Results 1 to 14 of 14
    Veteran Member Three Rings nistah's Avatar
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Audi C5 RS6 Aftermarket wheel fitment question
    Previously on my RS6 I've run OEM S4 Peelers with 43MM offset which required spacers and 57.1MM-66.56MM hub bore adapters, switched the peelers out and now run OEM RS4 wheels which are 29 ET offset no spacers needed with the RS4 OEM wheels. I am looking at running a new set of really nice set of staggered HRE P43 wheels that are 19x9 ET24 front and 19x9 ET19 rear? Is it possible & if yes do fenders need to be rolled? Thanks!
    Current: Black Pearl Metallic Effect/Ebony, Peelers, RNS-E, + pedals, oCarbon
    Past: Daytona Grey Pearl Effect/Silver ,Eurocharged ECU Tune, MTM TCU Tune, RNS-E, Michelin PS2's - SOLD
    Sep 16 2010
    Central Wash
    Once you get below about ET35 they almost always fit. Below ET30 I can't imagine *needing* spacers, even though you may want them. Adding a 10mm spacer to an ET30 wheel gives you low offset; but final good fitment and fender rolling depends a little on tires and stance too.
    Mar 08 2013
    I'm running 19X10 ET30 with 265/35/19 PSS and don't have an issue in the rear. Your new setup would be 1-2mm less poke, which seems like it would work, but that would also depend on tire size, tire profile, and suspension setup.
    https://www.willtheyfit.com/index.ph...h=9&offset2=19
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Thanks guys I have a set of 265/35/19 Michelin Pilot Super Sports and a set of 255/35/19 Conti DSW06 Extreme Contact that I could use with set of staggered HRE P43 wheels that are 19x9 ET24 front and 19x9 ET19 rear.
    Established Member Three Rings JorisRS6's Avatar
    Jun 06 2017
    2003 RS6
    Norwich Canada
    The et 19 will be very agressive. Im running et25 all around. Its possible i think.
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    I love these HRE wheels, really want to run them on my C5 RS6 can anyone on here advise if they will fit for sure? Also any insight as to the ride quality of running staggered setup would also be helpful.....
    https://www.ebay.com/itm/HRE-P43-19x...QAAOSwC-tZ8N3h
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Beatiful rims for sure. 99% sure they will fit. Im running et 25 square with 20x9 rims. Tommorow i will check my rs6 to see if you can go another 6 mm wider at the back.
    How low is your car and what tires are you going to run?
    That will make a difference too
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Quote Originally Posted by JorisRS6 View Post
    Thank you JorisRS6, I understand that square is the preferred setup for C5 RS6 but these wheels are destined for my RS6. The beast is currently running stock DRC and tire options are
    A: 255/35/19 Conti DSW 06 Extreme contact or
    B: Michelin Pilot Super Sport 265/35/19
    Car is currently running OEM RS4 wheels, in the past I had run peelers which required spacers and hub bore centric adapters, however the ride is better with flush mount OEM RS4 wheels
    Jun 06 2017
    2003 RS6
    Norwich Canada
    They will fit. Front and back will be perfect. 6 mm in the back more than me is no problem at all. Especially when you are stock ride height.
    Also, i would personally go with the michelin tires. 265 will cover the edges of the rims a little better.
    Good luck!
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Thanks JorisRS6 they fit my RS6 great!
    Purchased from GTtechnik in Los Angeles they are HRE wheels P43SC model in naked silver 19X9 Staggered offset ET24 up front & ET19 in rear with 66.6->57.1 hub centric adapter rings, no spacers.
    Tires are Michelin Pilot Sport 265/35/19 square. No rubbing.
    Pics here: https://www.instagram.com/p/BpvVDLIB...2zu0-RnMdpZU0/
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Post some pics!! Your ig is private
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Ah OK did not realize my IG was not public....having a tough time uploading to AZ however try this link:https://nistah.imgur.com/all/
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Doesnt work either. I requested your ig
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Added you, nice RS6 pics BTW!
