Results 1 to 14 of 14
Threaded View
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Putting together a budget BBK with Q5 3.0T calipers, part list?
    Doing some research to avoid spending 1000+ at ECS
    2013 + Audi Q5 345mm version from the 3.0T or 3.0Tdi
    Part number :
    8R0 615 107 G (Pre-revison = E)
    8R0 615 108 G
    Rotors (345x30) - Left & Right https://www.ecstuning.com/b-ecs-part...0301mxsgmtlra/
    Brake Lines - Left & Right hoping my aftermarket SS lines fit
    Brake Pads https://www.carpartkings.com/catalog...y/1/id/657251/
    Front Brake Pad Wear Sensor Bypass - 2
    Caliper Mounting Hardware ???
    Super DOT 4 Brake Fluid - 1 Liter
    Red caliper paint: https://www.ecstuning.com/b-por_15-p...ed/por42806kt/
    ended up getting this:
    Brake Hose - Priced Each
    ES#: 2568433
    $11.90
    Brake Pad Wear Sensor Clip
    ES#: 61990
    $1.42
    $2.84
    Brake Rotor - Cross Drilled & Slotted Geomet Coated - Left
    ES#: 2189683
    $138.95
    Brake Rotor - Cross Drilled & Slotted Geomet Coated - Right
    ES#: 2189682
    $138.95
    ES#: 2872652
    $5.95
    Super DOT4 Brake Fluid - 1 Liter
    ES#: 602
    $11.65
    $11.65
    Hex Bolt - Priced Each
    ES#: 8764
    4
    $5.71
    $22.84
    Caliper Paint Red
    ES#: 3551570
    $14.66
    StopTech Posi Quiet Ceramic Brake Pads
    ES#: 2856005
    $63.99
