Results 1 to 9 of 9
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    2016 F-150 SCREW and 09 A6 Avant
    Idaho
    Dead battery, key stuck in ignition
    Installed a brand new battery back in December. Wife drove the car last night. This afternoon, she goes to start it and nothing. Not even an attempt to crank, no sound. She noticed that the Parking brake indicator flashed on the instrument panel and the button itself. The key is stuck in the ignition and I cannot remove it. I currently have a battery tender hooked up to the front posts but suspect that won't help. I need to pull the battery out and do a test. Thing is, is that I don't know how to release the tailgate and have come up with nothing via Google search.
    ETA: Just did a test with a multimeter and it's showing the battery @ 4.59 volts...
    Current:
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Jun 11 2018
    West Virginia
    I just had this issue with mine. Luckily it was just a dead battery. Same exact symptoms too. The tender didn't work for me no matter what setting I had it on.
    May 17 2009
    Idaho
    Quote Originally Posted by lazerghost View Post
    How old was the battery?
    Current:
    2002 1.8t A4 Sedan
    Jun 11 2018
    West Virginia
    Quote Originally Posted by c@@kieMonsta View Post
    I just purchased the car about two months ago, but it was the stock battery. I'm assuming it was never changed, so 10 years?
    May 17 2009
    Idaho
    Sedan or Avant?
    Current:
    2002 1.8t A4 Sedan
    Jun 11 2018
    West Virginia
    It's the sedan. I'm not sure if the hatch is set up the same way as a VW Golf, but there's a little "service" door above where the latch for the hatch is. If you can pop the plastic piece off it should give you access to the latch to open it up.
    May 17 2009
    Idaho
    I was able to give the battery a "jump" long enough to pull the key out and open the hatch. Pulled the battery. Parts store tested 5.16v, couldn't even do a load test. We'll see tomorrow when the battery is all charged.
    Current:
    2002 1.8t A4 Sedan
    May 23 2016
    Edmond, OK
    It could be a bad cell on the battery or your alternator not charging it. Did the store try testing your alternator's output while on there?
    Also, if you're flexible enough (for future reference), you could have just dropped the rear seats and stretched back towards the glow-ie emergency trunk release to get it open (the "omg I've been kidnapped-handle" inside the trunk, lol).
    ^^ nevermind on that tip. I just realized the key (which you would have needed to unlock the rear seats if locked in) was stuck at the ignition. Disregard... as you were
    May 17 2009
    Idaho
    Quote Originally Posted by 95blkmax View Post
    I have an Avant. No glowy handle to be seen.
    Called the parts store and they said the battery won't charge so it's a goner. Good thing it's under replacement still.
    Current:
    2002 1.8t A4 Sedan
