Results 1 to 27 of 27
    Established Member Two Rings Marlon177's Avatar
    Nov 04 2010
    2016 CLA250 4Matic
    Need advice on Crank Pulley and Supercharger Pulley
    Just purchased a 2012 Audi S4 with 80k miles on it few weeks ago, I had been reading up about B8 S4 but I am still confused about the pulleys. Since I will be changing out the front grill because my car came with euro grill and I came across about crank pulley failure thread. Here are my questions;
    I am planning to tune it for sure but it probably wonít be another year, since I will be taking off the front bumper, I think I should replace the crank pulley at the same time.
    As front as the tune, I am undecided on stage 1 or 2.
    There are many different sizes on the crank pulley, what size do I need and what are the difference with all these sizes.
    If I want to upgrade the supercharger pulley, will it be ok without tune for a year or 2?
    I think the crank pulley and the supercharger pulley are running on the same belt, so I think I will need the correct size of the belt if I am gonna upgrade both, which is the part I am confused the most.
    What tools do I need to do all that myself, the grill should be here in a week or 2, so I am planning to do all these at the same time.
    Any help would be appreciated.
    Thanks.
    Edit: I havenít purchase any pulley or belt yet, just the grill.
    Senior Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    2011 Audi S4, 2017 Honda Civic EX
    Rapid City, SD
    If you already have a new crank pulley, why not go ahead and swap it out? I haven't done mine yet, but I'm still contemplating on going dual pulley.
    Stage 1 or 2 in this car is great. But if you get the chance to experience going stage 2 in the S4, it's a completely different animal. You can get a larger crank pulley and run stage two on the OEM supercharger pulley. If you're already pulling off the bumper, go this route. You'll take care of the failing crank pulley and be stage two.
    There's no point in upgrading your supercharger pulley and not tuning the car. Your car will bleed off the extra boost but in all reality, don't be that guy.
    Contact EPL, they're running a July 4th sale right now.
    YouTube: DV Motions | Instagram: daanny.vu
    []S4 | EPL Stage 2
    Nov 04 2010
    2016 CLA250 4Matic
    Quote Originally Posted by USAF_Danny View Post
    Just to clarify, I havenít purchase any pulleys or belt yet and what is dual pulley?
    Oct 08 2017
    2013 S4 6MT
    Boston, MA
    I replaced mine with the 179mm JHM Crank pulley and tuned with Chipwerke pro stage 2. All done for ~$600. I heard with larger than 179-mm you'll need to file down/cut off a part to not have the belt rub off.
    https://www.audizine.com/forum/showt...r-2-in-a-jiffy
    No point of upgrading the super charger pulley unless you are going DP setup.
    Nov 04 2010
    2016 CLA250 4Matic
    Quote Originally Posted by ValidatedS4 View Post
    So if I run a bigger crank pulley then I donít need to upgrade the supercharger pulley to run stage 2? And what is the stock crank pulley size?
    Established Member Two Rings spoolin80's Avatar
    Mar 03 2013
    Va
    Quote Originally Posted by Marlon177 View Post
    correct the crank pulley is alittle easier, although when I did my jhm 179 on my 12 I had to put it into service position, which you can find on youtube from ECS.
    I'd check this thread out, it all comes down to pulley ratio and what can be done to achieve that
    https://www.audizine.com/forum/showt...lopment-thread
    basically a crank pulley can give you the same effect of a pulley ratio as it would keeping the stock crank and a supercharger pulley. That thread also gives you ratios and when you should look at cooling upgardes like a heat exchanger
    2012 Ice Silver S4 - CW Stage 1 - HR OE Springs - Roc-Euro Intake
    Stage 2 Banner Advertiser Four Rings Chris@EPL's Avatar
    Jun 23 2011
    The stock crank pulley is about 163mm so if you went with a 179-183mm crank pulley kit that would put you at a Stage 2 ratio and you would not need to replace the SC pulley to go Stage 2. LMK we offer our Stage 2 tunes with our SC pulley or without.
    European Performance Labs
    http://www.facebook.com/EPLabs
    https://www.instagram.com/eplabs/
    (203-345-6499)
    Chris@eplabs.net
    Please feel free to contact us with any questions!!
    Nov 04 2010
    2016 CLA250 4Matic
    What is the difference between 179 and 183?
    Can I run a larger crank pulley without stage 2 tune for a year or 2?
    Which tune can I run with larger crank pulley? I read on the APR site, supercharger pulley is required for stage 2.
    Will the car act differently if I run a larger crank pulley without tune?
    Do I need to file/cut down some area in order to run larger pulley?
    Too many questions lol, sorry.
    Thanks.
    Established Member Two Rings BigKeshy's Avatar
    Jun 01 2017
    Washington, DC
    The first page of the thread that theweebabyseamus linked answers most of your questions.
    Sizing up the crank pulley has the same generally effect as sizing down the supercharger pulley in that it simply spins the supercharger faster. Spinning the supercharger faster means that more boost will be generated.
    You "can" but again there's no point. As USAF_Danny pointed out all you'll do is bleed extra boost.
    I understand the desire to do everything while the bumper is off to save yourself from doing it again. But based on the questions you're asking I'd encourage you to simply do the grille swap this time around, then spend the time between now and when you decide to get a tune reading up on the subject so you can make more informed decisions based on your particular use requirements.
    2013 B8.5 S4 MT
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Thanks.
    1. You can, but it's not ideal, and I personally wouldn't do it.
    2. Many tuners have files for "stage 2" and "dual pulley" setups. APR, EPL, GIAC, and Unitronic are the most popular tuners for this platform. I'd only consider running a tune from one of these four.
    3. It should act mostly the same, but the ECU will constantly bleed off the extra boost. This is not optimal.
    4. From what I've seen 179mm is about the largest you can run without having to cut the extra machining boss off the engine block. I'm sure there are others out there who have run a 183mm setup without issues, but I wouldn't suggest it. The risk is simply your supercharger belt breaking, leaving you potentially stranded somewhere. If you have the proper tools, machining down the extra part of the block only takes a few minutes. I used an angle grinder with a cutting disk, but a file should work too.
    Since you have a 2012 model, I would suggest replacing the crank pulley as preventative maintenance if you an. I would suggest looking into the JHM pulleys - they offer both 179 and 187mm sizes. I personally run a dual pulley setup with their larger 187mm size. Going with the 179mm setup is basically the same as swapping the supercharger pulley for a smaller one. The supercharger just spins - it doesn't know or care which pulley's diameter is changing.
    A quality lightweight solid crank pulley for this platform should cost you anywhere from $300-500. Anything more than that, such as a fancier "dampened" Fluidampr pulley, is a waste of money.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR CPS, AWE Touring Exhaust (90mm Silver), ECS 10mm/12.5mm Spacers, 034 Mount Inserts, Hawk HPS 5.0, Rotors w/ PSS (Summer), Peelers w/ LM-32's (Winter)
    Mar 20 2015
    McKinney,TX
    Quote Originally Posted by BigKeshy View Post
    I would agree
    Also note the main purpose of all of these higher ratios is to spin the supercharger 2-3K faster, so youre if you're not tuned for stage 2, as noted above, you're creating extra stress/heat on supercharger and components without getting the extra power because of the boost bleed.
    Though it is Ok I wouldn't do it now and then wait for a year or two as was suggested in original post.
    Nov 04 2010
    2016 CLA250 4Matic
    Thank you for everyoneís input, I believe I got all the info I need.
    I was thinking to replace the pulley as one of the maintenance since I will be taking off the bumper and also afraid the stock crank pulley will fail and cost me more money.
    Established Member Two Rings wastatepride's Avatar
    Aug 17 2016
    Monroe, WA
    Quote Originally Posted by Acejam View Post
    1. 4. From what I've seen 179mm is about the largest you can run without having to cut the extra machining boss off the engine block. I'm sure there are others out there who have run a 183mm setup without issues, but I wouldn't suggest it. The risk is simply your supercharger belt breaking, leaving you potentially stranded somewhere. If you have the proper tools, machining down the extra part of the block only takes a few minutes. I used an angle grinder with a cutting disk, but a file should work.
    OR you could get a cts crank pulley which comes with a 6 rib v-band belt and no filing or machining. I have a 187 on mine and donít rub on anything. Been dual pulley for about 2000 miles problem free
    Dec 22 2009
    MA
    Quote Originally Posted by wastatepride View Post
    I consider 6 rib belts to be a hacky and temporary solution. Glad itís working out for you, but if you ask me, get a belt that fits.
    Jun 01 2017
    Washington, DC
    If you're just going with an OEM sized (162mm) replacement crank pulley, then that would make sense to do while you've got the bumper off for the grille swap. Good luck, mate!
    2013 B8.5 S4 MT
    Aug 17 2016
    Monroe, WA
    Can you tell me how my belt does not fit? I feel like your the one with the belt that doesnít fit cuz you had to grind your engine block like everyone else that uses a 7 band to each there own.
    Aug 17 2016
    Monroe, WA
    Also, Iím curious how itís temporary Iím eagerly awaiting your response
    Dec 22 2009
    MA
    Running a 6 rib belt leaves an entire rib exposed that isnít covered/supported and requires using a thinner and thus weaker belt.
    The amount of material that needs to be removed is about 2-3mm tops. Thatís almost a bad surface scratch. My setup wasnít actually touching at static, but I did it as a preventative measure.
    As Iím sure youíre aware, these belts move a bit. Thatís why the pulleys have a taller ďedgeĒ on them, something you loose out on with a 6 rib belt.
    Aug 17 2016
    Monroe, WA
    The cts crank pulley only has 6 ribs. So ya, Iím good. Do your homework.
    Dec 22 2009
    MA
    Itís temporary because almost all folks run 7 rib belts but when they snap one (cause they didnít grind or for any other reason) they have to run a 6 rib temporarily because a properly fitting 7 rib is tough to find at local auto part stores.
    May 12 2008
    I think both setups have merit but I'd definitely consider grinding my engine block to be the more 'hacky' of the two options. Lol
    Aug 17 2016
    Monroe, WA
    If there was an empty rib on my pulley I definitely gone with a 7 rib. But since it came with the 6 rib and thereís only 6 ribs on my pulley... seemed like a no brained but who am I lol
    Dec 22 2009
    MA
    I think you are confused: https://www.ecstuning.com/b-cts-part...-hw-266-187~c/
    Edit: Zoom in on those machined ribs, and the belt too. 7PK1320 means 7 rib, 1320mm length.
    Aug 17 2016
    Monroe, WA
    [QUOTE=Acejam;13153379]I think you are confused: https://www.ecstuning.com/b-cts-part...-hw-266-187~c/
    You are totally correct I just went out and counted mine. *inserts foot in mouth*
    Sent from my iPhone
    Established Member Three Rings MSq5's Avatar
    Feb 14 2017
    Gulfport, MS
    Can't say with absolute certainty about crank pulley clearance on the S4, but I think it is identical to my Q5. On the Q5 I was able to install the JHM 179mm crank pulley completely from below without taking off the front bumper (service position). It is tight, but not difficult. Entire process took me about 45 minutes to remove the lower shield, lock the belt tensioner, remove the stock belt, remove OEM crank pulley, install JHM 179, loop new belt in place, unlock the tensioner and put the lower shield back.
    Regardless of method you use, note that one of the crank pulley holes is offset. That hole location must be marked and visually indexed to a reference point so that all bolts will fit properly. You can also put a longer stud temporarily in that offset hole on the front of the crank and slip the offset hole of the crank pulley over it first, fasten down all the others, unscrew the stud and replace the offset bolt last.
    2017 Q5 3.0T S-Line | Brilliant Black | EPL Stage 2 93 octane tune | JHM 179mm crank pulley | K&N E-1987 in "modified" stock air box
    034 silicone throttle body hose
    Nov 27 2015
    UK, West Berks
    If I read the OP's requirements correctly then the best strategy might be to fit a 162mm now to solve the OE pulley problem. Then when ready to tune, fit a Vdamper over it. Just need the right size to give the ratio suitable for the remap file chosen.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
