Results 1 to 2 of 2
Thread: HPS rear pads
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 USP, 68 Camaro, 00 Cavalier
    HPS rear pads
    Brand new pads. I bought these a while back, and since upgraded to S4 brakes. I mistaking tried to install them on my girls b6 so one set had brake lubricant added to the backside. $50 shipped to the CON US.20180712_165830.jpeg20180712_165818.jpeg
    Sent from my SM-G930V using Audizine mobile app
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L
    Before camber and tire stretch, there was horsepower and performance.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    HPS rear pads
    Andrew, these should work on B6 also?
    2005 1.8T Quattro
    GTRS Eliminator Turbo / Motoza BT 1000cc injector tune / IE intake manifold / TT225 MAF w/ 42DD TT225/Carbonio CF intake / BB Stealth cat-back exhaust w/ ATP 3" test pipe / APR cast DV / CTS Turbo FMIC / JHM short shifter + linkages / 034 street density motor/trans mounts, upper(adjustable) & lower control arms / Bilstein PSS9 coilovers / S4 H&R front / S4 Hotchkis rear sway bars w/ 034 end links
