Results 1 to 14 of 14
    May 03 2017
    DC/Md/Va
    CEL, whistle, and no boost
    So this morning I noticed a whistle while slowing down. I thought it was my brakes, but the whistle would continue for several seconds after I stopped and was idling at lights. Went in to an appointment and when I started the car the check engine light came on. Drove a few miles to work and the whistle started lasting longer at lights and by the time I got to work the whistling was constant at idle.
    On my drive home I noticed that I didnít have any boost and it didnít sound like the turbos were spooling. Sounds like it is coming from close to where my ROC-Euro intake is, but everything looked and felt like it was on tight. Does anyone have any thoughts or recommendations?
    Jul 01 2012
    11 b8 s4, 90 toyota supra turbo(575 whp), 02 subaru wrx (stock atm),
    North little Rock, Ar
    Items for Sale
    Quote Originally Posted by TritonTC View Post
    Sounds like a boost leak.. did you check for what the codes were?
    Sent from my LM-G710 using Tapatalk
    May 03 2017
    DC/Md/Va
    Quote Originally Posted by mrb5_supra_wrx View Post
    Not yet. Probably wonít be able to do so until later tomorrow.
    Senior Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    Oregon
    Most definitely a vac/boost leak.
    Sent from my SM-N920V using Tapatalk
    1997 VW GTI VR6 (sold), 2003 Audi RS6 (sold), 2010 Audi A4 2.0T (RIP Totaled on 11/2/2015 ) 2005.5 Audi S4
    My build log
    Texpoops "Correct, but a half inch difference isnít going to accelerate wear by much. Iím sure the front dips that much with a fatty in the front"
    Jan 26 2015
    2010 MDX Advance pkg, a workbench
    CO
    Items for Sale
    Oil separator or blown turbos (less likely). Either way, YOU HAVE OFFICIALLY JOINED THE 4.0TT CLUB!!! Now get out your wallet and bend over...
    2014 S6 - Stage 3, AMS downpipes with custom exhaust
    2013 S4 - Dual Pulley e85 - sold
    Jun 30 2016
    NNJ
    Oil separator, have fun...
    Established Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Definitely sounds like the oil separator. You can get a new ĎEí version for about $250. If youíre up for the challenge, check out WhiteWhiteS7ís thread on how to replace it. You can also change out the oil screen beneath the turbo lines as long as you are there, and of course, since youíll be at the turbos, you can upgrade those as well. If you arenít up for a DIY, order the new part and bring it to a reputable indy shop.
    2016 S6, mythos black, RS7 turbos, MRC inlets |AWE intake and touring exhaust| APR downpipes| AMS cooler| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights |Sound: Navtv Zen-v, Audiocontrol DM-810 DSP, JL HD900/5 driving JL10W3 sub and Focal KX3 up front. Rear; JL HD600/4 driving Focal KX2.
    May 03 2017
    DC/Md/Va
    Looks like P2279 - Leak in Air Intake System is the culprit.
    Established Member Two Rings RedheadNV's Avatar
    Apr 05 2017
    Reno, Nv
    I have the same code. I sprayed a little brake clean around different connections, and found a crack in the oil separator. I just did the separator in November, about 3900 miles ago.
    I ordered all the new parts from www.audiusaparts.com this time around. Just make sure that your new separator has the ďeĒ embossed on it.
    When ordering the last one, the Audi dealer kept giving me a reboxed ďDĒ version. I went around and around with them. Now Audi wonít warranty the separator because they say itís not the one I purchased.
    2013 S6 Quartz gray metallic
    Apr 17 2017
    Orange County
    Just got my car back from PCV work and rebuilding turbos that has some shaft play. no CEL came on before having the pcv replaced and after replacing there were a couple O rings on the intake side that were leaking. While waiting for them to come in the same CEL you got came on and the car had no boost. It felt Prius slow. Replaced those O rings, cleared the codes and car runs like a champ again with full boost.
    May 03 2017
    DC/Md/Va
    I cleared the codes, flashed back to stock ecu/tcu tunes, and then took off my roc-euro intake and cleaned the filters. I made sure to reconnect the intake really well after everything dried.
    Took it for a quick 5 minute drive and I had my boost back and didnít hear any whistles. Too soon to tell if this fixed the issue as Iím sure a longer drive will be necessary for the computers to sense something is different.
    Will probably find out tomorrow on my way into work. I bought the car used and purchased a 3rd party extended warranty. If the issue comes back Iíll find a reputable indy mechanic to do the work.
    May 03 2017
    DC/Md/Va
    Took it 20 minutes, but it came back. Anyone know a good independent shop in the El Paso area?
    Jan 26 2015
    CO
    Items for Sale
    Just fyi: I got my oil sep and labor covered under my 3rd party warranty. Make sure they replace with E revision. And for the love of god have them change out the turbo oil filter screen too for revised part, even if you have shell out some money for it.
    Btw the oil sep housing cracks and allows for vac leak.
    Good luck.
    Senior Member Three Rings DocTJ's Avatar
    Jul 29 2016
    Alabama
    Quote Originally Posted by Hofahome View Post
    Good luck.
    thanks for the info
    Triton good luck
    SQ5: TOTALED: 034 Inlet Hose // EPL Stage 2+ // 034 X-Brace // 034 Transmission, Rear subframe, and Rear Carrier Differential Mounts // AWE S-Flo Filter + Airbox Mod // DeAuto LED Interior and Reverse Lights // Phillips LED fogs // E-Codes // RSQ5 Grill // Pearl Nano Ceramic Coating // AG m590 // Thinkware F750 // Valentine 1
    SOLD: '16 A7 3.0T Prestige
    CURRENT: '16 S7 Prestige
