Results 1 to 18 of 18
    Senior Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    Cabriolet head lights...what aftermarket ones you got?
    Trying to find a decent set of aftermarket S4 cab headlights. What headlights you guys running, how do you like Ďem and share pics if you can.
    Mine arenít terrible, but a lil cloudy. Iíve tried the repair kit and that helps a little, but looking to freshen up the look a bit
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Cloudy as in condensation? Cause their is some DIY regarding the o ring size. Iím not a fan of aftermarket headlights that are offered whether itís a b6 or b7
    Oct 11 2015
    Atlanta, Georgia
    B6...not condensation but just some discoloration Image1531481962.754114.jpg
    Senior Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    Oregon
    Why not just buy new lenses?
    Sent from my SM-N920V using Tapatalk
    1997 VW GTI VR6 (sold), 2003 Audi RS6 (sold), 2010 Audi A4 2.0T (RIP Totaled on 11/2/2015 ) 2005.5 Audi S4
    My build log
    Texpoops "Correct, but a half inch difference isnít going to accelerate wear by much. Iím sure the front dips that much with a fatty in the front"
    Nov 03 2011
    B6 Avant 420-R, Toyota Runx 1.4 16V
    Manitoba, Canada.
    Quote Originally Posted by VinnysS4 View Post
    If replacement lenses are available for these headlamps, itís news to me. Arenít the polycarbonate lenses bonded to the housings??
    2003 B6 Audi A4 Avant Quattro Sport | 3.0 V6 | 6MT | Denim Blue Pearl | B6 S4 ďBlack OptikĒ Grille | Votex Kit | Black Leather - Part Out.
    2012 B7 Seat Exeo ST Sport Tech | 2.0 TDI 170 | 6MT | Phantom Black Pearl | LED DRLís | Bi-Xenons | AFS | LED Tails | LED RNS-E | AUX / iPod Input | Black Leather | Multi-Function Steering Wheel | Rear PDC.
    2002 Toyota Runx |1.4L DOHC 16V Auto.
    Nov 12 2015
    Oregon
    I guess I may have assumed they were available and swappable like other s4 lenses
    My build log
    Nov 03 2011
    Manitoba, Canada.
    S4 Sedan / Avant lenses are available and swappable? If they are, Iíd be interested in a set for a pair of B6 S4 headlamps I purchased last year.
    Nov 12 2015
    Oregon
    B7 are available, not b6. It was my fault for reading the first post and scrolling down to reply without reading the rest.
    That being said. Yes they are openable. B6 and b7. If it were me, and I wanted to retain the OEM housings, I would buy a cheap set of replacement headlights and swap the lenses between the two. Like these
    https://www.am-autoparts.com/Audi/Au...gaAr-aEALw_wcB
    And no I haven't done it on a B6, but I would be willing to do it.
    My build log
    Nov 03 2011
    Manitoba, Canada.
    Thatís an awesome idea, VinnysS4. Thatís what Iíll do, buy a cheap pair of brand new units and bake the lenses off.
    Nov 12 2015
    Oregon
    Or just use the cheap ones. OR,
    Get a cheap buffer, polishing compound, and spend a couple hours polishing the outsides. If it's the insides, bake em open, do the same inside and out. Just make sure to use a UV protecting clear coat to prevent them from yellowing.
    My build log
    Oct 11 2015
    Atlanta, Georgia
    Ok so a couple of things. The swappable lenses that you speak of is only for avants and sedans. The cabrio (I believe) has a diff lenses. Secondly Iíve bought a refresh kit and the picture above is as cleaned up as I can get it. So refresh kit is out. Swapable lense is out(I think)...what else you got? :)
    Nov 12 2015
    Oregon
    Then polish them properly with a buffer and ascending polishing compounds until they are crystal clear.
    Quote Originally Posted by Fourpoint282 View Post
    My build log
    May 01 2017
    Lincoln DE
    Problem with buffing and polishing is you are still removing the UV protection thats on the lights. What you should do is have a body shop sand them down with like 600-800 and put a few layers of clear coat on . Then youll have UV protection back on the lenses and they will be clear.
    2008 DTM RS4
    Instagram--@tjbradney
    Nov 03 2011
    Manitoba, Canada.
    Iíll rather buy a cheap new set, and swap the lenses.
    ďRefurbingĒ discolored lenses will get them looking good, but if the originals have clouded, refurbed lenses would have an even shorter life span.
    Oct 11 2015
    Atlanta, Georgia
    Iím confused about this ďswapping lensesĒ thing. I have a cabrio. I believe my lights are slightly different (could be wrong). How can I tell if my lenses are removable?
    Feb 17 2004
    Round Rock, TX
    you're not confused, they are =P. The lenses on the B6 headlights are notoriously difficult to remove, and there are pretty much zero aftermarket options for the cabriolet, so there's nothing to swap the lens covers from. If you don't want to shell out for new OEM housings (which are insanely priced), then a lightly used OEM set might be your best option
    WTB: B6 Ultrasport Avant 6-sp
    2007 RS4 Sprint/Ebony, Ti, 113k
    UM tuned/JHM/BC Racing/Milltek/oCarbon
    Nov 03 2011
    Manitoba, Canada.
    Is your Cabriolet B6 or B7?
    B7 headlamps are the same, through Avant, Cabriolet and Sedan. B6 Cabriolet headlamps are unique, different to Avant or Sedan.
    As for swapping lenses in either, I believe the process in any B6 in fairly involved, and involves baking the headlamps in a domestic oven for about 15 minutes on low heat (pre-heated oven). This is to soften the glue. This process involves removing the lenses from a non-Xenon pair to swap onto S4 items. Not worth doing on non-Xenon units.
    B7 lenses are commercially available as separate parts. Iím not sure if they are clipped on or bonded to the housings. If they are clipped, replacement will be easy. If they are bonded, the B6 method will have to be used.
    Oct 11 2015
    Atlanta, Georgia
    B6
