Results 1 to 3 of 3
Thread: My humble build
    Established Member Two Rings atldoc1's Avatar
    Oct 25 2016
    S63AMG, Volvo C30 Polestar, Subaru Outback 3.6R
    atlanta
    My humble build
    Hello gang. Ive been a member for a few years now, but have never posted since my car has always been a work in progress. This is my first Audi (B8 A5) and I bought her slightly used CPO in 2012 with under 6K on it. Im at 93K now, shes still good as new and I love her more than ever. Shes been a daily driver since day 1, but Im finally getting a new daily cause shes becoming more and more irreplaceable to me. Her name is Eila. Design goal is a OEM+ / SuperStreet look, but functional as an amateur track day/autocross car also. Put down 267whp 300wtq in April on a mustang dyno running 93 Octane, 90+ degrees ambient temp. Hope yall like the build.
    Car list for Eila
    Suspension:
    Alu kruez
    Koni FSD shocks
    CR-15
    034 control arms
    Vogtland springs
    Control arm service kit
    034 Front End Links
    AWE wiring harness relocator
    ECS Spacers
    ECS Street Shield
    ECS Transmission shield
    Front Strut mounts 034 x2
    Rear shock mounts x2
    034 rear sway bar and end links
    Eurocode top & bottom diff mounts
    CTS turbo transmission mount
    034 rear subframe mounts
    034 Tie Rods
    UltraRacing front upper strut bar
    UltraRacing rear lower cross bar
    H&R front sway bar
    Engine:
    APR Stage II Tune
    Go Fast Bits Diverter Valve
    Eurocode Turbo Muffler Delete
    Ignition set w/ NGK plugs
    K&N Oil/Mann cabin filter
    ECS Magnetic oil drain plug
    Luft-Technik CAI
    Borg Warner K03 upgraded Turbo. Clipped 10* turbine, ceramic bearings, Billet compressor wheel. Heat treated housing.
    DEI Turbo blanket
    ECS FMIC
    Eurocode Charge Pipe
    ECS air scoop
    Fluidampr w/ ARP Bolt
    New OE HPFP
    Braking:
    SS Brake lines USP.
    Rennline Pedal Set
    Stoptech slotted rotors x4
    Carbotech XP11 pads
    Front & Rear brake pad/rotor service kit
    Motul fluid 3 cans DOT 5.1
    Brake Flush
    Exhaust:
    034 HFC
    Spintech muffler
    USP- DP
    Akrapovic Tips
    034 MiniCat Spacer
    Rear 02 sensor
    Vibrant piping & resonator
    Aesthetics:
    Painted Calipers
    RFB lighting LED kit
    ZIZA lights
    Interior lighting kit RFB
    LaminX headlight, taillight, foglight Tint
    Two tone window trim
    ECS CF engine cover
    CF spoiler
    CF oil can cover
    CF side view mirrors
    CF door handles
    CF Aerial
    CF radiator shroud
    CF interior trim
    Suede boot shift
    BFI Billet shifter
    One-off CF F1 style steering wheel with leather airbag (not yet installed)
    Maxton Design front splitter
    Strafe design side skirt extensions
    Maxton design carbon side skirts
    OEM valance redone in hex carbon fiber & a ceramic coating.
    19 Alzor w/ tire stickers; Sumitomos
    To Do:
    - IE Manifold
    - Big turbo
    - APR HPFP
    - Bosch or Nostrum injectors
    - Upgraded LPFP Bartek
    - Engine rebuild IE
    - Level10 transmission rebuild
    - Aeromotive LPFP
    - Snow Performance Stage 2
    - Grams Throttle body
    - BBK
    - Agency Power front/mid ties
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    @atldoc1
    hardly what i would call 'humble'.... lol... ; )
    i truly appreciate the performance-minded tack you have taken.....
    i have been looking at the UltraRacing front upper strut bar & rear lower cross bar myself....
    do you feel added stability with these?
    does the front bar require drilling mounting holes?
    great car....!!!!
    Bill
    2011 A5 2.0T Old Man Project
    1983 Porsche 944 (Modified)
    1971 Moto Guzzi Elderodo
    Avatar Chart
    Oct 25 2016
    atlanta
    Quote Originally Posted by wkhanna View Post
    @atldoc1
    great car....!!!!
    Thank you very much. I did notice a difference when turning in and mid corner. Im debating on getting the Ultra Racing mid-frame or Agency Powers front/mid ties next. Those should help with mid-corner adjustments and lift off understeer.
