Results 1 to 7 of 7
    Jun 27 2017
    2003 audi a4, 1988 cadillac brougham-R.I.P.
    Buffalo new York
    97 a4 needs alot of help
    So guys i was working on the a4 again and Noticed my rpm guage stops at 4500rpm, hooked up vcds and the motor revs to 7k like it should. How do i readjust the needle to its proper location? If it wasnt off by 2500rpm i wouldnt care but thats a huge gap
    Jun 08 2017
    london
    Do you think the needle is in the wrong position? Does it not register below a certain rev? If so itís quite easy to take the cluster out and adjust it.
    Jun 27 2017
    Buffalo new York
    I think its in the wrong position. At idle the numbers are off by a few hundred rpm on the dash and when revving you really notice how the guage doesnt match vcds. If i hold to redline the needle will bounce at 4500 while vcds says 7k. Is it really as simple as pulling the cluster?
    Jun 08 2017
    london
    Yes. There are instructions on how to change the lcd in the middle. This involves taking the needles off so follow one of those tutorials and just pull the rpm counter off and reposition.
    Feb 12 2017
    raleigh
    Sounds like a signal issue
    Established Member Two Rings warrenzo's Avatar
    Dec 06 2016
    2000 S4 Black, 2001 Ram 1500 Off-Road
    Lethbridge, Alberta
    First thing, check the coding with VCDS - when I got my A4, the cluster had been switched from a 1.8 to a 2.8, and the needle went way up to 8k RPM. Sounds like you have a 2.8 coded cluster in a 1.8 car. The free VCDS will let you recode it.
    If the needle is off, you can readjust it by turning the needle clockwise until it maxed out, then push a bit more to force it over, then turn it counterclockwise until it maxed out again, and force it more counterclockwise back to the zero position (if that explanation makes any sense?)
    Since idle numbers are off, too, maybe you have a combination of both of these problems - someone didn't know about the coding and moved the needle thinking it would fix it?
    Jun 27 2017
    Buffalo new York
    Quote Originally Posted by warrenzo View Post
    Thats exactly what i needed, the last owner 1.8 swapped it and didnt change anything over but the ecu and associated wiring, my guess is the same he must of moved it but i have vcds so i will try recoding first
