Results 1 to 40 of 40
    Aug 02 2012
    2000 S4
    Harrisburg
    Flashing battery light and burning smell
    So after I drove home from my 40 mike commute to work. I noticed my battery light was intermittently flashing. It was not a constant flashing pattern. I also smelled a burning rubber smell. From what I read so far everyone says the alternator is going out. But no one mentions the burning smell. I looked at the belt with the car running and it seems fine and isn’t slipping. But that was my first guess that the belt was slipping and cause the burning smell and the flashing battery light. I turned the car off and started it again which it started right up but the light continued to randomly flash. What do you guys think?
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Check grounds on the car, if they are bad it could explain the warning lamp in and out as the voltage may be all over the place. when my alternator crapped the bed it just stopped charging no smell. You can wile it is running check with a DMM to see if you are getting 13-14 volts on the battery terminals after you start up, GL
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Aug 02 2012
    2000 S4
    Harrisburg
    So I started the car this morning and after 2 minutes of warming up there was a good amount of smoke pouring out of the hood.. still got the flashing battery light.. strong smell of burning rubber. But the belt is fine and not slipping and all the pulleys are spinning. Can’t pinpoint exactly where the smoke is coming from other then the front end. I might finally be giving up on this car after 10 years of blood sweat and tears with it. I just can’t trust it anymore
    Aug 24 2014
    Newport Beach, CA
    I would disconnect the battery immediately if I were you, there's clearly an electrical short in the wiring that's causing that smoke. If it's creating that much smoke it's more than capable of burning your car to the ground.
    2024 M3 Comp xDrive
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    what ^ he said, also for it to throw smoke like that and not short a fuse I would look at the battery to starter/alternator wire shorting out its the only thing I can think of in that area that would not cause a fuse to blow.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Check the starter wire that runs down the pass side frame. It’s under a plastic covering. My friends car lit on fire Bc of a short there.
    Aug 02 2012
    2000 S4
    Harrisburg
    Dang. I’m at work now. I’m pretty paranoid I’m gonna go home to a car on fire. At least it’s supposed to downpour all day in my area
    Aug 02 2012
    2000 S4
    Harrisburg
    About a month or so ago I kept having fuse #29 blow constantly. One day it went away never really found out what it was.. maybe this is related????
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Holy crap, I would stop driving it and pull the battey terminals off ASAP, the fuse blow may have something to due with it, off top of my head i dont recall what #29 is , GL
    Aug 02 2012
    2000 S4
    Harrisburg
    It’s one of the ECM fuses I believe
    Aug 02 2012
    2000 S4
    Harrisburg
    Battery is 12v when off and 14v when running.. used vag com and zero codes.. the smoke is coming from the front passenger side I’m gonna check the wiring to the starter and alternator
    Aug 02 2012
    2000 S4
    Harrisburg
    Wiring all checked out and good.. but I found some wet black tar/gunk inside the alternator if I can figure out how to post pics on here I’ll do that tomorrow. Also the alternator was extremely hot after only running the car for 2 mins I burnt my finger. You guys think it’s the alternator putting out the smoke? I’m afraid to run my car anymore in case it is burning wires somewhere else
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    If there is black stuff on your alternator. This means that the bearing inside the alternator that drives the pulley is probably roasted. And what’s happening is, the belt is slipping on your alternator pulley, because the pulley no longer wants to spin. The friction between the belt, and the alternator, are causing it to smoke. With this, rubber is melting onto your alternator. This is also causing a battery light to flash on and off, because the alternator pulley isn’t spinning adequately enough to produce charge.
    Time for a new alternator. And voltage regulator. And whatever else you can change while your in there.
    Aug 02 2012
    2000 S4
    Harrisburg
    It’s weird because it looks like the pulley is spinning fine on the alternator. I’ll post picks here soon
    Aug 02 2012
    2000 S4
    Harrisburg
    Aug 02 2012
    2000 S4
    Harrisburg
    Any input? I’ve never seen that stuff inside an alternator. But I don’t want to just go ahead and replace the alternator if there could be a Short elsewhere that cause this
    Feb 23 2010
    Emmaus Pa
    Replace It.
    Aug 02 2012
    2000 S4
    Harrisburg
    Quote Originally Posted by CELison View Post
    Replace It.
    So you think this is just an issue with the alternator itself?
    Aug 30 2015
    Derry NH
    From looking at the pictures. It seems that the alternator is WHEYSTED.
    Replace it.
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Those windings are charred and definitely your problem.
    That black is likely plastic that has melted inside and is causing the smoke.
    Sent from my SM-N950U using Tapatalk
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Aug 02 2012
    2000 S4
    Harrisburg
    Sounds good I will be yanking it out tonight
    Aug 30 2015
    Derry NH
    Post more pics of your able to. Once you get the front clip off.
    I wonder if the voltage regulator was affected.
    Jul 31 2014
    NH
    As they said replace it, it looks like the enamel on the windings has melted and charred which mean the alternator has an internal short or got way to hot
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Please post pics of this so I can plan my alternator change when appropriate!
    Sent from my XT1254 using Audizine mobile app
    Aug 02 2012
    2000 S4
    Harrisburg
    I got the car in service position last night but I misplaced my whole set of Allen sockets.. does anyone know off the top of there head what size Allen socket I will need for the two bolts on the alternator and the pulley???
    Aug 02 2012
    2000 S4
    Harrisburg
    After a few days of fighting with the garage to get my “lifetime warranty” alternator swapped out. They completely refuse and “lost” my paperwork. I’m selling this car as soon as I get it running so I want to spend as little as possible on this replacement alternator. I saw a few recommendations for the duralast alternators at autozone. A few of them show up in the searches but none say they fit the B5 S4. Does anyone have the autozone part number that I’m looking for??
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    So when you go onto the AutoZone website and login they have this My Vehicle section where you put n your vehicles info and the parts that fit will come up in your searches.
    Duralast 12056 is what came up for me (2000 Audi S4)
    Their site is pretty spot on with fitment.
    Why sell the car? Your the S4 Boost King after all.... ;)
    Aug 02 2012
    2000 S4
    Harrisburg
    Yeah I ended up getting that alternator with that part. Thanks though! And I’m kinda done fixing this car every 3 months. Also I’m at 215k miles and still on the stock clutch and turbos, so I’m gonna end up spending almost twice what the cars worth to get nice turbos and clutch along with the other upgrades it would need. Looking to get a c7 s6 or a b8.5 s4 as of right now
    Aug 02 2012
    2000 S4
    Harrisburg
    Another question I had to yank the coolant hose off in front of the alternator to get it out. If I just run the car with the heat on and keep adding coolant will that get all the air out of the system or will I have to bleed it???
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Our cooling systems are designed to self bleed over a couple of heat up/cool down cycles. Not even necessary to run the heat as there's always coolant flowing through the heater core. Just fill it, start it with the cap off, and top it off. Put the cap on and go for a short drive. After a warm up and cool down, top it up again.
    Aug 02 2012
    2000 S4
    Harrisburg
    Thanks for the help. I finally got a replacement alternator and am taking off work tomorrow to finish this job. I just hate working on it for 30-45mins every night I just want to get it done
    Aug 02 2012
    2000 S4
    Harrisburg
    Got everything back together car runs great no smoke, smell, or noises from the alternator. Only thing that worry’s me is when I have the key in the ignition and turned but the car not on, the battery light very slowly blinks. But it starts right up every time and seems ok?? Tested the battery and the alternator with a DMM and are fine. Also the power steering pump is now howling. This is why I wanna finally get rid of the car.
    Feb 23 2010
    Emmaus Pa
    Are you low on fluid or did you disconnect a ps line? If you did, jack the front end up and turn the wheel lock to lock with the engine running.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Aug 02 2012
    2000 S4
    Harrisburg
    I was a little low on fluid so I topped it off. But it was still making noise hopefully it goes away tomorrow. But what worries me more is the slow blinking battery light when the car is off but the key is turned to the on position. Doesn’t blink when the car is running though. Any ideas on that?
    Aug 02 2012
    2000 S4
    Harrisburg
    So the power steering issues went away. Isn’t he morning my battery light was still slowly flashing when the car was off. But after my 40 min drive to work it stopped so hopefully it stays away
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    Was the battery fully charged once the new alternator was installed? Should hook it to a charger/tender to ensure full charge. Weak batteries or ones deep cycled can shorten the life of the alternator
    Aug 02 2012
    2000 S4
    Harrisburg
    I did not fully charge the battery. I didn’t really think of that. But the battery is only 4 months old and should still be solid. It started right up after I got everything together. That could have been the issue. And after my drive to work it fully charged the battery and that’s why it wasn’t flashing after I turned the car off..
    Aug 02 2012
    2000 S4
    Harrisburg
    Still have the flashing battery when the car is off after it hasn’t been driven in a couple hours. Still starts up fine though. I wonder if I damaged the battery somehow when I hooked everything back up
    Veteran Member Three Rings SoundEfx's Avatar
    Aug 29 2017
    2000 S4 - 2001 S4 - 2003 RS6
    PNW
    Quote Originally Posted by s4BoostKing View Post
    This might be it.
    Aug 02 2012
    2000 S4
    Harrisburg
    Just had the battery tested and it is fine.. not sure what to do but that battery light makes me nervous
