Results 1 to 35 of 35
    May 18 2016
    wyoming
    Stuck Intake valve.
    When cleaning out the carbon from my intake valves. I noticed one of the valves are not opening. I pulled the intake and cleaned the carbon because the intake flaps broke. Has anyone had this issue?
    Sent from my SM-G960U using Audizine mobile app
    Established Member Two Rings Dre_audi's Avatar
    Oct 24 2009
    tricycle
    toronto
    is this before or after you put it back together because its possible to slide the intake back on with the flaps out of position and then they wont move but if its the unit itself the the actuator could be broken inside
    May 18 2016
    wyoming
    Quote Originally Posted by Dre_audi View Post
    I'm installing a new manifold. The valve that's stuck is the intake valve in the cylinder head
    Sent from my SM-G960U using Tapatalk
    May 18 2016
    wyoming
    Top one not moveing.
    Oct 14 2017
    Erlanger, KY
    I would say that there is an issue with either the cam or a lifter. Both valve should be open the same. You should pull the valve cover and inspect the area for that valve.
    2008 Audi S4 Cabriolet (Alpaka Beige Metallic)
    2002 Chevrolet Corvette Z06 (Electron Blue)
    Senior Member Three Rings diabolical1's Avatar
    Mar 24 2009
    New York and Toronto
    Could be any one of a number of things. Definitely requires thorough inspection. How did you determine the closed one is the problem? Were you turning it by hand?
    Because S4 = Hooker
    - getslideways
    May 18 2016
    wyoming
    Quote Originally Posted by Spaceme1117 View Post
    Pulled the valve cover off
    Senior Member Two Rings Nizmo's Avatar
    Oct 09 2015
    08 S6, 06 A4
    Boston
    Quote Originally Posted by s4ugenfast View Post
    Damn, looks like the cam just ate it.
    My condolences.
    Oct 14 2017
    Erlanger, KY
    Damn that sucks. How many miles on the engine?
    From what I have read about the 5.2L V10 engine, this seems to be quite unusual.
    May 18 2016
    wyoming
    It's got just around 100k. I cant find any info where this happend to someone else so I'm guessing this is a rare instance. It looks like I'm going to need a new camshaft and rocker. I just wish I could figure out why that happend.
    Oct 09 2015
    08 S6, 06 A4
    Boston
    This is the V10?
    What oil are you using?
    May 18 2016
    wyoming
    Quote Originally Posted by Nizmo View Post
    This is the V10?
    Yes v10, I bought the car damaged like this. So not sure
    Oct 09 2015
    08 S6, 06 A4
    Boston
    0W-40 Synthetic if you fix it.
    Whats your plan?
    Stage 2 Banner Advertiser Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    Thatís interesting: it would be indeed best to find out the reason, did you check the compression/leak down of this, actually all cylinders? This can rule out a bent valve/tell you more about the engine health...
    Also is that a crack in the cylinder head between the 2 intake valves?
    Bestiale - incredible quality tuning and full service for Audi, Porsche, VW and Bentley backed with 101 year labor warranty
    8651 Washington blvd., Culver City, CA 90232
    562-448-2599, Grigor@bestiale.net, www.bestiale.net
    Oct 14 2017
    Erlanger, KY
    Quote Originally Posted by Grigor@Bestiale View Post
    I highly doubt it is a crack. I think it is just a casting seam left over when the engine block was cast. My S6 has the same seams there.
    May 18 2016
    wyoming
    Yeah it's casting.
    Jul 02 2018
    Lima oh
    Yeah it's casting.
    I would also be concerned about your other cam as well. I see a bit of scaring on there and looks like some scaring on the head as well. I will tell you this. I would look around for some loose hardware. I build engines for a living and if I was a gambling man, I would suspect that someone on the assembly line dropped a bolt, nut, something in the head during assembly. Weíve seen this kind of quality issue happen with with engines we build, although extremely rare, this is the type of damage that can occur. Or, just could of been a bad rocker, someone didnít set the tapets on the valve properly, or didnít adjust the valve clearance enough. Considering the V10 is not a widely used engine, I am sure Audiís assembly people may of just made a mistake from not building enough of that engine. But, sluth around. Loose bolts in the cam area cause lots of damage.
    Oct 14 2017
    Erlanger, KY
    Someone has definitely been in there before. If you look at the bottom picture, clearly someone had put a wrench or pliers on the lower cam. You can see the scar/marks from this. I would bet who ever was in there previously did not install things quite correctly.
    Oct 09 2015
    08 S6, 06 A4
    Boston
    Looks like residual damage from the rocker thrown around while the engine (was) running. Looks like it let go at idle.
    See what you mean though. Its possible was the OP or original owner/repair shop getting rockers out previously. The oil tho, synthetics tend to stick to walls and parts.
    May 18 2016
    wyoming
    It looks like the rocker caused that damage. That's where I found the rocker right under that camshaft. It looks like the previous owner might have drove with the car like that for awhile. When I did the carbon cleaning the valve with the missing rocker had a noticeable amount more carbon then the one working.
    May 18 2016
    wyoming
    It looks like I will need a new camshaft and rocker. Can I pull the rear cover on the head without pulling the engine? Like the 4.2s?
    Oct 09 2015
    08 S6, 06 A4
    Boston
    This is an absolutely fascinating thread and story.
    Check out this guys videos
    May 18 2016
    wyoming
    Awesome videos!
    Apr 03 2018
    If your engine code is BXA (if not send me the code/VIN) then according to Audi (from Erwin/ElsaWin) the engine/trans has to be removed.
    Even so it maybe possible to do it without, maybe ask the guy who made the video :-)
    Oct 14 2017
    Erlanger, KY
    It doesn't look like this is possible. There is not room to remove the rear cam covers. You also would need to remove the cam phasers and the timing chain and again it does not look like there is any room to do this.
    May 18 2016
    wyoming
    Yeah I started to pull the engine.
    Oct 09 2015
    08 S6, 06 A4
    Boston
    Best news all day, PICS!
    Feb 26 2017
    South Africa
    A local guy here in South Africa pulled the V10 from his S6. He made up a replica type scissor lift frame that Audi uses when they remove it. Here's the link to his thread about it: https://www.vwclub.co.za/forum/viewt...?f=11&t=194967
    Unfortunately the pics aren't working anymore, but the link to his youtube timelapse is there.
    He's fairly helpful on PM if you have any queries.
    Good luck!
    Oct 09 2015
    08 S6, 06 A4
    Boston
    Quote Originally Posted by mkv View Post
    Good luck!
    What Link?
    Feb 26 2017
    South Africa
    What Link?
    Sorry, the link was there but I by mistake deleted the text for the link. I updated the post.
    Oct 14 2017
    Erlanger, KY
    Please continue to provide pictures if you can. Thanks.
    May 18 2016
    wyoming
    Received a clynder head from the junk yard today. Going to swap the camshaft out of it when I get the motor out. Came with a valve cover, fuel injectors and some other extras.
    May 18 2016
    wyoming
    Some motor pull pics. I have my own lift in the garage. So my plan is to drop the engine trans and subframe onto jack stands and then lift the car off of it. I will do the work and the. Lower the car engine will sit back where it was.
    I bought the car with this issue non running . The body and interior are really nice with the exception of rock chips in the front bumper. Found it leaking bad looks like the oil filter housing seal. Tires are worn bad and will need upper and lower control arms.
    May 23 2016
    Edmond, OK
    that's great that you have the means to do this yourself dude! and thanks for sharing details as you go along. Certainly a good time to knock out ALL the stuff that leaks/ may leak soon since this will be the easiest time to get em done :-)
    Oct 09 2015
    08 S6, 06 A4
    Boston
    Appreciate the pics, keep em coming.
    What was the damage (price) wise for the single loaded head?
    You planning to keep or sell after the fix :)
