Results 1 to 24 of 24
    Jul 09 2018
    Slovenia
    2.0tfsi turbo whiseling from 1100 to 2000rpm
    Hi,
    I Have changed my turbo for new one from Borgwarner. After instalation I noticed that turbo is whiseling or something around it.
    It can be heard only when driving, when you pump the gas standing still it cant be heard.
    When driving up from 2000rpm,there is no wierd sound and it pulls up normaly.
    What could that be?
    Thx
    Nov 23 2009
    NYC, US
    Quote Originally Posted by Primzy69 View Post
    Hi,
    What could that be?
    Thx
    You said your new turbo is from BorgWarner? Is it a K04? Do you have a sound clip?
    Jul 09 2018
    Slovenia
    No, it is k03, like original...
    It is a bit louder than on video. It can be heard also when you push on the gas fast, it feels like that sound comes when trubo is starting to spin.
    https://youtu.be/V3L9BmJrxE8
    Best heard at 23s
    Jul 09 2018
    Slovenia
    Is it possible that this problem is connected with second air pump, because when the car is cold, you can hear growling/grinding sound for less then a minute? It comes from air filter location?
    thank you for your answer!
    Jul 09 2018
    Slovenia
    https://youtu.be/BXGqVUwlZXA
    Here is a video od whining. It is a cold start, but it happens when Hot as well.
    Any ideja?
    Pleas help!
    Turbo and pcv valve are New.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Toronto, Ontario. Canada
    May not be able to hear it properly but that sounds like it's just spooling up as it should.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Jul 09 2018
    Slovenia
    Turbo doesn't spin untill 2000 its not variable turbine...
    As well I have listened to my friends car, same engine, no strange sound...
    Jul 09 2018
    Slovenia
    Pleas, can somebody help me what else can i check.
    Here is a new video:
    https://www.youtube.com/watch?v=a6CanxPx9T4
    Video was taken early in the morning, engine was cold.
    Also there is a rumbling noise from air box, like metal sound, especialy when cold.
    Feb 15 2016
    Cambridge Ontario
    Sorry I cant help as I still have to replace mine.. could turbo be just bad or noisy ?
    did you use a DIY to replace it of just start unbolting stuff till it fell out ?
    2014 A4 2.0TQ Technik
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 09 2018
    Slovenia
    I used a DIY method with a mechanic.
    Seller says that turbo cant be bad, because if it is, there should be whiseling in higher rpms as well.
    Feb 15 2016
    Cambridge Ontario
    if you have Links to a DIY I would appreciate it , thanks
    strange that it would only happen with install of new turbo. I guess I would look closely at other stuff that was removed.
    2006 A4 2.0TQ 6spd
    1976 Yamaha XS 360
    Jul 09 2018
    Slovenia
    Actualy I used online etka, to se where the bols are, those exploded views are quite good...
    I am wondering if it is possible that sound is comming from exhaust or catalysator.
    Feb 15 2016
    Cambridge Ontario
    I'm not sure how unless something was left loose and as it heats and expands it does not make noise..
    2006 A4 2.0TQ 6spd
    1976 Yamaha XS 360
    Jul 09 2018
    Slovenia
    I noticed that exhaust is pretty black inside. Maf shows only 2.2-2.4 g/s at idle (780rpm).
    Boost max 23psi
    Dec 03 2016
    nowhere
    An aftermarket k03 or an actual borgwarner k03, there's a difference.
    Reminds me of an out of balanced turbo.
    Also, who did the install?
    HEAR
    Established Member Three Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Is it tuned? 23 psi boost isn't stock.
    2011 A4 Avant Prestige S-Line
    Nov 20 2016
    That is a bit unusual sounding, but I have gotten all sorts of sounds from the stock turbo. My airbox rumbles, there are low pitched whistles when driving through tunnels or past buildings or other cars and its been fine for 50k miles now. How are you reading your max boost pressure? Through a datalog or through a boost gauge?
    Active Member Three Rings
    Jun 17 2018
    Colorado
    Random idea: could this be the PCV with a little tear making the noise only under vacuum? Once the vacuum goes away (i.e. the turbo is on), the whining stops.
    Nov 20 2016
    Quote Originally Posted by blgilles View Post
    Entirely possible.
    Jul 09 2018
    Slovenia
    I think this is normal boost. That is absolute pressure (boost + atmospheric pressure)
    Jul 09 2018
    Slovenia
    Same here. My airbox rumbles as well. Every time I start moving, there is this low whiseling sound and rumbling noise from airbox.
    If you disconnect hose from airbox and if you put your ear next to it, you can hear the engine running (this pap pap pap pap pap pap pap sound).
    I meassure boost with a boost gauge on Torque and Vag-com.
    - - - Updated - - -
    Quote Originally Posted by flowhigh View Post
    It is a Borgwarners k03. What is the difference?
    Turbo was installed by my mechanic, and than again by seller of the turbo...
    Out-balanced turbo? Is it possible that it balances it self when spinning fast?
    Jul 09 2018
    Slovenia
    Entirely possible.
    PCV is new. It is not original, but I think that should not be a problem...
    Jul 09 2018
    Slovenia
    There is a new symptome, i hope it is connected with original problem.
    There is a very quiet noise (like hissing or an AC vent.), but it does not change with rpms. It stops as soon as i touch the brake. It can be heard only in the cabin and while driving or standing still.
    Is it possible that because of a vacuum leak in the brake booster i am having other problems as well?
    Dec 03 2016
    nowhere
    There are Chinese made aftermarket K03 turbos.
    No. However if infact it is a new Borgwarner turbo I doubt it would be out of balance, but anything is possible.
    HEAR
