Originally posted by belinko
Jeremy,
I'd be looking to get an S4 (B5 or B6), I wouldn't want to drop that much money into a 450hp A4.
What would be the need for the new rear diff.?
My current pedal setup doesn't allow me to heel and toe very well (accelerator is 1.5" lower than the break pedal). Any good tips help?
Oh, gotcha.
If you want that much power, get a B5. IMHO, it is the best Audi chassis for comfort and power.
Here's a good client testimonial to offer you some insight;
"Jeremy helped me out when I decided to get the differentials installed. So, I'd be happy to give you my impressions of the differentials. First of all, you'll realize that your car will not feel the same ever again. You'll realize that the original open diff set up gives you a bad understeer. I autox and also do track days so my experience will be more on the racing application of the diffs. When I used to drive through slaloms without the diffs, I'd have to throttle-lift oversteer to get around corners. In quick transitions, the weight transfer and the inside rear wheel lifting would give you a throttle response delay. The quattro system would try to send the power to the front and the rear wheels which felt like they lost power. There's a lag when the power is being transferred. In this power lag, the rears would drop by down and the quattro would send the power to the rear again. This added to lost time in power delivery. With the rear LSD, quattro feels like it always keeps the power to the rear when there's traction issues. So, in essence, you're always on power. The difference after the rear LSD and center diff was that I just went flat out through slalom sections. The car just hooked up and I drove quicker. The transition issues didn't give any time loss. Also, you get power-on oversteer. I've used this as an advantage also to get around corners faster. You'll enter the corner fast and then turn-in, but pinch the apex, and power out. The rear will step out and you can hold a drift. It's not a proper way to enter a corner but it's more like doing tarmac rally, WRC style. As for putting the power down, it's well worth it. Just think about the time saved in corner work when you can keep the throttle pegged. I used to enter a corner, lift in the apex (to initiate rotation), and power out. Now, I just progressively get on the power at turn in until I'm WOT past the apex.
The diffs is something that I'd personally recommend. Just keep in mind that the car will not feel the same. It'll feel like a RWD car. So when you do decide to get them, you'll just have to drive slower in the rain. I'm glad you're not in my autox region because an S4 with diffs would drive my doors off. I hope this helps. STaSIS products are definitely worth every penny.
-Noel
2000 A4 1.8TQ
APR Stage III
STaSIS Motorsports (800F/900R)
CPP front upper control arms / tie rods / sway bar end links
STaSIS center and rear LSD
STaSIS Tracksport BBK"
