Page 2 of 2 FirstFirst 12
Results 41 to 69 of 69
  1. #41
    Veteran Member Three Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Quote Originally Posted by csobel View Post
    Iíve only heard great things! I was going to get one but they were in between production cycles and so I opted for a used Lincoln square wave TIG. Your skills look awesome though... nice work
    The squarewave is an awesome entry level machine. I bought my AHP right when I graduated so I couldnít really afford anything else.
  2. #42
    Oct 27 2012
    Lamborfeetes
    Washington
    Sometimes I wish I would of just done a joe blow STK or k24 build lol. At least itís all down hill from here.
  3. #43
    May 09 2012
    Virginia
    Looks like a beast. You arenít worried with the amount of heat that will be up top from the exhaust? Assuming you mocked it up and it will clear the firewall?
  4. #44
    Oct 27 2012
    Lamborfeetes
    Washington
    I did test fit everything (hence why itís only tacked). Iím going to do my best at heat management but we shall see the results. Honestly it couldnít be worse than a STK since my turbos are in a better spot. Everything is getting DEI wrap.
  5. #45
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    In love with this build
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
  6. #46
    Feb 23 2010
    Lehigh Valley
    Very nice fab work. You think that clutch can handle the power though?
    B5 S4- K24s, built bottom end, E85
    B8 S4- GIAC Stage 2
    150cc Chinese Scooter of Doom
  7. #47
    Oct 27 2012
    Lamborfeetes
    Washington
    I think it will as long as Iím not doing tons of launches and no lift shift haha. I donít really do that anyways. If it doesnít hold Iíll swap over to a twin disk. I know that once the car is broken in that there will be things I want to change. The clutch setup might be one of them whether I like it or not.
  8. #48
    Aug 29 2017
    PWN
    Nice work man.
    So when is the Mike's B5 Auto Shop Grand opening?
  9. #49
    Oct 27 2012
    Lamborfeetes
    Washington
    Quote Originally Posted by SoundEfx View Post
    Nice work man.
    Ironically thatís always been a dream of mine. Iíve been overly fascinated with automotive performance my whole life.
  10. #50
    Aug 29 2017
    PWN
    Quote Originally Posted by mikeb17 View Post
    Then make it happen. You don't have to start big, but if this is the type and quality of work you can perform, it wouldn't be long before you are.
    Twin turbo set up that fits under the hood will be sought after if the heat doesn't melt anything.
  11. #51
    Oct 27 2012
    Lamborfeetes
    Washington
    I think one of the big reasons Iíve always been deterred from doing this kind of stuff is people donít really want to pay for what these kind of kits cost. This one was $700 for all of the fab stuff alone. Not to mention the time that goes into making a tubular top mount kit and the welding supplies. I would most likely start with a more popular and easier to fabricate kit like the STK. People are paying $800 for just an up pipe right now for an STK which kinda steep in my opinion.
  12. #52
    Aug 29 2017
    PWN
    I hear that.
    Sorry if it was mentioned before, but where are you located?
    Also, would you be interested in fabbing some stuff for me? I have no problem paying for quality.
  13. #53
    Oct 27 2012
    Lamborfeetes
    Washington
    I hear that.
    Iím located in Arlington Wa, what ya looking for?
  14. #54
    Aug 29 2017
    PWN
    Want to take this to PM? I think I've killed your build thread.... lol
  15. #55
    Senior Member Three Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    This thread isn't dead, it's just poorly documented. Didn't you read the title?
  16. #56
    Aug 29 2017
    PWN
    Quote Originally Posted by slowSfaux View Post
    I meant derail.
  17. #57
    Oct 27 2012
    Lamborfeetes
    Washington
    Was gonna finish welding this up this weekend but of course I ran out of gas to back purge with
  18. #58
    Feb 23 2010
    Lehigh Valley
    I thought the same thing about the 6 puck I put in when I went the built motor route. Had to come out a month later because it couldn't hold. It would just be a buzzkill to pull it back apart after all this work you've put in.
    B8 S4- GIAC Stage 2
  19. #59
    Oct 27 2012
    Lamborfeetes
    Washington
    Well maybe I should swap it now then :/ Iím not sure where your power levels are but I know Iím going to easily break 700 wheel on e85. Honestly if the block holds for a year Iíll be happy.
  20. #60
    Aug 29 2017
    PWN
    Nice work man. The orientation of the down pipes looks to be in point. The ones I bought doesn't even point straight back like yours.
  21. #61
    Oct 27 2012
    Lamborfeetes
    Washington
    Figured Iíd share some weld porn to you guys since itíll be covered by DEI as soon as itís finished
  22. #62
    Senior Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    Man, what a build! Best of luck to you sir!
  23. #63
    Oct 27 2012
    Lamborfeetes
    Washington
    One down, one to go. I have some flex joints on the way for the ends and then they will be done. Afterwards the engine goes in the car and I will be attempting the first start.
  24. #64
    Established Member Two Rings WEBER's Avatar
    Jul 01 2008
    Imola B5 S4 ,90 CQ 20vt KTM Superduke
    Portland, OR
    Hey check out this stuff from heatshield products, I think it would work well for your setup. We use a pretty similar product of turbine bleed air lines.
    https://www.heatshieldproducts.com/heatshield-armor
    2001.5 S4 Imola
  25. #65
    Oct 27 2012
    Lamborfeetes
    Washington
    Quote Originally Posted by WEBER View Post
    That actually looks pretty intriguing. Unfortunately I already have some DEI sitting in my garage. I may get it coated as well (I have a friend who does ceramic coating and other thermal management coatings).
  26. #66
    Oct 27 2012
    Lamborfeetes
    Washington
    Some other exciting news is that I have my first customer. I was asked to make an STK for a PTE setup featuring dual WGs. Without naming vendors, I guess he ordered a similar kit and just now got his money back from the ordeal. I cut him a deal since he will be my first customer this should be cake to fab since it uses 2.8 manifolds.
  27. #67
    Apr 26 2015
    Phoenix, AZ
    Without naming vendors? Everyone here knows that's wdr. Not trying to derail the thread at all, but seriously everyone here knows wdr makes promises they have no intention of keeping. 😊
  28. #68
    Aug 29 2017
    PWN
    And Mike Fabrication shop has begun.
  29. #69
    Feb 13 2016
    Philadelphia Burbs, PA
    Great build. Big fan of the fabrication.
