    Quote Originally Posted by 16AudiS8+ View Post
    This. Those other brand intakes they named really show 0 benefit.
    Oct 21 2019
    Cincinnati, OH
    Dec 23 2014
    S6, Traverse, Prius
    NE Ohio
    I've been following this thread for months. As with others, been waiting for SRM intakes to arrive. I ordered through Eurocode along with some other stuff in early September and received in late December. Finally got the chance to install today.
    Most of what everyone else says is spot on. Depending on the tools/extensions that you have, the job can be easier or more difficult. It took me maybe two hours. Yeah, those short throttle body tubes are certainly a pain, very difficult to get unstuck, but not too bad getting back on, especially if you remove the throttle body as I did. I used some plastic trim removal tools so to not scratch or tear too much, but mostly it takes just getting really aggressive with them. If taking off throttle body, which I definitely recommend, since it is so easy anyway, need that longer Torx T30. As for other tools, basic screwdrivers, socket extensions and wobble extensions. I did find that an L shaped hex key was handy for one of the 5mm bolts. I was able to get the that last passenger side rear screw in the throttle body, without cutting it short, by just scraping by on the tube a bit, but it might be because ...
    My intake tubes from SRM appear to be a new version. They come as two pieces per tube now. I confirmed through SRM because they were different than all the previous pictures (they haven't updated their web site yet). My tubes don't touch each other and I also did not have to trim off anything from the top heat/engine cover as one person mentioned. Getting the couplers and clamps on though was very tight and needed some persuasion because the tubes are so close together at that point.
    I applied DS1 Stage2 tune and drove around a bit. I am running without the stock air box. I have to say I was really surprised about the various new sounds. Not sure that I like it really (the sounds). I might see if I can fit the air box back in or not. We'll see. For now, will let the computer figure things out. I have winter performance tires on right now anyway, never tried draggy with them on, I guess it wouldn't hurt sometime. I probably should wait until the weather is clear and salt off the roads anyway to really test it out (northeast Ohio).
    Junior Member One Ring
    Jan 12 2009
    2016 S6, 2000 S4, 1999 F-350
    Michigan
    Quote Originally Posted by jobu72 View Post
    Try changing these two tables in your Stage 2 file to the RS7 values, see if it gets rid of your new lift throttle sounds while driving gently. Turbo whine and wooshes when letting off under high boost will still be there of course.
    Feb 24 2022
    Jacksonville, FL
    I’m curious to know if that is what SRM is still shipping? Their website still shows. Single piece, unless they’ve done away with the short and/or 2 piece entirely to go back to the original design
    Also, I’m trying to figure out a fitment issue, regarding the PCV hose, and if the drivers side inlet contacts it at all, or any clearance issues with the hose anywhere else with the SRM. I saw one post here somewhat mention it. I’ve purchased and now am returning two different manufacturers inlets, specifically ECS tuning, which was well made, but the inlet tube was clocked so that the throttle body connector contacted the hose inlet, and they then said it wasn’t compatible when I asked about it. Also their couplers didn’t fit right to RS7 sized airbox, which was frustrating. Then I have one from ARM Motorsports, which is an odd design that doesn’t align well with stock airbox (they sell their own intake filter/shield, but separately), but it would squeeze the PCV hose slightly as it came up from the valve, and then would also cause the hose contact the throttle body assembly slightly. Was concerned that could potentially lead to premature failure of the PCV hose. Not end of the world, but I also want reliability and not to have to pull these pieces every 5k just to check either.
    Needless to say, I’m getting good at changing out the turbo inlets :l
    2016 Nardo Gray RS7
    Feb 03 2016
    Cleveland
    Looks like enough people complained to SRM about having to remove their intake to change spark plugs!
    Oct 21 2019
    Cincinnati, OH
    Quote Originally Posted by ItsLarryG View Post
    Now people can complain about the updated ones!
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Sent from my SM-N976V using Tapatalk
    Jan 03 2009
    Iowa
    Not sure what SRM makes now, someone else can answer that.
    But any of the large inlets will lay on the PCV hose, completely normal. Not an issue.
    As far as hooking it up with the airbox, I bought SRM long inlets and cut them to length. It is a tight fit, but the stock RS7 accordion hoses will work. One of my long inlets was fab'd incorrectly, so I had to add a second coupler to get one of mine to line up...typically not needed. But it works fine, no issues...
    Senior Member Three Rings ClaudeG's Avatar
    May 27 2017
    2023 Audi Q7 3.0 | Daily 2006 Mazda Speed6
    Santa Clarita
    I’ve had these installed for nearly 2 years and they’ve been great! But recently I now have an air intake leak code and a high pitched sound ..
    Anyone ever encounter this?
    2016 S6 Prestige, Sepang Blue, Black Optics, Lunar Silver Interior | APR Exhaust | VMR V802 Matte Bronze wrapped in 275/35/20 | Silly Rabbit Intake | NeuSpeed SS Brake Lines | Lowered via OBDEleven | JL Audio XD7005V2 | JL Audio 10"W3
    GONE BUT NOT FORGOTTEN 2017 A6 3.0 Prestige, Brilliant Black, Black Optics
    Daily... 2006 MazdaSpeed6
