Results 1 to 8 of 8
    Aug 10 2018
    Eugene
    Windshield Washer Nozzle Alternatives?
    The heated windshield wiper nozzles seem to be clogged. I've tried soaking them in vinegar but they still won't spray. I have no need for the heated portion are there any non heated "cheap" alternatives that are snap in?
    Established Member Two Rings turbo3's Avatar
    Oct 08 2012
    Central Florida
    Blow air thru them backwards.
    Jun 30 2008
    Erie, Pennsylvania
    If I recall correctly, the washer jets from a B5 Passat are a direct fit, and they offer an upgraded "fan" spray pattern. There may be some certain year interchanges, so check the details on that first.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Just delete the headlight washers, they dont do dick!
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Registered Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    can confirm it doesn tfit fucking facelift and i broke my fucking washer jet tee trying. may have to replace the fucking lines now.
    EH F0UR 2001 A4 1.8TqM
    = K04 | SOUTHBEND | STERN | FORGE | TREADSTONE
    = ST | MEYLEHD | FCPEURO | 034 | AWE | AKMOTORSPORT | JHM
    = HERTZ | JVC | ALPINE
    2001 A4 1.8TqM
    2002 Golf TDI
    = VNT-17 | 11mm IP | DLC1019 | COLTCAM2 | SOUTHBEND
    = RL Ultimo |
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Quote Originally Posted by Turbo_B5 View Post
    Can confirm Passat ones donít fit. What I did because I hate those fucking penis sprayers was I grabbed Passat sprayers (heated) and both pigtails took mine and cut the mounting clip off. Took the Passat ones that were oval with a adjusting screw and took them apart and grafted my correct mounting clip on to the Passat (fan pattern) sprayer. At first I used hot glue to get the angle and placement on the glass right then plastic welded them together and switched the weather tight connectors. Was a lot of work for something small and I spent like 40$ but I hate the fucking jets and it make me very happy every time I use them. When the windshield is frosted the fan pattern hits the whole shield and defrosts quickly coupled with my brand new oem aero windshield kit bitches get wet lol!!!!
    Sent from my iPhone using Tapatalk Pro
    Oct 09 2012
    I am considering wiper delete now.
    2001 A4 1.8TqM
    2002 Golf TDI
    = RL Ultimo |
    @Turbo_B5
    Aug 10 2018
    Eugene
    I ended up soaking them in some vinegar for a couple of days. That broke up whatever was crustified enough inside that I could run some wire through them and roto-root out all the crusty shit. Finished by blowing some compressed air through them and now they're good as now.
