Results 1 to 15 of 15
    Established Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Losing coolant. No leaks shown during pressure test. What could be happening?
    About a week ago I took my front bumper off to install a lip, since then I've had to top off my coolant every couple days. Where is it likely leaking from, and what tests could I perform to figure this out?
    187/57 - e85 custom tune (EPL) - custom exhaust -
    ported blower - IABED TB - Brembo BBK - APR CPS - USP intake- 034 sways and drivetrain inserts - cr-15 - 034 density control arms - Koni sport shocks - Eibach lowering springs - VMR v804 -PSS - N2O coming 😎
    Nov 19 2008
    San Antonio
    Sounds like it could be the lower radiator house. Maybe it backed off a little and just needs to be seated better.
    Really you just got to get under there and look. Maybe take some soapy water and spray it around to clean up any road gunk so you can see the leak better.
    May 08 2018
    Berkeley, CA
    Had it pressure tested... No leaks at all. Gonna keep an eye on it. Maybe it just got rid of a really big air bubble XD
    Established Member Two Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    Could be the PCV failing, especially if it doesnt stop after a week or 2.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Did you actually depressurize the system?
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by BucDan View Post
    Should I be losing coolant under a pressure test if this was the case?
    Senior Member Two Rings Akvdubn's Avatar
    Jun 28 2013
    2001 Imola B5 S4, 2005 Subaru STI, 1997 VW Jetta GLX, 2016 Triumph Daytona 675R
    Anchorage, AK
    Quote Originally Posted by Morritse View Post
    Might be a pretty slow leak. If you have time maybe pressure test and leave it on overnight and check the pressure in the morning
    Sent from my LG-H820 using Audizine mobile app
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Akvdubn View Post
    It isn't a slown leak... At least under normal circumstances. Have to fill up every day almost.
    Jun 28 2013
    Anchorage, AK
    If it's nothing visible, then probably either pcv or intercooler leak
    May 08 2018
    Berkeley, CA
    Any way to check if it's PCV besides pulling the blower off?
    May 12 2008
    Pull your oil cap when the vehicle is running and itíll be tough to get the cap off.
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by theweebabyseamus View Post
    I thought it was a different part of the PCV failing which caused this sort of symptom. There was some slight suction. Really not too hard to get off though.
    May 08 2018
    Berkeley, CA
    Turns out it was the fucking coolant resivoir. Cracked underneath the metal heat shield on the left side of the resi so I couldn't see shit.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    That is an easy fix! You are very lucky.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by jygesq View Post
    Yeah, super relieved!
