Results 1 to 10 of 10
    Senior Member Two Rings wastatepride's Avatar
    Aug 17 2016
    Monroe, WA
    Pulling out my mechatronics unit
    Im currently in the middle of doing the repair kit. Im having a hard time pulling the mech unit out of the gearbox housing.
    Ive done lots of searches and have found great info but they seem to breeze over this part. I must be doing something wrong if mine is that stuck up in there? Any help would be great?
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Did you pull the plug out for the tranny tcu?
    Goes in the back drivers side of the tranny.
    Then once the harness plug is out the acual plastic ring around plug twists out
    Sent from my SM-G950W using Audizine mobile app
    Aug 17 2016
    Monroe, WA
    Nope I sure didn’t. Pretty sure I just broke something related to that? Is there a ribbon connected to something up there?
    Aug 15 2015
    2 feet
    Niagara canada
    Damm
    Ya that ribbon is part of the tcu
    Ill take some pics if a unit i have out once i get to shop
    Veteran Member Three Rings WarmFuzzies's Avatar
    May 24 2017
    b8.5 S5 cab, 200-series L/C
    Montana
    whats your personal email address? PM me
    I made an extensive DIY print out for a B8 A4 with instructions on how to pull this out.. I had to fix a leaky connector within the mechatronic unit
    Aug 17 2016
    Monroe, WA
    Quote Originally Posted by WarmFuzzies View Post
    I appreciate that. It’s too late now though. I’ve got the unit out and I broke the tcm pulling it out so I’m kinda stuck
    May 24 2017
    Montana
    Quote Originally Posted by wastatepride View Post
    No worries — it’s too bad there’s no way to upload PDFs to the site to archive.
    Either way good luck!
    Veteran Member Three Rings Jcam14's Avatar
    Aug 17 2013
    fully built 1998 Camaro SS/ 2000 Silverado RCSB/ 2000 Camaro SS
    Tucson, Arizona
    are you doing this repair due to getting the mechtronic fail issue? no reverse?
    2015 White S4/Lowered/034 CAI/034 STG 2 Tune/034 Upper & Lower Crank pulleys/19" Peelers/Black Leather with brown inserts/full CF inlays/Full LED interior lights/ Prem+
    Aug 17 2016
    Monroe, WA
    The gear selector sensor went bad on mine. It gets stuck in neutral and can’t get out without restarting the car
    Aug 17 2016
    Monroe, WA
    Quote Originally Posted by Jcam14 View Post
