Originally Posted by
JayTeeC
I put a full set of Stoptech x-drilled cryo treated rotors on my B7 S4, about 3.5 years ago (almost 30k miles) and very pleased, they've held up great. I like the look of x-drilled and do believe it helps with initial bite, cooling and brake-gas venting (or so I've read). Makes me feel better anyway! Of course you'll never know during most commutes, and I've never tracked it.
I also went with Stoptech Street Performance pads. They take a higher heat (also bled/filled with their STR600 hi temp fluid) but they lost some initial bite (they are also lower dust IIRC). Love the rotors but looking for better pads - I am starting to think you cant find the holy grail of pads - good initial bite, hi temp endurance, and low dust. I noticed the same loss of initial bite with Hawk HPS Streets.
Well - The best I've found (on my Legacy GT they are the "Holy Grail") =
Porterfield R4-S
The LGT is similar to the Audi - it's a heavier AWD Car - and these pads with Stoptech Steet Rotors are the best I've tried.... Tried Hawks, EBC, and Factory - all less pleasing - also replaced DBA Rotors with StopTechs - as the shop recommended them to play nicely with the R4-S pads.
They are low dust / excellent stopping power with extremely even application feel (Initial Bite through longer pedal press) - the only caveat I will add = I have Stainless lines with ATE 200 Fluid that was added along with this Rotor/Pad Combo....
So while my experience is not directly on the S4 - it will be the setup I go with on the S4 based on the Subaru LGT Platform results (i.e. having both to at least be familiar with the platforms).
