    Aug 13 2017
    Cincinnati, OH
    2017 S6 auto seat belt tensioner
    When I first got my car new about a year ago, the drivers seat belt would pull noticeably at first acceleration from stop. I would say that it pulled maybe an inch or more. Over time, the belt auto tensioner seems to have gotten more and more feeble to the point bow where it is barely noticeable. Both front seats settings show the auto tension is ON.
    Is this a feature that learns the driver over time and pulls less. For people with cars more that 1 years old does theirs still pull back noticeably.
    Had my 1 year audi care done yesterday and dealer says, no error codes, so it is operating correctly. It has definitely decreased the amount of pull over the last year. I cant see how it is normal, unless it is a learned feature that changes over time, on purpose.
    Aug 13 2017
    Cincinnati, OH
    Bump
    Mar 29 2014
    Hampshire, UK
    This is not normal behaviour.
    I had the same issue on my driver belt, no codes, and no pretensioning of the belt, which is feature of Audi Protect.
    My belt assembly was replaced under warranty.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR650//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Roc-Euro//Modded Exhaust//Cete ASC v2 installed//APR Stage 1 on. WoW
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Gone: 2009 Audi A3Q 2.0 TDIi
    Veteran Member Three Rings gk1's Avatar
    Aug 06 2014
    2014 SQ5
    NJ>CO
    Items for Sale
    FWIW I believe the belt tension differs based on drive select setting. So "comfort" is looser than "dynamic", but I could be wrong...just something to check.
    Your "individual" settings should have a mode for the belt tensioner to make it easier to isolate that one difference without the distraction of changes to engine/trans/suspension etc.
    2015 S6 Quartz Gray
    Black, Carbon, Night, Cold, DA, ACC, VCDS lowered, 034 Trans mounts, EuroCode Alu-Kreuz, {APR v1.1 & TCU}, Rohana RF2 20x9, {11.660@114.83 (4615lbs.)}
    2014 SQ5 Glacier White
    Black Nappa, Carbon, B&O, NAV, 21's, {stock 13.527@102.11 (4615lbs.)}
    2012 S4 S-Tronic Monsoon Gray {Stage II 12.868@107.8 (4275lbs.)}
    2008 A6 3.2Q S-Line Daytona Gray
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue {Stage I 14.746@95.29 (3944lbs.)}
    Aug 13 2017
    Cincinnati, OH
    Thanks guys. I will check settings mentioned. Also, i will check driver versus passenger seat. Both should be the same. But, it sounds like the tensioner mechanism is toast and will need to be replaced.
