Results 1 to 7 of 7
    Nov 08 2016
    Big Sky
    Cracked Fuel Injectors
    I recently developed some leaks around a one of my injectors. While I examined it I noticed a couple others were. I just replaced all the o-rings and they are leaking just the same.
    It looks like I may just need new injector since I am suspecting they are leaking in the body. Anyone know the cheapest spot to get oem or oem equivalent stock injectors? Looking for a set of 6.
    May 09 2012
    Virginia
    Iíll have a used OE set shortly. PM me if interested.
    Nov 08 2016
    Big Sky
    PM sent.
    Anyone use Bosch? Which model is closest to stock?
    How about Siemens?
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    stock is Bosch, only difference Audi uses slightly thicker o-rings comparing to OEM Bosch.
    Do not use Siemens on a stock tune.
    Make me an offer, I have a bad engine in Tysons corner, will pull them for you on Tuesday.
    Nov 08 2016
    Big Sky
    Anyone have experience with a cracked injector? Could it leak more in the morning than after it warms up or would it leak the same any time any temp? I tried soapy water to make sure that's my problem but couldn't tell.
    Thanks V1nny. I am wondering if I need to order the audi o-rings, or get new injectors. Are the injectors you are selling originals or were they replaced ever?
    Nov 08 2016
    Big Sky
    Quote Originally Posted by V1nny View Post
    I haven't been able to find Bosch stock injectors. All I am seeing are the performance upgrade options.
    Dec 04 2012
    Arlington VA
    Sorry I was wrong about brand. Here is OEM set for sale SIEMENS Fuel Injectors Part # 078133551BL:
    https://www.ebay.com/itm/6x-SIEMENS-...L/332749706945
    or
    https://www.amazon.com/UPGRADED-inje...qid=1534127874
    I have set of 2001 injectors in good condition still on the bad engine, may pull them for you if you make an offer.
