Results 1 to 15 of 15
    Veteran Member Three Rings fstr n u's Avatar
    Jan 20 2015
    Has anyone purchased and installed the Unitronic Stage 3 package?
    Has anyone bought and installed the Uni Stage 3 package?
    My question is around fuel delivery with this system....would you not require some sort of fueling upgrade?
    Being an MT car, i know i would need a clutch...and without a doubt a cooling upgrade (ie. PLM Hx or Merc Racing Hx).
    Is there anything else i'm missing?
    Also looking for feedback on how owner experiences have been should anyone be able to chime in.
    Ryan
    2019 Audi SQ5 Navarro Blue Technik w Black Optics Pkg - stock for now
    2015 Audi S4 6MT Glacier White w Black Int (IE Stg 2, Merc Hx, CTS Turbo CAI & CTS S/C Pulley) - my DD
    2006 Subaru STI Hawkeye Murdered Out - larger turbo 400hp - son's car
    1998 Chev Camaro 6MT, LS2 Rear mount Turbo (710+rwhp/710+rwtq @ 14# boost wheels) - summer hooligan
    http://www.youtube.com/@musclecarfan1
    https://www.instagram.com/ryan_baliski/
    https://www.tiktok.com/@winewithryan
    Jul 21 2004
    South Florida
    No fueling upgrade necessary if you are not using a bunch of e85. Unitronic tuned the cars assuming the normal fuels it was designed for like up to E10 of 91 and 93 octane in the US.
    I'd keep you stock clutch as long as you can. See how it goes. You may get lucky for awhile.
    Get a good heat exchanger. Doesnt have to be expensive. You can get the bar and plate Revo for a grand when its on sale or the Merc for around $450 if I recall.
    Thats it. Have fun.
    Mike
    2018 Audi S5
    Gone-
    Established Member Two Rings TSTARKZ's Avatar
    Feb 20 2007
    NY/NJ
    Quote Originally Posted by fstr n u View Post
    Ryan
    So far, so good. I do have an upgraded clutch and heat exchanger. I'm pretty sure I could have gone without the clutch for some time, but absolutely needed the heat exchange.
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Any of you guys commenting do the upgrade from Stage 2 to 3? Was it magical?
    Jul 21 2004
    South Florida
    Quote Originally Posted by jbullin2 View Post
    As long as you keep iats in check these cars continue to make great power the more boost you add. Its definitely there compared to stage 2.
    If you figure nothing fancy basically stock car with just a good hx on pump gas i estimate very roughly....
    Stock: 104-105mph traps
    Stage 1: 109-110mph traps
    Stage 2: 114-115mph traps
    Stage 3: 118-119mph traps
    Mike
    2018 Audi S5
    Gone-
    Dec 21 2014
    Milwaukee
    Quote Originally Posted by bhvrdr View Post
    Mike
    What’s amusing to me is my car in Stage 2 form on 93 at <3700 lbs only trapped 108 . Then again, I was the 4th person to jump on the Uni tune and haven’t updated it since. My rev limiter is still 6500 as well :(
    I keep meaning to reflash but I’ve been trying to coordinate it with a dyno rental to see what I’ve been missing.
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    Participate in the dyno day at Komet in St Charles Illinois?
    Dec 21 2014
    Milwaukee
    Quote Originally Posted by GandalfTheIbis View Post
    I usually just rent the dyno for an hour at Late Model Throttle in Waukesha. That’s where all my baselines are.
    Apr 04 2017
    Chicago IL
    That makes much more sense. Keep on keeping on
    Jul 21 2004
    South Florida
    Those traps are all relative. Based on conditions or fuel quality you may be subtracting 4mph from all of them. Doesnt hurt to log the car though as you can learn so much about what may be impacting your power output
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Mike
    I've seen even higher , 117mph stage 2+ and 120+mph stage 3 with e25 mix (done with pgear and not at a track)
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Senior Member Two Rings wastatepride's Avatar
    Aug 17 2016
    Monroe, WA
    What’s funny is you guys are just talking about a regular old DP tune. They dont have a stage 2, just stage 2+ which consists of a single pulley. Then you have “stage 3” which is dual pulley. It’s the same as every other tune and every other guy running dp is stage 3 technically if their pulley ratios are over 3-1
    Junior Member One Ring trancepat's Avatar
    Jul 29 2005
    Montreal/QC
    I installed the Unitronic Stage 3 two days after it was released, you can feel the difference a lot when it's cold but fter a few runs it degrade a lot, I was completely aware that I need an Intercooler.
    The ECU is pulling Timing a lot in warmer temps. I am now in process to buy the Merc Racing HX with their Expansion Tank and maybe the VariMax PWM Intercooler Coolant Pump.
    Next step will be Test Pipes
    2013 S4 Prestige | Ice Silver Metallic | Magma Red Nappa leather | Carbon Atlas Inlays | DSG | Sport Diff | Unitronic Stage 3 DP | Unitronic Stage 2 TCU | UniCONNECT+ | Ecode F/R Sway Bars | Ecode Alu Kreuz | ECS Trans & Diff Inserts | 034 Rear Sub-Frame Mounts | CR-15 | Moog F/R EndLinks | Magnaflow 11385 X-Pipe | Test Pipes | 034 Intake Hose+Pipercross Filter | KW V3 | 034 Rear Toe Links | StopTech SS Brake Lines | EBC Yellow | Michelin PS4S
    Senior Member Three Rings sc117's Avatar
    May 11 2015
    2015 Audi SQ5
    NOVA
    Unitronic Stage 3 makes the same power as the APR stage 2 Ultracharge noodle?
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by sc117 View Post
    Looks like it... anyone else notice that?
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
