Results 1 to 10 of 10
    Apr 07 2015
    Toronto, Canada
    Disconnecting alarm siren
    Hi, I have a 2001, A4 1.8T (B5) sedan. I know you can't disconnect the alarm system, but can you disconnect just the siren? I've spent enough trying to fix the alarm randomly going off. Now I don't care if the alarm goes off, I just don't want to hear it. Thank you.
    Jun 08 2017
    london
    Itís probably going off due to movement sensors. Why donít you disconnect them?
    Apr 07 2015
    Toronto, Canada
    Not sure how to do that but I will look it up. Thank you.
    Jun 08 2017
    london
    On my A4 they are on the b pillar above the seat belt adjuster. Get a trim tool and pry the top down from the headliner. Donít use a screwdriver as you will break the plastic. You will see a little wire coming down from the sensor. Just pull that down and it disconnects.
    Established Member Two Rings turbo3's Avatar
    Oct 08 2012
    Central Florida
    Leaving the windows cracked ain't ya?
    Veteran Member Three Rings vrmm's Avatar
    Nov 14 2011
    NW
    For me it's always been in the trunk area. B5 it's above the disc changer and C5 Allroad it was below the rear passenger brake light. In the Allroad it would go off all the time too. I replaced all the door lock modules per vagcoms 'codes'. After resoldering their connections. Only thing I didn't replace was the trunk and it would randomly make noises like it was locking and unlocking while I was driving, but that wasn't very often. Anyways... In my b5 sedan like I said, siren is in the trunk. Not sure what the pillar stuff they're talking about. Your lights still go off. But they stop eventually and you'll never be they wiser.
    Feb 26 2016
    Cincinnati,OH.
    I believe that you can just turn off the motion detectors via a switch. Can't recall exactly where it is, (on one of the b pillars perhaps? Check owners manual.)
    Jun 08 2017
    london
    Yes thereís a button at the base of the drivers b pillar. Trouble is it resets every time you lock the doors again.
    Best way is to disconnect the movement sensors.
    Oct 08 2012
    Central Florida
    I'm not sure of removal but I think you can turn the sensitivity down or even off via vagcom
    Jun 08 2017
    london
    Yes you can turn it down to 50% but not off.
