Results 1 to 7 of 7
    Apr 17 2018
    Rochester
    Bracket for Macan Calipers on 375x36 Rotors Group buy.
    Hey Everyone,
    I was looking into big brake kits and I didn't find any solutions that I liked besides the Macan turbo setup. But I want a bigger rotor, I don't plan on running 18's on my S5.
    So I found this company that makes custom brake brackets and a bunch of other stuff. They already released brackets for the Audi S2 which uses a Macan Turbo caliper paired with a Brembo 375x36 disc.
    https://www.akmotorsport.net/shop/al...or-audi-s2-b4/
    I contacted them and they mentioned that they could make this kit for the the B8 S4/S5. But there's a min of 5 orders. I'm assuming the brackets would cost about $180-250.
    Parts list
    * I'm not sure if the calipers come with the sping clips, bleeder valve and/or brake tubes/transfer hoses.
    Left caliper $335
    95B-615-123-E
    https://www.sonnenporscheoemparts.co...Y2LWdhcw%3D%3D
    Right Caliper $335
    95B-615-124-E
    OEM Pads $238
    971-698-151-E
    https://www.sonnenporscheoemparts.co...bC12Ni1nYXM%3D
    Brembo 09.A960.21 $86-120 (Check amazon!)
    275x36
    This rotor is from a Mercedes. Has 5x112 bolt pattern but the hub may be 0.1mm smaller.
    32-33 pounds.
    So if you're in, just let me know!
    Other pads that may fit.
    EBC Yellow DP41835R
    Hawk Performance PC HB720Z.575
    Hawk Performance HPS5 HB720B.575
    StopTech Street 308.16630
    TRW TPC1349
    Ferodo FDB4064
    Raybestos SP1349EU
    Raybestos PGD1577M
    Apr 17 2018
    Rochester
    Here are my other OEM BBK options.
    Macan Turbo - 6pot Brembos with 360x36 rotors
    I'm seriously considering this! Nice vented rotor design.
    Labor labor labor! Steering knuckle needs to be swapped out, and the additional parts can get expensive as I would like to replace everything (Wheel bearing, ball joints, bolts, etc.). #OCD
    Pros
    - Directional vented rotors.
    - Affordable rotors and calipers!
    - Clears some 18" wheels.
    - Decent pad selection since this caliper can be found on the Panamera and I think the Cayenne.
    Cons
    - Needs the Macan turbo steering knuckle (Part is cheap, requires labor).
    - Rotor selection is very limited.
    - Rotor is all steel, and can be heavy.
    RS5/R8 - 8pot Brembo with 365x34 rotors
    Love the rotors, but I hate the caliper.
    Pros
    - Direct fit!
    - Great pad selection.
    - Light weight rotors (23-24 pounds).
    Cons
    - 8pot is a over kill.
    - Heavy (15 pounds)
    - Caliper is ugly and outdated.
    RS7 - 6pot Brembos with 390x36 rotors
    I love this kit, but replacement parts are expensive.
    Won't clear some 19's, I want to get the TE37 Ultra in 19's and the fitment is unknown. These wheels Won't clear BMW M4 400mm ceramic brakes.
    Pros
    - Direct fit & beautiful.
    Cons
    - Rotors and calipers are $$$!
    - Rotors are huge and heavy (32 pounds).
    - Needs 20" wheels, some 19's may fit.
    Q5/Macan base 4pot Brembos with Stock 345 rotors
    Very basic.. I want a bigger rotors.
    Pros
    - Direct fit!
    - Cheap!
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    you have peaked my interest.....
    i put S5 345's on my A5, but i run 20's & have lots of room to spare...
    .... let me do some research......
    Bill
    2011 A5 2.0T Old Man Project
    1983 Porsche 944 (Modified)
    1971 Moto Guzzi Elderodo
    Avatar Chart
    Apr 17 2018
    Rochester
    Quote Originally Posted by wkhanna View Post
    Awesome!
    Yeah the 345 looks tiny on my RS5 20's.
    Have you seen the brakes on the new B9 S4/S5/RS5? The 6 Pot Akebono calipers. They look cleaner/mono-block, lighter, pre-painted(red/black) with the S badge. They're a tad bit more expensive.
    I'm still doing some research on the performance and reliability. The G37 and 370 Use Akebono calipers and I've seen no complaints so far.
    Senior Member Two Rings Marlon177's Avatar
    Nov 04 2010
    2016 CLA250 4Matic
    How about the B9 S4 6 pot caliper?
    Apr 17 2018
    Rochester
    Quote Originally Posted by Marlon177 View Post
    I'm thinking about changing the specs of this project to use that caliper. It already comes painted red or black with the S badge on it.
    It's a tad bit more expansive but if it preforms the same and it's lighter. Then I would love to consider it.
    The rotor options that I would consider is
    Maccan turbo 360x36 rotor
    $150 per side
    30 pounds?
    Can fit some 18's wheels.
    B9 RS5 375x36
    $550 side a
    29 pounds (I think)
    May fit a few 18's but 19's would be a safer bet.
    Would you be interested?
    Senior Member Three Rings IllusionalTA's Avatar
    Aug 16 2009
    06 A4 2.0T Sline M6
    Long island ny
    I'd be interested in doing something like this, just can't see spending 6 bills on a rotor since, I daily my junkbox.. but def would love a better brake option..
    Steve
    13 S4 Dsg
    Roc Euro Cai,034 Stage 2 EFawty!
    95 Firebird
    408ci Turbo LSx, 1100whp
