Results 1 to 20 of 20
    Feb 09 2013
    CNY
    B7 S4/RS4 Exhaust Hangers
    Looking for the updated exhaust hangers from the B7 S4/RS4. Part is updated to prevent sag of the rubber hanger portion that happens with the older revision part.
    8E0253144AS and 8E0253144AT are the P/N's.
    I know it's a long shot, but shoot me a PM if you've got a set kicking around. Thanks!
    Senior Member Two Rings PigDiesel54's Avatar
    Jan 18 2013
    Might have better luck posting this in the B6/B7 S4/RS4 classifieds.
    2006 Brilliant Red B7 S4 Avant 6MT
    2001 Cactus Green B5 S4 Avant 6MT
    2006 Brilliant Red B7 A4 2.0T Quattro Tiptronic
    Senior Member Two Rings lostInTheSmoke's Avatar
    Aug 06 2015
    Minnesota
    I think I got a set of them in my garage.
    Feb 09 2013
    CNY
    Quote Originally Posted by lostInTheSmoke View Post
    Shoot me a PM if you find them.
    Quote Originally Posted by PigDiesel54 View Post
    Yeah, figured I'd post here first. Good idea, though.
    Feb 09 2013
    CNY
    bump
    Feb 09 2013
    CNY
    bump
    Feb 09 2013
    CNY
    bump
    Feb 09 2013
    CNY
    Bump
    Feb 09 2013
    CNY
    bump
    Feb 09 2013
    CNY
    bump
    Feb 09 2013
    CNY
    bump
    Feb 09 2013
    CNY
    bump
    Jul 14 2009
    Pasadena
    GTX2867r Audi A4 B6 TQM RECARO|HRE|ER|IE|APR|AWE|034 Build page here
    Daily Driven Audi Q3 Neuspeed|HRE|REMUS|KW Build page here
    IG: @matthewee
    Feb 09 2013
    CNY
    Quote Originally Posted by itsmatt33 View Post
    new 65 each
    ebay used36 each + ebay has 15% off all today PRONTO15
    That’s an option. Thanks for the heads up.
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Why not just buy new rubber pieces? I did and it fixed mine for like $15 total.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Feb 09 2013
    CNY
    Quote Originally Posted by evo_ski View Post
    I picked up a pair of ANSA hangers from RockAuto but haven’t gotten them yet. Figured I’d keep looking for the RS4 ones in case they didn’t work
    Mar 05 2013
    CA
    Not sure what ANSA means.
    Don't these also come on B7 A4's?
    I don't get why spend more on whole hangar units, vs. just buying updated rubber pieces for less, and sliding them on.
    Feb 09 2013
    CNY
    Quote Originally Posted by Spike00513 View Post
    ANSA is just a brand that makes exhaust components. Gosser mentioned them in my other wanted thread in the S4 section.
    Idk if they’re the same as B7 A4 hangers, but if you’re buying OEM, I believe the bracket and the hanger are all one part number/assembly.
    Feb 09 2013
    CNY
    Still looking. Tried the ANSA hangers and it actually had more sag than the original hangers... don't really feel like buying another just to have the same problem again. Rather just get the RS4/updated hangers...
    Feb 09 2013
    CNY
    bump
