Results 1 to 25 of 25
    Mar 21 2011
    NJ/NYC
    Heads up for B9 S4/5 guys...... Bosch BMW ECU/DME has been cracked.... same as B9
    Guys just wanted to let everyone know since I follow the BMW boards that the Bosch ECU/DME that are in the BMWs (which is the same as the B9 Audis) has finally been cracked for flashing. (finally)
    They are supposed to start flash tuning 335's and 340's in the next few weeks, so its only a matter of time until APR, Revo, and everyone else follow suit for Audi models.
    If anyone wants to read....
    http://www.n54tech.com/forums/showthread.php?t=54066
    Just a friendly update for everyone. :)
    Senior Member Two Rings dave329's Avatar
    Nov 18 2011
    Woodside, NY
    Brace yourself #TD1 is coming lol
    But thatís awesome news. Subscribed
    2016 S6, Prestige, Mythos Black w/ black int, Sport Package, Black optics
    2014 A6 - SOLD
    2012 S4 - SOLD
    Apr 23 2017
    PA
    Heard a rumor MTM was in the MG1 ECU as well but wasn't able to find any info on it. From the n54 link it appears they are able to keep the dealer ID and original programming ID which sounds promising for those concerned about being flagged for TD1. Can't wait to see what the S4 can put out with a proper tune.
    Found this video on the Femto OBD Flasher: https://www.youtube.com/watch?v=f2_Rzurc1Dc
    Jun 07 2016
    Europe
    Quote Originally Posted by dave329 View Post
    Where are you living, on the moon? Epl offers flash @home tuning, no TD1 if you flash back to stock before going to the dealer.
    Established Member Two Rings Nez136's Avatar
    Mar 21 2011
    Milwaukee, WI
    Quote Originally Posted by Logtec View Post
    If they dig they will find it. Just depends if itís a regular service/recall or if itís a big repair.
    '11 S4
    '05 Evo 2.3 HTA35r
    Active Member Two Rings Yabi's Avatar
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Awesome news, thanks for sharing!
    Jun 07 2016
    Europe
    Quote Originally Posted by Nez136 View Post
    No they won't, I even had my gearbox repairs all done under warranty.
    Mar 21 2011
    NJ/NYC
    If everyone waits a few weeks for bootmod or one of the big vendors to come out with the tuning solution the TD1 doesn't get flagged in the ECU.
    Its the same as if you guys had an APR emcs tune in your car in the past..... if you flashed back to stock its imperceptible.
    Bootmod saves a complete copy of your stock map, and runs the flashed map. When you go into service if you flash the car all the way back to stock (your copied stock map) the car will not show anything was done at all. There's tons of info about it online. The new style M3 and M4 have been running this type of flash for a few years now. When you go back to the stock map even if you have engine damage, the car just shows it was trying to meet the target boost the DME was calling for, thats what took so long for them to crack in this ECU..... because when they lowered the target numbers and the car went to make more boost to meet the new target (higher boost but stock to the DME) , the new DME would lean the car out instead of richen it, or back the boost or timing or both off until the target came back up. Tough to explain.... BUT NO TD1 definitely.
    Mar 21 2011
    Milwaukee, WI
    So you guys are saying that there would be no logs that would throw a red flag that can be seen if they dig deep enough? Even after thousands if not 10s of thousands of miles driven with a modified DME?
    '11 S4
    '05 Evo 2.3 HTA35r
    Mar 21 2011
    Milwaukee, WI
    Which car and what tune did you have ? Thatís pretty awesome news
    '11 S4
    '05 Evo 2.3 HTA35r
    Nov 18 2011
    Woodside, NY
    Lol ok buddy. Thereís plenty of ways Audi now can tell if cars were flashed. Even when flashed back to stock EPL, APR, or the likes... trust me. Not my first rodeo.
    Plus the TD1 comment was meant as a joke... the B8 board blew up with those topics /threads. Now with this platform nearing with an actual ecu tune Iím excited honestly. Just like anything else you gotta pay to play. Nothing has changed.
    2014 A6 - SOLD
    2012 S4 - SOLD
    Nov 18 2011
    Woodside, NY
    Iíve had my gearbox repaired as well. It was depends on dealership and tech. After the dealer fixed the car they (AoA) wanted to run a spec actual scan on the car. These cars have black boxes too. They record the boost levels, and all that stuff. Like the previous person said if they want to dig into it they can find it. Audi can now tell if cars were flashed by drive assistance system now as well.
    2014 A6 - SOLD
    2012 S4 - SOLD
    Apr 23 2017
    PA
    Features that may make it a little harder to detect a tune.
    Benefits
    FEMTO calculates all checksums inside FLASH (also known as CS)
    CVN and CALID will be automatically corrected to match stock
    Dealer program ID number remains the same as original
    Date of programming will not be changed
    Mar 21 2011
    NJ/NYC
    More info guys:
    Officially released on the BMW 340 and 330. It also states that it will not throw the TD1 code and is UNDETECTABLE as the DME is fooled into being frozen in time.... it doesn't log or store information when it's flashed onto the new program, when you flash it back to virtual stock, it begins to work as it does from the factory..... if you read the article here, it explains it in better language then I can:
    https://f30.bimmerpost.com/forums/sh....php?t=1516067
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Quote Originally Posted by OverBoosted View Post
    Benefits
    Until the OEM catches on, reflash ECU and locks it out again. I say keep quiet/don't advertise the intricacy of the hack and they will never know..
    2014 S4, Audi Exclusive DRM, 6MT, 034 Stage 2+ E40, DP (3.362), AMS Cooler, Autotech HPFP, ADV. wheels, CR-15, Deval CF, JHM LWFW/3R, Eurocode, KW V3, ST6 BBK, USP SS clutch line, XPEL full wrap.
    Gone: 2012 S4 Brilliant Black, Prestige, S-tragic.
    Senior Member Four Rings Loe's Avatar
    Aug 09 2015
    '14 Audi S5, '18 BMW 540i
    Sarasota, FL
    jeez, if this is accurate, this is amazing!
    -Loe- ('14 Audi S5 S-tronic )
    [10.930@127.38mph | +1209 ft. D/A | 3.371 PR]
    Technical discussions? JOIN ME!
    Veteran Member Four Rings b6onboost's Avatar
    Jan 10 2007
    VA
    Just a game of cat and mouse. Possibly undetectable "for now".
    Established Member Two Rings BrockDM's Avatar
    Jan 21 2018
    Frankfort, IL
    Quote Originally Posted by Loe View Post
    My exact thought! Hopefully a definite answer arises
    Jun 06 2018
    Alpharetta, Georgia
    just curious, will they be able to "patch" the ECU in the future so they can detect the tune? i wonder if that has ever happened before
    Established Member Two Rings samwisemueller's Avatar
    Nov 12 2007
    '18 S4, '18 Tiguan
    Alexandria, VA
    Sub'd, here is a dutch company that has cracked DME on BMWs that I found going down the rabbit hole on a few sites. They are showing pretty serious gains. Not clear if this is a target or if they have already tuned to 440hp/~457tq. Pretty exciting potential!
    https://www.br-performance.be/nl-be/...1-s4-3-0-tfsi/
    Mar 21 2011
    NJ/NYC
    A few companies already selling the flashes.
    It's only a matter of time before Audi tuners announce something...... would be great timing with waterfest being this weekend. :D
    Established Member Three Rings PeteRock's Avatar
    Mar 08 2017
    Chicago
    Same ECU on the new RS5 as well correct?
    Pete
    Established Member Two Rings GTburn's Avatar
    Jul 09 2017
    18' Ford Explore (wifes)
    ft Lauderdale
    Quote Originally Posted by PeteRock View Post
    Pete
    Sure is.
    AKA: gt5tang
    Mar 08 2017
    Chicago
    Quote Originally Posted by GTburn View Post
    Sure is.
    Damn....might be a good time to order up a new RS5 :)
    Pete
    Jun 07 2016
    Europe
    Cant wait to tune this b9, its so slow @the moment!
