Results 1 to 13 of 13
    Feb 12 2017
    raleigh
    Is Maestro still top cheese for bome brew AEB ECU?
    ^^^^ Havent found a solid answer to this, thanks.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by Fasterd View Post
    If you HAVE to use the AEB ecu it is
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Feb 12 2017
    raleigh
    we have what we have, my friend
    Dec 13 2010
    FL
    Doesn't mean you have to use it. You can use a stand alone, and theres a few places that make a plug n play stand alone for AEB too.
    Feb 12 2017
    raleigh
    ^^^^ do tell me more. PA Emissions passable?
    Edit: I cant buy your wheels for sale, the link doesnt work.
    Dec 13 2010
    FL
    Hit up lugnuts tuning. I think 034 sells one too.
    http://lugnutstuning.com/node/34
    As for emissions, I guess just throw your stock ECU and harness back in every couple of years? A little bit of a hassle, but could be well worth it depending on your setup
    Feb 12 2017
    raleigh
    I thought some dude ran the big B1 efr without issue on maestro?
    Dec 13 2010
    FL
    I haven't seen it, but I'm sure you the proper tuner can sort it out
    Oct 24 2013
    girls MK4 1.8t
    United States
    you can run whatever setup you want with maestro...its a tuning suite.
    Stupid drift A4
    R.I.P RWD-converted '99 A4 Avant 1.8T
    Feb 12 2017
    raleigh
    I understand that, but need for sensitivity increases proportionally with output as margin for error diminishes. Tuning suites have their limitation, like that fact that the aeb maestro is setup with 500rpm increments for setpoint reference and interpolates the value in the dead band.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    500rpm comes and goes by pretty quick with a 60mm turbo. I, and many others, have had great success with big turbo setups using maestro on aeb ecus. All the way up to 9k+rpms.
    Oct 24 2013
    girls MK4 1.8t
    United States
    Well, the margin for error is dictated by you. You can leave yourself a small margin for error ,or a larger margin for error. Like was said above me, a lot of people have run it with great success and made plenty of power.
    Stupid drift A4
    Feb 12 2017
    raleigh
    Quote Originally Posted by Rodgman15 View Post
    Thanks for the insight, I was looking at a T3/T04e 50 trim, Iím having a hard time finding an HY35
