Results 1 to 37 of 37
    Senior Member Two Rings delz05's Avatar
    May 16 2014
    2013 Volcano Red S5 Cabriolet, 93 Mustang 5.0
    Boston area
    C6/A6 3.0T EPL stage 1 and 2
    Just want to confirm the tune is fantastic!!!
    Chris and Tony have spent the better part of the past week working out the power and torque increase in my old 2011 A6... (with 81K miles!) that belongs to my nephew.
    something near 365hp to the wheels with SC pulley swap, with the potential to add another 30+ with a crank pulley and heat exchanger...
    Docile and steady in normal shift mode... an awakened beast in sport mode! The torque pull is beastly!
    I had asked a few of the regular tuners what was available... "we are working on it..." was the most common answer...
    Chris and Tony said... "Come on down!!!"
    So we did.... and they did... and now it's done!
    An amazing improvement, well worth the effort, time and money.
    I hope you are ready to roll this out!!!
    Thanks guys!
    Family comes First!.... Nice cars a close second.
    2017 SQ5 Ibis White, Black Optics P+ with Tech, Nappa, 21" wheels, Milltek exhaust, EPL Stage 2... more to come
    And for topless Summer fun... 2013 Volcano Red S5 Cabriolet Prestige, Black Optics Grill, Rear Valance, Tint, Unitronics Stage 3 with DP and TCU, IE Down Pipes... doesn't get any better!
    2018 Manhattan Grey Q5 Premium Plus with Nav, Hot & Cold packages, 20" wheels, B/O sound... wifey's new ride
    Established Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    Is it ECU only, or is there a TCU tune also?
    I'm already APR on my current C6.5....so won't be changing up, but can totally see buying another one as this one starts to wear out more.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Feb 15 2018
    Vancouver, WA
    Is the 365hp to the wheels dyno proven?
    I am getting stage 2 single pulley - SC pulley setup from EPL for my car!
    I am currently stock right now, so this should be massive improvement for me!
    GIAC is like 350hp to the wheels stage 2 https://www.youtube.com/watch?v=xWPxiW0cAio
    I was really torn between GIAC and APR, but GIAC and APR both didn't go balls deep on this platform, so EPL will have total monopoly on this platform if they do what they say they will and based off your post I am very excited!
    EPL says they are going to get all of the power they can out of this platform!
    They have tons of customers awaiting them if their word is good!
    - - - Updated - - -
    What fuel were you on when you got the 365 and how did you measure it?
    Feb 15 2018
    Vancouver, WA
    Can you elaborate more on the heat exchanger options for this car - I am not aware of any
    Feb 15 2018
    Vancouver, WA
    This a6 weighs the same as an s4, so with this new EPL tuning this car's value about to go UPPPPP literally no reason to get an s4 for straight line
    May 16 2014
    Boston area
    Tony (EPL) confirmed dyno proven, on a Mustang Dyno, high 80d to mid 90d outside temps (dropped car off 7/26, picked up yesterday...) humidity levels high. Dyno is inside their non air conditioned shop.
    Going to fit a Merc Racing heat exchanger (already have it, just have to work on fabbing up mounting brackets). While not a must do... it will help keep the power band consistent and at max HP/TQ throughout the RPM range.
    No TCU tune at this time, but that is something Chris and Tony can comment on...
    If all goes well, the plan is to bring the car back in October (cooler temps) with the new heat exchanger completed, new Fluid Damper pulley installed and try to complete a dual pulley tune upgrade.
    Feb 15 2018
    Vancouver, WA
    Quote Originally Posted by delz05 View Post
    What fuel
    Feb 15 2018
    Vancouver, WA
    See if EPL will build a cooling system that's bolt on for this car
    Also can you explain to me what the heat exchanger is doing? Is it just adding on to the cooling capacity of the radiator?
    Is the charge coolers in the supercharger cooled by the same coolant as the radiator?
    Senior Member Three Rings dluxxx's Avatar
    Mar 13 2013
    Nor*Cal
    I tried getting a EPL tune from the a while back and said my ECU was not compatible. I believe my 2010 C6.5 has the Simos 8.3 ECU and their tune applies only to Simos 8.4 or 8.5. Has this changed?
    2010 A6 C6.5 3.0T, Remus Mufflers w/ Quad tips, Magnaflow Resonated X-Pipe, RocEuro Intake, Chipwerke Pro, Transparent Gloss Copper Verde Axis V99 20x9, Michelin Pilot Sport 4S 265/30, Bilstein P14 PSS Coilover, H&R Rear Sway Bar, RS6 Black Gloss Grill, Rear diffuser, Black Vinyl window trim, Smoked Rear Tailights, Complete Interior LED Lights, Blacked out front sidemarkers, Morimoto 5000k D3S bulbs, SB3 Alpha Ceramic Coating.
    Stage 2 Banner Advertiser Four Rings Chris@EPL's Avatar
    Jun 23 2011
    Quote Originally Posted by dluxxx View Post
    Yes it has. Still just Beta for Stage 1 and Stage 2, but it will be very soon.
    European Performance Labs
    http://www.facebook.com/EPLabs
    https://www.instagram.com/eplabs/
    (203-345-6499)
    Chris@eplabs.net
    Please feel free to contact us with any questions!!
    May 16 2014
    Boston area
    Quote Originally Posted by NickLim View Post
    Running 93 octane pump gas...
    Heat exchanger will increase cooling capacity, and give you the option of separating the SC coolant from the engine coolants...
    plenty of write-ups in the S4/S5 forums....
    Feb 15 2018
    Vancouver, WA
    Wonderful results! Seems on par with GIAC and if it's still in beta that's amazing news!
    Interesting - so stock the SC coolant is shared with the engine coolant?
    Whereas with an additional radiator the SC coolant will have its own radiator and pump?
    Or would you simply be adding it on to the same line
    Senior Member Four Rings christianb5s4's Avatar
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by Chris@EPL View Post
    Very interested if you're able to get it to work on the earlier ECUs on the 09-10 models, I would definitely be a customer.
    Imola 2001 Stage 3 S4: 312K - 2.4sec FATs - Completely Refreshed/Built Motor - SRM K24s w/ Custom Turbosmart wastegates - Clutchmasters Stage 4 - Etspec - Cinesnow WG/Oil Lines - SRM V3 Intercoolers - AA built trans - 4:1 Diff - JHM Trio - 034 - H&R Coilovers - FCP - Bosch Motorsports - OZ Racing - SRM/SSAC exhaust - Tons of New OEM parts
    2009 C6.5 A6 3.0T Prestige - stock, daily driver
    Jun 23 2011
    Quote Originally Posted by christianb5s4 View Post
    If you have VCDS and can send me your box code I can check, but yes I do not think it will be a problem.
    (203-345-6499)
    Chris@eplabs.net
    Aug 24 2014
    Newport Beach, CA
    I can get that to you.
    Mar 13 2013
    Nor*Cal
    OMG can't wait. Please post a thread on here when it is out of the beta phase. Very interested in the stage 1.
    May 16 2014
    Boston area
    Yes... all fluids shared
    Yes, you can separate the systems but the engine uses the water pump to push coolant flow, and on my S5, the SC loop has a pump in addition to the WP. Not certain about these A6 model... working on it next week.
    Feb 15 2018
    Vancouver, WA
    So just string on an another radiator to the coolant line and you're good!
    So heat soak should be seen on the temperature gauge as well if I understand it correctly?
    Established Member Three Rings Ford Prefect's Avatar
    Jan 20 2017
    2011 Silver S4, Mercedes Benz R350 ('07 & '11), Suzuki SV1000
    New Hampshire
    Check out the B8 S4 section. Tons of info there on cooling, assuming it’s the same since the motor is the same.
    The two systems are connected only to share a reservoir. The engine cooling is driven by a belt turned water pump. Charge cooling is via an electric pump (drivers side behind head and fog light). The charge cooling HX are crazy small. Many divorce the systems so they can run more water and less antifreeze in the charge cooler portion for summer.
    Again, tons of info in the B8 S4 section. Hopefully is the same setup for you guys.
    Established Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    Been shopping around for a C6 A6 Avant w/ the 3.0T. This is exciting to hear. It would be great to eventually have the TCU tune available as well as it seems the Tiptronic is the limitation on this platform.
    IG: @puzoyboy
    '15 S4 Sepang Blue (6MT)
    | APR Stage 2+ UC| APR CPS| Milltek Valvesonic| ECS CF Intake| H&R Street Coilovers| SPC ACA| EuroCode Sways & Endlinks| EuroCode ST Shifter| BFI GS2 Knob+Boot| Alu Kreuz| CR-15| ECS Drivetrain Inserts| P3 VIDI| USMW bracket| RS style front grill & fogs| Deval CF Diffuser| RSNAV 10.25"| HRE FF01|
    Mar 13 2013
    Nor*Cal
    Quote Originally Posted by alexdell View Post
    MRC Tuning based in the UK has a TCU tune for our cars but i asked them if they have any dealers out here in the US and they said no... supposedly they said their tune for the tip gearbox makes it rev higher and hold more torque... it is doable but i guess no tuner here sees much value in it...
    Feb 15 2018
    Vancouver, WA
    That's HUGELY valuable
    Feb 15 2018
    Vancouver, WA
    If this car gets a TCU tune then this car is KING
    Dec 01 2007
    Orange County, NY 10918
    Subscribed to this cause i need this lol
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Feb 15 2018
    Vancouver, WA
    I'd pay for a TCU tune right now
    Veteran Member Three Rings ichi d's Avatar
    May 10 2013
    T.O.
    s4 is a bit lighter and has a dsg and i bet it will feel more nimble. s4 tune vs a c6.5 tune the s4 will win all day long. sorry to break it to you. lol
    C7 4.0T
    Donated - C6.5 Apr Stage 2
    Mar 13 2013
    Nor*Cal
    Quote Originally Posted by ichi d View Post
    yeah.. plus the sports differential option the S4 has...dual pulley tunes....the C6 is like the middle child of the audi group... always forgotten
    Established Member Two Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    2018 A6 Comp, 2017 Q7
    Chicago Burbs
    Current A6 gets dual pulley with enhanced TB through APR. that’s something
    Feb 15 2018
    Vancouver, WA
    Definitely! By about 1-5%
    Some people care about that 1-5% but it's not worth it to me to pay 2-3x for a smaller car with less luxury and less comfortsble ride for that marginal performance
    99% of the time I'm cruising only 1% of the time racing
    - - - Updated - - -
    Forgetting is a good thing
    If people knew about it there's no way it'd be this cheap
    Established Member Two Rings ApostolSauce's Avatar
    Oct 28 2010
    C6.5 Avant, STG3 B5S4
    North Jersey
    I was getting myself ready to buy into APR stage 2 with both pulleys, but I am interested in what EPL has up their sleeves. Also very interested in any kind of improvement TCM wise. Hope this thread continues positively :)
    Feb 15 2018
    Vancouver, WA
    Quote Originally Posted by ApostolSauce View Post
    Very excited about this as well!
    If this car gets a TCU tune in the united states I foresee the c6 a6 BLOWING up with enthusiasts who are in the know
    Senior Member Three Rings diabolical1's Avatar
    Mar 24 2009
    New York and Toronto
    Glad to see EPL is still at it.
    Because S4 = Hooker
    - getslideways
    Aug 24 2014
    Newport Beach, CA
    The thing I don't find ideal in these cars is how long the gearing is. The car is quick but the long gearing makes it feel like it's not as quick as it is at least compared to the S4's DSG.
    Oct 28 2010
    North Jersey
    i find the gear ratios to be good, driving the car in upper RPMs is quite satisfying given the kind of transmission we’re working with here. What id like to see improvement on is less torque converter slippage and quicker gear change at low gear lower rpm. But who knows how much improvement there can be in a transmission with older technology. Maybe EPL knows..
    Aug 14 2010
    Buchanan, NY
    I flashed my car last night with EPL's Stage 1 software. It feels like a lighter car and the grunt down low is waaaaaaaaaaaaaaaaay more evident! the car feels much more eager to get itself moving from a stop.
    The trans is the dull spot of this car. The torque converter slippage is obvious but if you drive it in a particular way it can be mitigated somewhat.
    I can only imagine how much more fun the car would be with the S4 manual or DSG trans in it.
    Feb 15 2018
    Vancouver, WA
    Quote Originally Posted by Mr. Rictus View Post
    Good to hear!
    Aug 24 2014
    Newport Beach, CA
    Is the converter slippage more pronounced now or the same as before?
