Results 1 to 9 of 9
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    spacer & bore conversion help
    It has been a while since I posted, but I need to tap the collective brain trust of my fellow enthusiasts on a matter I am less than familiar with.
    I am running Enkei Kojan 18x9.5 ET 35 on the 02 S6 wrapped in Michelin Pilot Sports 265/35. My question is as follows:
    The Enkei has a center bore diameter of 72.6 MM and the S6 has a bore diameter of 57.1MM. I need approximately 8MM spacer in order to make the setup work. My question is, are there spacers available that will convert from 57.1MM to 72.6MM and keep the stock 5X112 bolt pattern?
    Also, I had three wheel studs (second bad ECS part I have had fail that involved safety). Can I get a recommendation on a set of proper set of studs that can handle 10MM spacers?
    Thanks in advance.
    ::2002 S6
    Established Member Three Rings JorisRS6's Avatar
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Sounds like you need hubcentric rings going from 57 to 72 mm.
    And a set of spacers with 57 mm hub.
    Just get a set of 10 mm spacers that have bolts included.
    I know studs are nicer but you only have to do this job twice a year.
    Good luck
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    JorisRS6,
    thank you for your quick response. the problem i am having is the hub centric rings do not seem to "seat" fully on the the hub centric spacers. is there a hub centric ring that has a max radius i can look for that will seat fully on the spacers? if i knew how to post photo's i could make this easier.
    ::2002 S6
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Yes pics would make this more clear.
    What do you have now and what are the sizes of the rings and spacers. Do you have a caliper?
    Jun 06 2017
    2003 RS6
    Norwich Canada
    I see hub rings on amzon for 57.1 to 72.6. It doesnt seem to be an uncommon size
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    here is the issue i am talking about. you can see there is about 2-3MM of space from getting the hubcentric ring to seat to the 5 MM spacer.
    ::2002 S6
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Clean the spacers first than take some good measurements. Probably need new rings
    Registered Member Three Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    adapters ftw, spacers are nothing but trouble for me which cleared up with adapters
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    Quote Originally Posted by alien_brain View Post
    i would love to do adapters but am struggling to find adapters that fit my specific need.
    ::2002 S6
