Results 1 to 7 of 7
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    '05 A4 USP, '03 A4 Cabby, '02 S4
    Broomfield, CO
    Seat Motor and Autodim
    Couple questions. My driver seat will not adjust up or down, it will tilt but no vertical movement on the switch. Which motor am I looking at replacing? Space/time to work is limited so I'd like to not have to pull it twice.
    Assuming I am after the motor in the middle? What part # would that be?
    Second thing, my driver auto dim mirror is permanently on, sort of a 3d effect almost. The rearview mirror is all permanently on, but clear as it should be. Passenger mirror works as it should. I know the driver glass is not the issue as it was swapped out with several. Am I looking at the assembly/housing being defective or is there something else? Same with the rearview?
    Registered Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Quote Originally Posted by Kittrell View Post
    All three mirrors are connected to one electrical board. It is located inside of the center rearview mirror. It has two light sensors. One pointing to the front. The other pointing rearwards. Check both sensors or/and grab a new used mirror to get a different board. I can post a picture later of what I am talking about.
    2000 RS4 B5 / nogaroblue on black [current]
    2011 A4 B8 avant s-line / monzasilver on black [current]
    2000 A4 B5 [gone]
    1986 Audi 80 [gone]
    May 07 2008
    Broomfield, CO
    Perfect, thank you. I will just track down a newer compass mirror and see if that doesn't correct the issue.
    Any direction on the seat motor folks?
    May 07 2008
    Broomfield, CO
    Compass mirror didn't take care of the driverside.
    Dec 06 2016
    2000 S4 Black, 2001 Ram 1500 Off-Road
    Lethbridge, Alberta
    Has to be a wiring issue then, from the rearview to the side mirror. Has the door been worked on? Maybe some wires got crossed. LCD's need a voltage to stay dark, there's no way the glass would get stuck that way. Not sure what the voltage range would be though
    TBH, it looks like the mirror is fine to me, mine are pretty dark, too, but they get almost totally black when they dim, way darker than the compass rearview
    May 07 2008
    Broomfield, CO
    It's really hard to capture in the picture but it's almost a 3D effect. You can see it the most of you look at the shadows on the ground. The passenger side looks just like my compass mirror, bright and clear. I bought another piece of glass just to be sure. Pending that doing nothing I'll have to start tracing wires.
    Established Member Two Rings Quicksilverawd's Avatar
    Oct 26 2008
    '01.5 S4, '96 Eclipse GSX
    Milwaukee
    Mirror glass is starting to die.
    It'll have that 3d effect that you're talking about, and start going brown during the day.
    A little rice, and a little kraut... at least their both AWD.
