Results 1 to 16 of 16
    Jun 05 2017
    Indiana
    Need help diagnosing drivetrain (?) noise - 5-speed manual quattro 1.8T
    Okay folks, I need help diagnosing a noise coming from the front end (I think) in my 2003 A4 1.8T Quattro Avant with a 5-speed manual transmission. It is stock, except it has a South Bend stage 2 Daily clutch with dual mass flywheel, and has a K04 turbo with APR K04 tune and the larger injectors. The noise only recently became noticeable. I don't ever launch the car, but I do drive it with spirit.
    The noise is like a repetitive rubbing noise. What I mean is, it is like a "Nuh, nuh, nuh, nuh." It is NOT a constant whine. It is also NOT a sharp ticking noise. It is speed dependent, and increases in frequency with increasing vehicle speed. But the amplitude (loudness) is fairly constant. It becomes a little more noticeable around 40mph due to the increased frequency, and at around 60mph the frequency of the noise is about 4 times per second. It is very faint, and only really noticeable if you are listening for it or ride in the car for an extended period. But it is ALWAYS there.
    Also, the noise is present regardless of the gear or clutch position. It is the same whether you are in gear or coasting in neutral. Braking also does not affect the noise. It also does not change around turns. The car shifts perfectly and has no other drivetrain noises that I can tell.
    I took it to a shop that my friend owns, who does a lot of european work, but who is not necessarily an Audi expert. They drove it, then put it on a lift and ran the car while using a stethoscope. They said the noise is coming from "inside the transmission" and thought it may need a new transmission, but didn't take the diagnoses any further. They also seemed to rule out the brakes, wheel bearings, and CV drive axles (they said the brakes looked fine and the noise did not change around turns).
    I've read a bunch of threads here about transmission pinion gears, etc, and watched videos of different B6 5-speed noises. However, they all seem to describe noises that are more of a constant whine, not a repetitive noise like I have.
    Any thoughts? I'm really desperate to figure this out, and would be THRILLED if it is not an internal transmission problem!
    Jun 05 2017
    Indiana
    Forgot to mention the car has about 180K miles on it. I bought it with about 160k miles. The previous owner was a tech at a VW dealer and took fairly good care of it.
    Senior Member Four Rings q5 dave's Avatar
    Dec 15 2014
    driving
    Quote Originally Posted by bobA4 View Post
    It is speed dependent, and increases in frequency with increasing vehicle speed. But the amplitude (loudness) is fairly constant. It becomes a little more noticeable around 40mph due to the increased frequency, and at around 60mph....
    Also, the noise is present regardless of the gear or clutch position. It is the same whether you are in gear or coasting in neutral......
    Lol, I wouldn't trust this guy too much...
    It's the wheel bearings. Was dealing with the same concern on my B5 around 180k, replaced the rear wheel bearings (narrowed down where sound was coming from) and now it's smooth and quiet again. No humming.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    IG @q5ds
    Jun 05 2017
    Indiana
    q5 dave, was your wheel bearing noise a constant hum or was it a repeating noise (nuh, nuh, nuh, nuh) like mine?
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    i have the similar 'rubbing noise' but mine is only in 1st when accelerating and gone once I'm out of 1st. 2 Audi shops (friend & mechanic) have said it's the transmission. Mine is also a 5 speed and I'm at 162K.
    * GTRS Eliminator - 550cc Injectors - 034 HFC - Techtonics Tuning Downpipe - Neuspeed Exhaust - 034 TIP - Treadstone TR6 FMIC - Reisu Motorsports Custom Tune
    * H&R Sport Springs - Bilstein Sport Shocks - RS4 Rear Sway Bar - B7/B6 S4 Front & Rear Brakes
    * 18" VMR v710 (Currently On) & 18" OZ Ultraleggera
    Dec 15 2014
    driving
    Similar to this, becoming a constant hum over 55mph. I did rear wheel bearings, trans+diff fluid in one service. All good after that.
    IG @q5ds
    Jun 05 2017
    Indiana
    Thanks everyone. Anyone else with my same symptoms?
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    This does sound like a wheel bearing. When mine fully went out it started to do the same symptoms including a grinding noise every other second or so. Is it possible to get a video/audio of the noise?
    I would do the diagnostics on both front bearings. It's something along the lines of lifting the wheels off the ground, grab the wheel in the 3 and 9 o'clock positions and wiggle it to see if you have play, then the 12 and 6 o'clock. It doesn't always work though.
    Also, try spinning the wheel off of the ground and see if you get the same noise, or even take the wheel off and spin the bearing and see if there is any type of resistance to it spinning.
    Brilliant Red '04 A4 1.8T quattro Ultrasport
    Stage 2.5? | Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    DIY - A4 B6 Boost Leak Test
    Jun 05 2017
    Indiana
    Ok I will try that. The noise is so faint, Iím not sure it will be detectable over the road noise in a video. I will try later today. Thanks!
    Feb 24 2008
    A good way to really pin point if its a wheel bearing is while at speed (and when safe) turn the wheel side to side. If the noise gets louder when the car changes direction one way or the other you know for sure its a wheel bearing.
    With the wheels in the air on a lift/jack grab the wheel at 12 and 6 and try and wiggle it back and forth. Any amount of play would confirm a failed wheel bearing.
    Veteran Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Video??Or the noise doesnt exist!!!!
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    How old are the tires? Otherwise assuming pristine evenly worn tires.
    Jun 05 2017
    Indiana
    Tires seem to be in good shape, about 30k miles on them, regularly rotated. It has A6 wheels on it.
    Jun 05 2017
    Indiana
    Hereís a video clip. Becomes more apparent near the end. The entire video was taken while coasting in neutral in order to lessen the gearbox sound. The noise in question does not change whether in gear or not.
    https://www.dropbox.com/sh/4feauf8hq...cTACmHCFa?dl=0
    Jun 05 2017
    Indiana
    I tried some turns on the road to see if I could tell any differences. It does get a little bit louder when turning hard left at speed.
    Jun 05 2017
    Indiana
    Is the video link working for you guys?
