Results 1 to 2 of 2
    Feb 20 2010
    2009 Dodge Journey, 1998 Passat AEB, 1999 Passat AEB, 2000 A4 ATW, 2002 A6 3.0/2.7T tiptronic KLR250
    Brighton, MI
    2006 A3 2.0T - wiring diagram/pin out for oil temperature/level sensor in oil pan
    Can someone post the wiring diagram (wire colors, pin numbers) for the 3 pin oil level and temperature sensor?
    Mine was ripped off, need to wire in a new connector.
    Thanks.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    Can someone help with a wiring diagram? Need to make a new connector (old ripped off).
    05 Golf TDI
