Results 1 to 16 of 16
    Feb 22 2011
    Las Vegas/Nevada
    Motor mount failure on 2013 S6
    Just brought in my 2013 S6 for 35k mile maintenance and the mechanic discovered that my mounts needed replacing. Problem is that I bought an extended warranty through Endurance in May but the adjuster came and determined through the ecu that it was damaged/leaking in March... how easy of a diy is this or is it ok to just drive it without replacing them right away? Just need some options cause this job is costing an arm and a leg when I literally just bought an extended warranty for problems like this 🤦🏻*♂️
    Senior Member Three Rings Yoshi123's Avatar
    Apr 02 2014
    Las Vegas, Nv
    Get use to it!! Lol, these Audi motor mounts go all all the time no matter what model. I have a 2012 a7 and have replaced both sides maybe 3 times with less then 50k miles, a decent shop will change them out for less then 400 bucks, sometimes you just have to bite the bullet my friend.
    Feb 22 2011
    Las Vegas/Nevada
    I wish it was 400! The shop is charging me about 1600 for parts and labor.
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by Yoshi123 View Post
    ...a decent shop will change them out for less then 400 bucks, ...
    I thought S6 mounts were around $600/ea? Either way I think they are at least twice as expensive as A7 mounts.
    Veteran Member Three Rings 07S6's Avatar
    Sep 17 2010
    wow...i must be lucky..im at 80K miles and i'm not sure that they've ever been replaced. def not in the last 50K miles.
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Mar 06 2016
    Knoxville, TN
    88K on my 2012 A6 and they have never given me any issue, no codes, never replaced. However, As preventative maintenance, I am installing the 034 Density line mounts since I will be dropping the subframe for a test pipe install. I'm Not sure if 034 offers these for the S6 but it may worth looking into as an upgrade and to save $.
    FastLane / '12 A6 3.0T quattro Prestige Sport / Unitronic BETA DP tune / HPT tcu tune by p3u / Iabed Fluidampr crank pulley 187mm / 58mm Unitronic SC pulley / Merc HX / Injen Intake with modified stock box / JHM test pipes / AWE Touring Exhaust with custom Vibrant GESI catted & Magnaflow resonated DPs / 20 x 9 VMR v702s / Yokohama Advan Sport A/S 275/35/20 / Eurocode sways & Alu Kreuz / 034 lower control arms, motor mounts & inserts / LYKT upper control arms / RS6 Grill / rear lip spoiler.
    Senior Member Four Rings
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    72k miles here and have replaced the mounts twice (once it's driver side only, other times are both sides).
    Also, it never throw any codes or anything, car was in for service and dealer noticed and replaced under warranty.
    - Michael
    2012 A6 3.0T Prestige: GIAC S2 / Injen Intake / Deval rear diffuser / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / KW V1/ RS front grill / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Muffler Tips for sale: http://www.audizine.com/forum/showth...-tips-for-sale
    Mar 26 2010
    CA
    Quote Originally Posted by MacFady View Post
    That's about right for each S6 active motor mount: https://genuineaudiparts.com/parts/2...E&group=MOUNTS
    4H0199256T - FRONT MOUNT S6 right
    4H0199255T - FRONT MOUNT S6; Left
    MSRP = $628.18, Online Price = $467.37
    2016 S6 Sport, black optic
    Oct 20 2016
    Los Angeles/CA
    Just finished up 35k maintenance under audi care on my 2015 S6 as well (cars only at 26k today) - my service advisor did a great job in identifying any issues and replacing which included the motor mounts. The invoice noted a bunch of customer statements (which i didnt make) for each diagnosis. Thought i would share in case anyone needed to use at their dealership to get something looked at:
    Replaced Transmission Pan Gasket - "Customer states oil leaking from under the engine area, oil burning smell from front of car when engine is warm"
    Replaced Engine Mounts - "Customer states engine runs rough at idle, front end of car vibrates at idle" (this one I did ask him based on the RPM test noted in forums)
    Replace Lower Control Arm Links - "Customer states in and out of driveways, front end suspension clunks and makes a popping sound when wheels are turned"
    Hope that helps!
    2015 Audi S6
    Aug 08 2018
    Clearwater, FL
    i send you a PM. i am located in clearwater and i have a shop i go to you can take it and he doesn't charge much.
    Feb 22 2011
    Las Vegas/Nevada
    Thanks for all the advice and input guys! I just decided to get the work done... the shop is charging me 620 for each side and 820 for the labor which totals a bit over 2k just figure I have to bite the bullet this time but any other major work will be done under warranty at least
    Mar 28 2014
    The Big Apple
    It's frustrating seeing all this complexity over what should be a simple motor mount. All because of 4-cyl mode that saves what, maybe 0.1 mpg? No way in hell the minuscule amount of fuel saved is worth it.
    Senior Member Three Rings all_kobiwon's Avatar
    Jul 30 2013
    2012 A6 Prestige. 2015 allroad prestige.
    Denver, Colorado
    Audi should have recalled these, German engineering at it's finest.
    2012 A6 Prestige, Havana Black, EPL Stage 2, LED package, 20" Sports Package. Eurocode Sways, Magnaflow exhaust. Injen cold air intake.
    Mar 07 2018
    Pacific NW
    To all the repetitive failure posters: Do you use your engine start/stop feature often?
    I am trying to correlate if the high failure rate can be due to the frequent cranking during these on/off cycles.
    Mar 26 2010
    CA
    Quote Originally Posted by vector78 View Post
    Most likely due to 4 cylinder mode which happens quite often.
    Mar 17 2017
    Redondo Beach, CA
    Quote Originally Posted by quillonvu View Post
    Wow, I'm surprised the adjuster actually scanned the car for fault codes.
    Word of advice... get an OBDEleven or VagCom cable and scan/delete any old codes, so if they reappear now, it'll be stamped with today's date before you engage your warranty company for future claims :)
    2013 Phantom Black S7 | Innovation package | Bang & Olufsen | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
