Results 1 to 24 of 24
    Dec 12 2015
    McLean, VA
    Best E85 Content Monitor
    Hey all,
    About to flash the APR E85 Tune with switching and I want to get a Bluetooth content monitor. I've seen a lot of fuel-it apps around the forums, but not a specific kit that will work on the RS3.
    Wondering what everyone thinks is the best monitor for this platform?
    2017 Audi RS3
    DGP / Dynamic
    Established Member Three Rings S3DUDE's Avatar
    Aug 29 2017
    AZ
    Check out innovative motorsports, they have been around for a while
    2018 RS3 Glacier White European delivery. Driven at 140mph /4000 rpm the within the first 25 miles after picking it up from the factory.
    Jun 11 2018
    Twin Cities MN
    I'm running the APR stage 1 E85 map and bought the fuel it bluetooth kit from Eurocode, makes it easy to monitor the ethanol content.
    https://www.ecodetuning.com/vw-audi-flex-fuel-kits.html
    2017 Audi RS3 Catalunya Red|APR Corn File|Iroz Downpipe/Midpipe|Milltek non resonated exhaust|Neuspeed RSE10|H&R Springs
    Active Member Two Rings nicholasdaa's Avatar
    Apr 26 2018
    2018 Tahoe Z71, 2014 E30 Stage 3 Big Turbo Ford Focus ST
    Colorado
    I run the Fuel-It! sensor and installed it myself, works great, quick, easy to use/install, and seems pretty reliable. I did have some issues during install, but that seemed to be from an OEM Audi part, fixed it myself in a couple of minutes.
    Current -
    • 2018 Nardo RS3 - Fully Loaded - E85 APR Stage 1, Milltek Catback, Secondary Decat
    • 2018 Black Tahoe Z71
    • 2014 Tuxedo Black Ford Focus ST - E30 Stage 3 Big Turbo
    Past -
    • 2014 Firesand Orange F-Type V8S Convertible
    Established Member Two Rings MichiganRS3's Avatar
    Apr 30 2015
    2017 Ford Escape
    Michigan
    Quote Originally Posted by nicholasdaa View Post
    Any photos of system installed on your RS3? Also, total install time? Thanks!
    `18 Mystic Blue Pearl Effect RS3
    Technology / Driver Assistance / Dynamic / RS Design / Black Optics
    Audi CF Spoiler / Audi CF Mirror Caps / Llumar Ceramic Tint 35% / APR FMIC / Fuel-It Ethanol % Sensor /
    Apr 26 2018
    Colorado
    Quote Originally Posted by MichiganRS3 View Post
    Green is fuel, Yellow is ethanol sensor, Blue is bluetooth module, and red is the power/ground wires. Took about 20 minutes to install, very easy + 30 minutes of testing/fixing the fuel leak I created.
    EDIT:
    Tapped into fuse F10, which is the fuel pump fuse that you'll be messing with during install.
    Current -
    Past -
    Apr 30 2015
    2017 Ford Escape
    Michigan
    Awesome! Thanks!
    Dec 12 2015
    McLean, VA
    Wow.. thanks for this!
    2017 Audi RS3
    DGP / Dynamic
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by dansnexusone View Post
    i wouldnt cut the hose right there
    if you look at that same line closer to the manifold there is already a coupler in the hose that can be removed and the sensor installed there
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic stage??
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Apr 26 2018
    Colorado
    Quote Originally Posted by saxon View Post
    Feel free to do it however you want, with proper fittings it shouldn't matter. I did mine there because the quick disconnect coupler you're talking about started leaking on my initial install, had to modify to this =(
    Current -
    Past -
    Oct 16 2012
    pa
    my only reasoning is that i can reinstall that part and remove the sensor without the dealer ever knowing.
    Unitronic stage??
    Apr 26 2018
    Colorado
    I agree, I wanted to use that originally but the leak ruined that idea for me.
    Current -
    Past -
    Apr 30 2015
    2017 Ford Escape
    Michigan
    Care to show us a photo of where you are talking about?
    Apr 26 2018
    Colorado
    He's talking about the area in red, its normally a double sided quick disconnect coupler.
    Current -
    Past -
    Oct 22 2005
    12 R8 / 04 A4 / 15 Allroad / 93 300SE
    Reppin the Mitten.
    Where is everyone tapping for power?
    Apr 26 2018
    Colorado
    Quote Originally Posted by vinny.dtw View Post
    Up above you'll see a fuse box diagram with the fuse F10 being used, this is the Fuel Pump fuse and you'll be pulling it to install the new line and sensor anyways.
    Current -
    Past -
    Oct 22 2005
    Reppin the Mitten.
    Thank you, sorry i was on the app earlier, and it didn't load the pics. Thanks!
    Active Member Three Rings
    May 03 2018
    If you got chresed by fuel-it, with VW/Audi kit before the 2.5L intro, like me, AND paid the extra :headbang: $20 for shipping, when it is free from eurocod. Cheap asses at fuel-it would not credit the 20$, so they desperate with poor CS!
    Anyway, the lines are a diff size, that you can cut, everything else the same per Steve@fuel-it to match the RS3 kit.
    Fuel line between sensor and quick connect is 3.5"
    Fuel line between sensor and barbed connection to HPFP is 9"
    Thank you!
    Fuel-It!
    1997 VW GTI VR6 / 1999 Mitsubishi Eclipse Spyder GST / 2000 Limited Tahoe / 2002 VW Golf GLS TDI / 2004 VW HPA FT360 R32 / 2004 VW R32 / 2012 VW Golf R 4dr Base / 2015 VW Golf R DSG loaded / 2017 VW Golf R DSG Loaded / 2018 Audi RS3 /
    Apr 30 2015
    2017 Ford Escape
    Michigan
    Resurrecting this for a minute. Does anyone know which fuel line feeds the high pressure fuel pump?
    May 03 2018
    Apr 30 2015
    2017 Ford Escape
    Michigan
    Quote Originally Posted by comingabriel View Post
    So the other one feeds the port injection system. Ok.
    Which system is used for low load driving conditions?
    And is there no return line on these cars?
    Last car I modified was an 05, so a LOT has changed. Trying to get up to speed here.
    Thx.
    May 03 2018
    1) why would you want to tap a hpfp line? Do you know how much pressure comes out of there???
    2) maybe that line feeds the injectors and hpfp, which came directly from the tank, and 100% fine to tap to measure gas content (less gas more et-oh, since it does not actually measure et-oh) low pressure fuel, even before rail, etc..
    Apr 30 2015
    2017 Ford Escape
    Michigan
    I want to avoid putting the ethanol content monitor in the line feeding the high pressure fuel pump. Doing some additional research this morning, the fuel line that is strapped to the front of the intake manifold is the supply line to both the port injectors as well as the HPFP. The other line is the return to the fuel tank from the pressure regulator. I will be putting my monitor in the return line, as not to possibly interfere with the fuel delivery.
    May 03 2018
    I understand your point, but an O2 sensor affects performance, due to possible flow restriction?
    Please fill me in on anything you've might have learned that the Continental sensor affects fuel flow in anyway.
    Tapping the return line is interesting though.
    Fuel may be more heated than the supply line (any accel wear potential or anything negative possible going that route)?
