Results 1 to 2 of 2
    Active Member Two Rings Uconoob's Avatar
    Dec 18 2016
    Norway
    Will A6/a7 c7 brakes fit on a4/s4 b8.5?
    Hey, as you can see per title, will a6/7 brake calipers/rotors fit the a/s4 b8.5? Specifically the bitdi performance brakes? The ones in the picture. And does anyone know the measurements of these brakes?
    Sent fra min ONEPLUS A6003 via Tapatalk
    Eyyy
    Established Member Three Rings scmtkings4's Avatar
    Oct 06 2016
    Brooklyn, NY
    Yes these will fit the s4. I'm not sure what you mean by size but the rotors for these are 356mm (about 14 inches).
    You'll need to make sure the carriers are included in order to bolt up to your s4.
    Sent from my BBB100-1 using Tapatalk
    2014 S5
    AWE Touring Exhaust l ECS Intake l EPL Dual Pulley 93 l AMS Alpha Cooler
