So I found the offending part, and was about a 3 min replacement job. Took longer to top the water up than to replace the sensor!
But...
Still hasn't solved the running cold problem. When sitting at idle, will get to around 70 degC, ('normal' is 90degC), and then drops down to about 50ish when driving. Only time is raises up again is if it's sitting in traffic or not moving.
Would anyone have any suggestions at to what could cause this? My first thought was that the thermostat is jammed open, but it was replaced last year (due to overheating!), so that's less likely, but still possible I guess.
