Results 1 to 8 of 8
    Senior Member Two Rings BrillBlackb5S4's Avatar
    Sep 10 2015
    Rhode island
    2001.5 Audi s4 Stage 3 10k obo
    Parting out if if doesnít sell soon.
    9k firm
    Just hit 102k miles
    sorted stage 3
    tons of maintenance done
    Car drives great
    The car needs a few minor things nothing major I currently daily drive it. I know everything that has been done to this car and what hasnít.
    I bought this car September 2015 from a Mini Cooper dealership in New Hampshire with 72.9k miles on it completely stock no mods at all. I was told an old man owned it and traded it in. Everything that is changed I have done.
    102,xxx miles 15k miles on build.
    Mods:
    Et spec/blake beadle stage 3 tune 23psi hold
    3 bar map sensor
    Bw k04s rebuilt new CHRA's
    SRM rs4 v3 intercoolers
    APR Bipipe
    bosch 550cc ev14 fuel injectors
    710n diverter valves
    Walbro 450 e85 pump
    034 85mm maf housing + accordion hose
    034 inlets with lobster claws
    034 motor/trans/snub street density
    * JHM rebuilt transmission full kit
    Cine snow upgraded wastegate lines
    034 spider hose with bilet check valve
    Vogtland Coilovers rust free shock mounts
    Milltek dual exhaust catback (very quiet exhaust until you get on it) with SSAC race catted midpipes and 3-2.5inch catless downpipes
    AWE boost gauge with ECS vent holder
    NGK C5 Rs6 spark plugs 98k miles
    C5 Rs6 coil conversion kit ICM delete 98k -- best kit keeps bolt down style plugs unlike fsi coil kit which is push down not water tight
    Maintence:
    Rs4 clutch and resurfaced flywheel 75k
    egt sensors replaced with new 75k
    tires continental extreme contact dws06 87k
    Full Jhm kit rebuilt transmission 87k
    Diff fluid changed with Motul at 75k miles
    Transmission fluid done twice: Oem fluid at 75k and fuchs sinto fluid at 87k
    Brakes all around + rear ecs stainless lines 85k
    New Oem N75 85k
    all front control arms 034 + inner and outer tierods 85k
    check valves replaced
    ECS ultimate timing belt kit at 75k miles in december of 2015 (includes waterpump thermostat ect)
    Replaced plastic thermostat housing with oem aluminum one 75k
    02 sensors front 91k
    new alternator/starter/battery 87k
    Oem accessory belt tensioner 87k
    oem oil/coolant hoses 87k
    coolant temp sensor 87k
    valve cover gasket full kit 87k
    New Bosch aux water pump with new hoses 87k
    coolant pipe o rings 87k
    rear wheel bearings 90k
    rear control arms replace with better used 90k
    steel uprights bushings replaced 90k
    91k miles front oem axels sent to raxels to be rebuilt 650$ + your oem cores
    Alignment 91k
    Rear caliper replaced with like new 98k
    102k oil change
    Sep 10 2015
    Rhode island
    now 9000$ firm if I donít get that it will be parted out. Priced to sell.
    Veteran Member Three Rings rage385's Avatar
    Sep 06 2012
    2001.5 Audi S4, 2009 Daytona 675
    United States
    Items for Sale
    sir, I attempted to reply to your message, but your inbox is full.
    Active Member Two Rings billbB7's Avatar
    Apr 16 2014
    B5 S4
    MA
    Good deal at that price. Would be all over this if I was looking for a 2nd B5. GLWS
    Jul 24 2014
    PA
    Smoking deal if pick this bitch up if I was looking for a car
    Sep 10 2015
    Rhode island
    Ok sorry I should be able to receive pmís now I guess my sent box was fill not my inbox.
    Sep 10 2015
    Rhode island
    bump
    Aug 31 2010
    willoughby oh
    If you decide to part it out Iím interested in couple items
