Page 5 of 5 FirstFirst ... 345
Results 161 to 192 of 192
  1. #161
    Senior Member Three Rings skree25's Avatar
    Dec 20 2014
    1999 Audi B5 A4 Avant, 1996 Cherokee, 1989 Honda VTR 250
    UT
    Difficult vacuum leak
    The bar not going on is for sure concerning. That should pop on no prob. You said the chain is new. Where did you get it from? Maybe that chain has links ever so slightly a different length from the OEM chain. Shot in the dark, but it's possible. And yes, timing being off can effect comp numbers, as the cylinder isn't sealing like it should. It will also effect Vac, which is what you're experiencing that got you into this wormhole.
    Got the chains from FCP, Iwis is the mfr. I donít think itís chains though. The timing marks between the intake and exhaust cams are spot on with the notches in the bearing caps (see photos in earlier post). I think it has to be the hall sender or the impulse rotor on back of the intake cam. If the ecu is trying to compensate for a timing error that isnít actually there, would it be causing the engine to behave like it is?
    I agree step one would be to put the timing set back to cam bar and crank pin. Then I think Iíll inspect and swap the impulse rotors and hall senders and see if that changes anything.
    Iím getting an occasional code for random misfire which I think has got to be my timing being off now...
  2. #162
    Senior Member Three Rings Bob Marley's Avatar
    Jan 18 2016
    Queens NY
    Can't think of scenario where the cam bar not going on is ok... no matter what MB 93 says
  3. #163
    Feb 23 2010
    Lehigh Valley
    Quote Originally Posted by Bob Marley View Post
    Exactly. That means that the engine is mechanically out of time even though VCDS says it isn't. Before changing anything on the cams, put the engine back in time so the bar goes on and the belt is nice and tight. I don't think the ECU changing timing based off bad readings would cause low vac though. That's hardware related.
    B5 S4- K24s, built bottom end, E85
    B8 S4- GIAC Stage 2
    150cc Chinese Scooter of Doom
  4. #164
    Jan 18 2016
    Queens NY
    Gotta get real ABC with this shit...
    Eveything is referenced from the Crank/Flywheel
    The first connection from the crank to the rest of youre engine is the timinng belt which links both Banks to the crank... ...if that shit ain't right... nothing else will be.
    ..start from Bottom to Top
    A) Crank @ TDC with Lock Pin
    B) CAM bar On
    C) Your Exhaust cams are now perfectly in time.
    This is now your foundation to make any other adjustments.
    otherwise anything else you do will compound the issues
    If all 4 TDC markings up top line up... leave it all alone. You have some other issue.
  5. #165
    Dec 20 2014
    UT
    B) CAM bar On
    Yes I need to find out why the ECU thinks itís out of time when it really is in time. -12 kw doesnít match what Iíve been able to visually verify via crank pin, cam bar, and visual inspection of the intake cam.
    I think my issue lies in whatever is causing that gap.
  6. #166
    Dec 20 2014
    UT
    How confident are you that having engine in time but 093 off wouldnít cause my issues? If that is the case then that throws my whole hall sensor/impulse rotor theory out the window...
  7. #167
    Feb 23 2010
    Lehigh Valley
    Quote Originally Posted by skree25 View Post
    70%. I don't see how it would cause low vac. Unless it was misfiring like crazy. I'm not confident in anything with your car. Seems to defy the rules.
    B8 S4- GIAC Stage 2
  8. #168
    Jan 18 2016
    Queens NY
    Nevermind block 93 for now...
    If you're cam bar was able to go on before... ...and now it isn't going on at all...
    That's a major issue
    That should never change once set
    The bar should always be able to go on and off smoothly with a new timing job done... once it's off... Correction factors rise
    Youe ecu may be right all along... forcing you to address something physically out of wack
  9. #169
    Dec 20 2014
    UT
    Ok hereís what the current plan. Swap hall senders. Check 093. Swap impulse rotors. Check 093. Reset timing via the traditional method. Check 093. Drive the car for 20-30 miles. Recheck 093. Do another compression test and leak down test. Redo heads if necessary. Otherwise Install new OEM chains. Check 093. Drive car another 20-30 miles. Recheck 093.
    Otherwise itís probably new cams. Then back to OEM flywheel
  10. #170
    Established Member Three Rings Teck09's Avatar
    May 11 2017
    WA
    Just my .02, and all of the above sound like good plans, but I would redo and verify that your compression results were truly skewed from the dieing battery before throwing any significant amount of money at it. You might be currently chasing something that isn't necessarily affecting the initial cause for concern, the low vac issue. You had mentioned earlier that your manual cam adjustment may have affected the comp #'s as well, they very well may have but I would retime first with the cam bar and pin then check comp #'s before going any further.
    I am unclear exactly how and why the ecu adjusts timing and/or what block 93 shows but is it possible the KW/correction factor could be off due to the ecu trying to correct for low compression on that bank?
  11. #171
    Dec 20 2014
    UT
    Quote Originally Posted by Teck09 View Post
    My understanding is that 093 simply measures the deviation between the crank and the intake camsí timing. The only way this can change is via the tensioner, and Iím able to show the tensioner adjustment at 0 when 093 is measured, so I believe it has to be something else.
  12. #172
    Feb 23 2010
    Lehigh Valley
    The heads totally stock besides the cams? Ever been messed with? A valve not sealing all the way will cause those issues. It's unlikely, but possible.
    Edit: Doesn't explain the cam timing being off in VCDS. Mystery continues.
    B8 S4- GIAC Stage 2
  13. #173
    Dec 20 2014
    UT
    Maybe just the universe telling me to upgrade to 2.8 heads and new valvetrain
  14. #174
    Jul 04 2012
    Woodbridge, VA
    Did you ever drive it around after seeing -12 and 5?
  15. #175
    Dec 20 2014
    UT
    Quote Originally Posted by vavJETTAw36 View Post
    No. So thatís a possibility...that after I reset timing again and drive it that 093 will work itself back into spec like it did for that one guy in the other thread...
  16. #176
    Jan 18 2016
    Queens NY
    Needs time for Oil Pressure to build and tensioners to do they're thing... drive around and let the oil warm up... it flows better warm and will actuate the tensioners fully.... then see if theres a difference
  17. #177
    Dec 20 2014
    UT
    Well would you take a look at this...hereís my impulse rotors. Left is bank 1 right is bank 2
    I think I found the cause of 093 being out of whack. The gap used for timing by the sensor is way smaller for bank 2 which was the bank out of spec
    So my guess is these must be different on 2.8 vs 2.7 cams then and I must have gotten one of each somehow.
    Hopefully I can find a spare to match bank 1 and throw it in...
  18. #178
    Jan 18 2016
    Queens NY
    For christ sake bro...
  19. #179
    Feb 23 2010
    Lehigh Valley
    Looks like heís finally slain the beast.
  20. #180
    Dec 20 2014
    UT
    Found a spare of the larger size to match bank 1 (stamped 234F). Threw it in. Also swapped hall sensor sides, but no change on 093
    I havenít retimed the motor so this is still showing the manual adjustment out of time, so I was hoping to see 093 out of time as well...but no luck
    Just seems weird that the impulse rotor being a different size wouldnít affect the timing at all
  21. #181
    Jan 18 2016
    Queens NY
    Apparently they just need to match ...i'm thinking because the 2.8 cams I have Installed have the 2.8 Sensor.. not 2.7 and Block 93 Is fine.
    But all the manual adjustments you made would indeed keep you out of whack now
  22. #182
    Dec 20 2014
    UT
    Apparently they just need to match ...i'm thinking because the 2.8 cams I have Installed have the 2.8 Impule Rotors... not 2.7 and Block 93 Is fine.
    Mine were mismatching, now they are matching, but 093 has shown the same in both scenarios.
    The hall sensors are interchangeable between the two right?
  23. #183
    Jan 18 2016
    Queens NY
    It seems that way... since I dont recall swapping them... I installed my 2.8 cams as is... Hall sensors and all without issue
  24. #184
    Feb 23 2010
    Lehigh Valley
    Still doesn't explain the low vac.
  25. #185
    Dec 20 2014
    UT
    Still peanut explain the low vac.
    Nope youíre right, it doesnít. Next step is to retime the motor and redo compression test. If compression is low then Iíve got a head problem. Not sure what else it could be at this point.
    What sucks is I wonít be able to get in a garage again for 2 months. Buying a new home and just in between work spaces...
  26. #186
    Dec 20 2014
    UT
    Got a quick question. What does vacuum typically do at this car when car is slowly accelerated to ~3k RPM?
    Iíve been reading a bit in vacuum issues and how if vacuum goes to 0 when light acceleration is given it can indicate a clogged exhaust.
    My motor definitely does this, but I donít know if itís out of the ordinary for a turboíd motor since itís always going to be creating some boost under throttle.
    Does anyone else lose vacuum under light acceleration (without building boost)? Or should I possible look into a clogged exhaust as a possible culprit of my low vacuum issue
  27. #187
    Feb 23 2010
    Lehigh Valley
    It depends how much you press the gas pedal. You can still accelerate while pulling some vac, and you can still accelerate at 0 vac/boost. If I'm accelerating under normal driving conditions and not in boost, my Boost/Vac will sit right at 0.
    B8 S4- GIAC Stage 2
  28. #188
    Dec 20 2014
    UT
    Ya sounds like what mine does...so probably not the issue.
  29. #189
    Jan 18 2016
    Queens NY
    Question... ...i'm currently having a random Throttle Body issue...
    I also have -12 & 11 vac now untill I change throttle body out.
    No codes at the moment.
    Have you done a Throttle body Alignmenttcheck since install?
    Basic Settings #60
    Youre looking for ADP O.K.
    Worth a Shot...sometimes you'll get a code if not in Alignment...sometimes not, but low Vac will result if Plate angle is off
    Currently my situation with all Timing Numbers Spot on... very low vac, however in my case I know it's my TB
  30. #190
    Jan 18 2016
    Queens NY
    Old TB ... mechanically failing open... I just replaced and all my vac is back.
    No code ... only when I tried to initiate Throttle Adaptation ECU went nuts
    MAF g/s readings at idle were high also... 6.00-7.89g/s
    Throttle Body plate is the biggest valve on you're motor...so if it's not fully closed...
    Just a thought
  31. #191
    Dec 20 2014
    UT
    Just a thought
    Thatís a good thought. Iíll do another adaptation to double check...
  32. #192
    Dec 20 2014
    UT
    TB adaptation is good...not the issue
