Results 1 to 25 of 25
    Senior Member Two Rings doady22's Avatar
    Feb 28 2010
    ft collins colorado
    When to add Fuel pump? I'm APR Ultracharged 93 file
    I'm stage 2+ APR Ultracharger and was wondering if any other Ultracharged guys could chime in. Have you guys added a upgraded fuel pump like autotech? The only reason I ask is that I'm seeing slightly lower boost levels now that I'm Ultracharged then when I was dual pulley? IAT's, were around 38C and outside temp was 72 degrees. Same amount of E-85 (4gallons) was put in and the exact same station so variables were the same. I'm 5200ft above sea level so don't laugh, but was seeing 16psi when dual pulley and when I ripped on it last night my P3 recall was 14.2psi.
    APR Crank Pulley, APR Supercharger Pulley, ULTRACHARGER APR Stage 2+ Tune 93 file, APR CPS, APR TCU Tune, CTS Intake and exhaust. Vogtland Coilovers, Niche Vosso M204 19x9.5 et38
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    '14 Audi S5, '18 BMW 540i, '17 Jetta SE
    Sarasota, FL
    There have been cases if the OEM HPFP not being able to keep up once ultracharged (and have been the reason Chris Carper here was only trapping 112-113mph, but then ended up trapping a good deal higher after an Autotech HPFP). If you have a VCDS logging tool, I would recommend logging your fuel to determine what the cause is, it may not be that issue.
    -Loe P.-
    Audizine Forum Moderator
    ('14 Audi S5 S-tronic )
    [10.930@127.38mph | +1209 ft. D/A | 3.371 PR]
    Senior Member Four Rings whiped's Avatar
    Apr 05 2016
    Portland, OR
    It's hard to say at your elevation.
    At sea level, the HPFP would be essentially maxed with your setup + ~E35 fuel causing you to lean out up top.
    Without seeing some logs or pulling the plugs it's hard to guess at the issue.
    Geoff
    Feb 28 2010
    ft collins colorado
    Thanks I'll try to find someone that has VCDS tool and knows how to log.
    Senior Member Four Rings JD S4's Avatar
    May 07 2016
    Boulder, CO
    Quote Originally Posted by doady22 View Post
    lmao.. stop being so fucking cheap. the 3 VIN is $199.
    2018 SQ5 - Daytona, Prestige
    *Sold*2011 S4 - EPL Dual Pulley + TCU - 20" BBS LM - Bilstein B12 - APR RSC Exhaust
    Deval CF Diffuser - Maxton Splitter - USP Intake - MercRacing HE - CR15 -AutoTech HPFP
    Feb 28 2010
    ft collins colorado
    Quote Originally Posted by JD S4 View Post
    Lol I'm not cheap I just don't know how to log or what to be looking for so would rather find someone who has done it and knows what to look for.
    Established Member Three Rings Melen2120's Avatar
    Feb 04 2017
    Bronx NYC
    Im all fair ness no one has been specific as to what logging parameters he needs and what are the tolerance for the values .
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4 2009 Q7
    St Johns, FL
    Quote Originally Posted by Melen2120 View Post
    https://www.audizine.com/forum/showt...t=vcds+logging
    Aug 09 2015
    Sarasota, FL
    download these into your VCDS folders, and then you can upload them as "saved" items. These are the fields I use:
    https://drive.google.com/open?id=15n...q3uFsJts6h-DoZ
    -Loe P.-
    Feb 04 2017
    Bronx NYC
    Quote Originally Posted by Loe View Post
    Thank you Leo , Im shore all those that are/were confused about the topic now have a clear understanding .
    May 07 2016
    Boulder, CO
    I can help you log
    Sent from my
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    This thread has my attention. The Mrs. got me a VCDS for my birthday and I am a VCDS novice. When you save the files does it act as a templet for data logging in the future?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    12.3 @ 112mph 2288DA on 93oct file Stage 2
    THEN THEN THEN Rinse & Repeat!
    Jul 10 2013
    Central WI
    There's an option to save/load selected parameters from the list to a file. Click the upper left corner icon, the menu is there.
    Feb 28 2010
    ft collins colorado
    Loe so I found your thread about his situation, my max psi hits at 5200rpm and then stays flat and doesn't climb. Was that the similar case with Chris?
    - - - Updated - - -
    3 Vin on order
    Apr 04 2017
    10 S4, 14 328d, 14 MDX
    Chicago IL
    You won't regret the cable... until you run out of vins because other audi drivers in town find out you're the cool guy with the cable.
    Feb 28 2010
    ft collins colorado
    Quote Originally Posted by GandalfTheIbis View Post
    Yea It's way overdue getting the cable, hopefully I can get this issue figured out so I can enjoy my ultracharger.
    Feb 28 2010
    ft collins colorado
    So when back to shop that installed my Ultracharger, we did a reflash on the tune and also did a smoke test to check for a boost leak. Holding boost fine and the reflash didn't help. This rosstech cable can't get here soon enough.
    Feb 04 2017
    Bronx NYC
    here are a few logs of my car feel free to share opinions
    Friday 15 June 2018 23:06:03:56276-VCID:303A19B89AAEEEC7C28-8064 VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
    4G0 907 551 J ADVMB 3.0l V6 TFSIH07 0003
    G002 F0 G007 F0 G014 F0 G221 F0 G455 F0 G468 F0 G469 F0 G674
    Marker TIME Loc. IDE00021 TIME Loc. IDE00083 TIME Loc. IDE00190-ENG103225 TIME Loc. ENG101818 TIME Loc. ENG101025 TIME Loc. ENG101741 TIME Loc. ENG101388 TIME Loc. ENG99738
    STAMP Engine speed STAMP Throttle valve position (absolute) STAMP Charge air pressure specified value-MAP_SP STAMP Actual fuel rail pressure STAMP IGA_AD_1_KNK[1] STAMP Intake air temperature STAMP Intake manifold pressure: absolute STAMP RFP_AV
    /min % hPa hPa C hPa
    1.55 2136 1.55 34.9 1.55 970.96 1.55 71401.9 1.55 0 1.55 33.75 1.55 876.36 1.55 71.24
    1.62 2168 1.62 44.7 1.62 947.91 1.62 77541.8 1.62 0 1.62 33.75 1.62 995.09 1.62 71.14
    1.69 2168 1.69 44.7 1.69 965.49 1.69 82471.8 1.69 0 1.69 33.75 1.69 984.73 1.69 71.03
    1.75 2136 1.75 41.2 1.75 1110.68 1.75 77525.9 1.75 0 1.75 33.75 1.75 976.35 1.75 70.93
    1.83 2153 1.83 44.3 1.83 1375.77 1.83 81399.8 1.83 0 1.83 33.75 1.83 998.33 1.83 70.68
    1.89 2175 1.89 49 1.89 1559.1 1.89 82753 1.89 0 1.89 33.75 1.89 1087.38 1.89 25.61
    1.96 2175 1.96 49 1.96 1627.67 1.96 84350.3 1.96 0 1.96 33.75 1.96 1312.67 1.96 13.71
    2.02 2244 2.02 53.7 2.02 1714.9 2.02 95414.9 2.02 0 2.02 33.75 2.02 1519.96 2.02 9.31
    2.09 2244 2.09 53.7 2.09 1761.91 2.09 104659 2.09 0 2.09 33.75 2.09 1620.95 2.09 7.46
    2.16 2252 2.16 57.3 2.16 1824.27 2.16 101725 2.16 0 2.16 33.75 2.16 1696.91 2.16 6.08
    2.23 2304 2.23 59.6 2.23 1986.79 2.23 101183 2.23 0 2.23 33.75 2.23 1772.28 2.23 2.44
    2.3 2346 2.3 62.7 2.3 2048.56 2.3 102467 2.3 0 2.3 33.75 2.3 1835.05 2.3 0
    2.36 2346 2.36 62.7 2.36 2142.67 2.36 102245 2.36 0 2.36 33.75 2.36 1872.19 2.36 0
    2.42 2389 2.42 65.5 2.42 2280.48 2.42 102287 2.42 0 2.42 33 2.42 1902.05 2.42 0
    2.5 2416 2.5 68.6 2.5 2286.87 2.5 103232 2.5 0 2.5 33 2.5 1916.14 2.5 0
    2.56 2416 2.56 68.6 2.56 2283.96 2.56 102239 2.56 0 2.56 33 2.56 1931.73 2.56 0
    2.63 2462 2.63 69.8 2.63 2295.82 2.63 102526 2.63 0 2.63 33 2.63 1941.85 2.63 0
    2.69 2507 2.69 71 2.69 2301.29 2.69 102207 2.69 0 2.69 33 2.69 1943.01 2.69 0
    2.75 2507 2.75 71 2.75 2310.58 2.75 104017 2.75 0 2.75 33 2.75 1954.2 2.75 0
    2.82 2548 2.82 78.4 2.82 2312.74 2.82 104431 2.82 0 2.82 33 2.82 1972.69 2.82 0
    2.88 2548 2.88 78.4 2.88 2323.43 2.88 105614 2.88 0 2.88 33 2.88 1981.56 2.88 0
    2.96 2576 2.96 80 2.96 2333.55 2.96 105890 2.96 0 2.96 33 2.96 1996.07 2.96 0
    3.03 2622 3.03 81.6 3.03 2340.76 3.03 105614 3.03 0 3.03 33 3.03 2007.76 3.03 0
    3.1 2670 3.1 83.5 3.1 2347.31 3.1 105800 3.1 0 3.1 33 3.1 2017.88 3.1 0
    3.16 2670 3.16 83.5 3.16 2349.14 3.16 106416 3.16 0 3.16 33 3.16 2024.93 3.16 0
    3.22 2715 3.22 85.1 3.22 2351.54 3.22 106097 3.22 0 3.22 33 3.22 2036.54 3.22 0
    3.3 2761 3.3 86.3 3.3 2355.6 3.3 106872 3.3 0 3.3 32.25 3.3 2047.32 3.3 0
    3.36 2761 3.36 86.3 3.36 2358.26 3.36 106930 3.36 0 3.36 32.25 3.36 2065.64 3.36 0
    3.44 2798 3.44 86.3 3.44 2361.08 3.44 107042 3.44 0 3.44 32.25 3.44 2073.44 3.44 0
    3.5 2844 3.5 86.3 3.5 2363.9 3.5 107811 3.5 0 3.5 32.25 3.5 2086.54 3.5 0
    3.58 2844 3.58 86.3 3.58 2367.38 3.58 108735 3.58 0 3.58 32.25 3.58 2103.87 3.58 0
    3.64 2890 3.64 86.3 3.64 2370.78 3.64 108358 3.64 0 3.64 32.25 3.64 2115.23 3.64 0
    3.72 2940 3.72 86.3 3.72 2373.51 3.72 109722 3.72 0 3.72 32.25 3.72 2127.83 3.72 0
    3.78 2940 3.78 86.3 3.78 2377.33 3.78 109165 3.78 0 3.78 32.25 3.78 2148.23 3.78 0
    3.85 2976 3.85 86.3 3.85 2379.4 3.85 109154 3.85 0 3.85 32.25 3.85 2160.66 3.85 0
    3.91 3023 3.91 86.3 3.91 2380.23 3.91 109377 3.91 0 3.91 32.25 3.91 2173.77 3.91 0
    3.98 3023 3.98 86.3 3.98 2381.39 3.98 109446 3.98 0 3.98 32.25 3.98 2192.42 3.98 0
    4.05 3075 4.05 86.3 4.05 2382.39 4.05 109563 4.05 0 4.05 33 4.05 2213.23 4.05 0
    4.11 3120 4.11 86.3 4.11 2383.22 4.11 109764 4.11 0 4.11 33 4.11 2217.21 4.11 0
    4.18 3120 4.18 86.3 4.18 2384.79 4.18 110263 4.18 0 4.18 33 4.18 2224.93 4.18 0
    4.24 3159 4.24 86.3 4.24 2385.37 4.24 109865 4.24 0 4.24 33 4.24 2233.55 4.24 0
    4.3 3215 4.3 86.3 4.3 2386.28 4.3 110247 4.3 0 4.3 33 4.3 2234.21 4.3 0
    4.37 3215 4.37 86.3 4.37 2387.61 4.37 109865 4.37 0 4.37 33 4.37 2228.91 4.37 0
    4.44 3267 4.44 86.3 4.44 2388.69 4.44 109340 4.44 0 4.44 33 4.44 2232.8 4.44 0
    4.5 3299 4.5 86.3 4.5 2389.43 4.5 109706 4.5 0 4.5 33 4.5 2243 4.5 0
    4.57 3299 4.57 86.3 4.57 2390.51 4.57 110035 4.57 0 4.57 33 4.57 2244.58 4.57 0
    4.64 3360 4.64 86.3 4.64 2391.51 4.64 110152 4.64 0 4.64 33 4.64 2255.36 4.64 0
    4.71 3401 4.71 86.3 4.71 2392.59 4.71 111240 4.71 0 4.71 33.75 4.71 2265.39 4.71 0
    4.77 3401 4.77 86.3 4.77 2393.58 4.77 112301 4.77 0 4.77 33.75 4.77 2282.22 4.77 0
    4.83 3448 4.83 86.3 4.83 2394.49 4.83 111929 4.83 0 4.83 33.75 4.83 2285.12 4.83 0
    4.9 3500 4.9 86.3 4.9 2395.74 4.9 111632 4.9 0 4.9 33.75 4.9 2297.98 4.9 0
    4.96 3500 4.96 86.3 4.96 2396.9 4.96 112805 4.96 0 4.96 33.75 4.96 2305.44 4.96 0
    5.02 3552 5.02 86.3 5.02 2397.56 5.02 113697 5.02 0 5.02 33.75 5.02 2315.22 5.02 0
    5.09 3552 5.09 86.3 5.09 2398.64 5.09 112274 5.09 0 5.09 33.75 5.09 2318.46 5.09 0
    5.15 3604 5.15 86.3 5.15 2399.22 5.15 113352 5.15 0 5.15 34.5 5.15 2326.42 5.15 0
    5.21 3653 5.21 86.3 5.21 2400.55 5.21 115262 5.21 0 5.21 34.5 5.21 2335.04 5.21 0
    5.27 3653 5.27 86.3 5.27 2401.04 5.27 114439 5.27 0 5.27 34.5 5.27 2332.47 5.27 0
    5.33 3694 5.33 86.3 5.33 2402.37 5.33 114853 5.33 0 5.33 34.5 5.33 2332.64 5.33 0
    5.39 3733 5.39 86.3 5.39 2403.36 5.39 113919 5.39 0 5.39 35.25 5.39 2332.55 5.39 0
    5.46 3733 5.46 86.3 5.46 2404.19 5.46 113919 5.46 0 5.46 35.25 5.46 2326.83 5.46 0
    5.52 3787 5.52 86.3 5.52 2405.27 5.52 115315 5.52 0 5.52 35.25 5.52 2316.63 5.52 0
    5.58 3787 5.58 86.3 5.58 2406.35 5.58 115066 5.58 0 5.58 35.25 5.58 2310.75 5.58 0
    5.64 3839 5.64 86.3 5.64 2407.51 5.64 114227 5.64 0 5.64 36 5.64 2310.66 5.64 0
    5.71 3875 5.71 86.3 5.71 2408.17 5.71 115527 5.71 0 5.71 36 5.71 2309.67 5.71 0
    5.77 3875 5.77 86.3 5.77 2409.17 5.77 116100 5.77 0 5.77 36 5.77 2315.06 5.77 0
    5.83 3937 5.83 86.3 5.83 2409.91 5.83 116207 5.83 0 5.83 36 5.83 2317.79 5.83 0
    5.89 3984 5.89 86.3 5.89 2411.08 5.89 116944 5.89 0 5.89 36.75 5.89 2323.43 5.89 0
    5.96 3984 5.96 86.3 5.96 2411.91 5.96 117326 5.96 0 5.96 36.75 5.96 2325.75 5.96 0
    6.02 4027 6.02 86.3 6.02 2412.32 6.02 118006 6.02 0 6.02 36.75 6.02 2331.56 6.02 0
    6.08 4027 6.08 86.3 6.08 2412.57 6.08 116530 6.08 0 6.08 36.75 6.08 2331.14 6.08 0
    6.14 4082 6.14 86.3 6.14 2413.07 6.14 116769 6.14 0 6.14 37.5 6.14 2342.92 6.14 0
    6.21 4129 6.21 86.3 6.21 2413.4 6.21 117432 6.21 0 6.21 37.5 6.21 2335.04 6.21 0
    6.27 4129 6.27 86.3 6.27 2413.73 6.27 117889 6.27 0 6.27 37.5 6.27 2329.4 6.27 0
    6.33 4174 6.33 86.3 6.33 2414.06 6.33 118536 6.33 0 6.33 38.25 6.33 2334.21 6.33 0
    6.39 4218 6.39 86.3 6.39 2414.31 6.39 118913 6.39 0 6.39 38.25 6.39 2334.29 6.39 0
    6.46 4218 6.46 86.3 6.46 2414.72 6.46 119099 6.46 0 6.46 38.25 6.46 2337.86 6.46 0
    6.52 4279 6.52 86.3 6.52 2415.14 6.52 120388 6.52 0 6.52 39 6.52 2341.09 6.52 0
    6.59 4279 6.59 86.3 6.59 2415.72 6.59 119709 6.59 0 6.59 39 6.59 2335.7 6.59 0
    6.66 4312 6.66 86.3 6.66 2415.97 6.66 119964 6.66 0 6.66 39 6.66 2341.26 6.66 0
    6.72 4362 6.72 86.3 6.72 2416.38 6.72 120160 6.72 0 6.72 39.75 6.72 2331.97 6.72 0
    6.78 4362 6.78 86.3 6.78 2416.63 6.78 120139 6.78 0 6.78 39.75 6.78 2332.88 6.78 0
    6.85 4415 6.85 86.3 6.85 2416.96 6.85 120924 6.85 0 6.85 39.75 6.85 2344.49 6.85 0
    6.91 4467 6.91 86.3 6.91 2417.46 6.91 120213 6.91 0 6.91 40.5 6.91 2335.95 6.91 0
    6.97 4467 6.97 86.3 6.97 2417.71 6.97 120463 6.97 0 6.97 40.5 6.97 2338.94 6.97 0
    7.03 4503 7.03 86.3 7.03 2418.12 7.03 121041 7.03 0 7.03 41.25 7.03 2345.32 7.03 0
    7.1 4558 7.1 86.3 7.1 2418.29 7.1 121206 7.1 0 7.1 41.25 7.1 2354.86 7.1 0
    7.16 4558 7.16 86.3 7.16 2418.95 7.16 121678 7.16 0 7.16 41.25 7.16 2367.63 7.16 0
    7.22 4598 7.22 86.3 7.22 2418.79 7.22 122193 7.22 0 7.22 42 7.22 2358.09 7.22 0
    7.28 4598 7.28 86.3 7.28 2419.62 7.28 122320 7.28 0 7.28 42 7.28 2355.77 7.28 0
    7.34 4651 7.34 86.3 7.34 2419.78 7.34 123089 7.34 0 7.34 42.75 7.34 2344.24 7.34 0
    7.41 4684 7.41 86.3 7.41 2419.87 7.41 123164 7.41 0 7.41 43.5 7.41 2345.41 7.41 0
    7.47 4684 7.47 86.3 7.47 2420.45 7.47 122463 7.47 0 7.47 43.5 7.47 2371.94 7.47 0
    7.53 4740 7.53 86.3 7.53 2420.86 7.53 122670 7.53 0 7.53 44.25 7.54 2344.82 7.54 0
    7.61 4785 7.61 86.3 7.61 2421.03 7.61 123816 7.61 0 7.61 44.25 7.61 2354.28 7.61 0
    7.67 4785 7.67 86.3 7.67 2421.77 7.67 123901 7.67 0 7.67 44.25 7.67 2396.9 7.67 0
    7.74 4838 7.74 86.3 7.74 2422.02 7.74 124379 7.74 0 7.74 45 7.74 2381.81 7.74 0
    7.8 4887 7.8 86.3 7.8 2422.19 7.8 124161 7.8 0 7.8 45.75 7.8 2365.89 7.8 0
    7.86 4887 7.86 86.3 7.86 2422.6 7.86 123397 7.86 0 7.86 45.75 7.86 2351.79 7.86 0
    7.94 4916 7.94 86.3 7.94 2423.18 7.94 123843 7.94 0 7.94 46.5 7.94 2370.78 7.94 0
    8 4983 8 86.3 8 2423.6 8 124862 8 0 8 47.25 8 2362.4 8 0
    8.07 4983 8.07 86.3 8.07 2423.68 8.07 124352 8.07 0 8.07 47.25 8.07 2394.82 8.07 0
    8.13 5028 8.13 86.3 8.13 2424.18 8.13 125239 8.13 0 8.13 48 8.13 2381.56 8.13 0
    8.19 5054 8.19 86.3 8.19 2424.34 8.19 125907 8.19 0 8.19 48.75 8.19 2389.19 8.19 0
    8.25 5054 8.25 86.3 8.25 2424.76 8.25 125987 8.25 0 8.25 48.75 8.25 2386.62 8.25 0
    8.32 5105 8.32 86.3 8.32 2425.25 8.32 127441 8.32 0 8.32 49.5 8.32 2382.47 8.32 0
    8.39 5105 8.39 86.3 8.39 2425.59 8.39 126963 8.39 0 8.39 49.5 8.39 2382.3 8.39 0
    8.46 5145 8.46 86.3 8.46 2426 8.46 127128 8.46 0 8.46 49.5 8.46 2394.49 8.46 0
    8.52 5221 8.52 86.3 8.52 2426.5 8.52 127568 8.52 0 8.52 50.25 8.52 2393.83 8.52 0
    8.58 5221 8.58 86.3 8.58 2426.42 8.58 128301 8.58 0 8.58 50.25 8.58 2407.1 8.58 0
    8.66 5245 8.66 86.3 8.66 2426.83 8.66 127929 8.66 0 8.66 51 8.66 2406.76 8.66 0
    8.72 5277 8.72 86.3 8.72 2427.41 8.72 127271 8.72 0 8.72 51.75 8.72 2400.71 8.72 0
    8.79 5277 8.79 86.3 8.79 2427.74 8.79 128237 8.79 0 8.79 51.75 8.79 2411.08 8.79 0
    8.86 5329 8.86 86.3 8.86 2427.99 8.86 128900 8.86 0 8.86 52.5 8.86 2416.47 8.86 0
    8.93 5358 8.93 86.3 8.93 2428.07 8.93 128417 8.93 0 8.93 53.25 8.93 2411.16 8.93 0
    9 5415 9 86.3 9 2428.65 9 128051 9 0 9 54 9 2407.76 9 0
    9.06 5415 9.06 86.3 9.06 2429.32 9.06 128900 9.06 0 9.06 54 9.06 2406.85 9.06 0
    9.13 5458 9.13 86.3 9.13 2429.32 9.13 128799 9.13 0 9.13 54 9.13 2414.56 9.13 0
    9.19 5511 9.19 86.3 9.19 2429.98 9.19 129251 9.19 0 9.19 54.75 9.19 2411.24 9.19 0
    9.25 5511 9.25 86.3 9.25 2429.98 9.25 130376 9.25 0 9.25 54.75 9.25 2416.55 9.25 0.18
    9.32 5554 9.32 86.3 9.32 2430.56 9.32 130843 9.32 0 9.32 55.5 9.32 2414.64 9.32 0
    9.38 5554 9.38 86.3 9.38 2430.64 9.38 129617 9.38 0 9.38 55.5 9.38 2417.05 9.38 0
    9.44 5585 9.44 86.3 9.44 2431.06 9.44 129744 9.44 0 9.44 56.25 9.44 2425.01 9.44 0
    9.5 5639 9.5 86.3 9.5 2431.31 9.5 130577 9.5 0 9.5 57 9.5 2416.55 9.5 0
    9.57 5639 9.57 86.3 9.57 2431.72 9.57 133045 9.57 0 9.57 57 9.57 2426.58 9.57 0.18
    9.63 5682 9.63 86.3 9.63 2432.05 9.63 130996 9.63 0 9.63 57 9.63 2435.95 9.63 0.08
    9.69 5728 9.69 86.3 9.69 2432.55 9.69 132143 9.69 0 9.69 57.75 9.69 2417.29 9.69 0
    9.75 5728 9.75 86.3 9.75 2432.63 9.75 131978 9.75 0 9.75 57.75 9.75 2425.59 9.75 0.54
    9.81 5774 9.81 86.3 9.81 2433.05 9.81 131288 9.81 0 9.81 58.5 9.81 2412.49 9.81 0
    9.88 5774 9.88 86.3 9.88 2433.46 9.88 132079 9.88 0 9.88 58.5 9.88 2428.16 9.88 0
    9.94 5809 9.94 86.3 9.94 2433.63 9.94 132281 9.94 0 9.94 59.25 9.94 2436.61 9.94 0.18
    10 5851 10 86.3 10 2433.88 10 134568 10 0 10 59.25 10 2427.33 10 0.13
    10.06 5851 10.06 86.3 10.06 2434.38 10.06 132137 10.06 0 10.06 59.25 10.06 2432.47 10.06 0.03
    10.13 5919 10.13 86.3 10.13 2434.71 10.13 132896 10.13 0 10.13 60 10.13 2416.8 10.13 0.69
    10.19 5967 10.19 86.3 10.19 2434.96 10.19 134531 10.19 0 10.19 60.75 10.19 2439.02 10.19 0.18
    10.27 5967 10.27 86.3 10.27 2435.29 10.27 135359 10.27 0 10.27 60.75 10.27 2419.12 10.27 0.03
    10.34 5992 10.34 86.3 10.34 2435.54 10.34 137009 10.34 0 10.34 61.5 10.34 2443.33 10.34 0
    10.41 6023 10.41 86.3 10.41 2435.87 10.41 134276 10.41 -1.5 10.41 62.25 10.41 2416.71 10.41 0.28
    10.47 6023 10.47 86.3 10.47 2436.2 10.47 137094 10.47 -1.5 10.47 62.25 10.47 2429.48 10.47 1.41
    10.53 6077 10.53 86.3 10.53 2436.45 10.53 136415 10.53 -1.125 10.53 63 10.53 2429.98 10.53 0.59
    10.61 6120 10.61 86.3 10.61 2436.86 10.61 136908 10.61 -1.125 10.61 63.75 10.61 2432.8 10.61 0.18
    10.67 6120 10.67 86.3 10.67 2437.44 10.67 135985 10.67 -0.75 10.67 63.75 10.67 2429.73 10.67 1.1
    10.73 6161 10.73 86.3 10.73 2437.61 10.73 136765 10.73 -0.75 10.73 64.5 10.73 2429.9 10.73 0.18
    10.8 6189 10.8 86.3 10.8 2438.02 10.8 136377 10.8 -0.375 10.8 65.25 10.8 2438.69 10.8 0.79
    10.86 6189 10.86 86.3 10.86 2438.02 10.86 136935 10.86 -0.375 10.86 65.25 10.86 2441.51 10.86 0.28
    10.92 6222 10.92 86.3 10.92 2438.27 10.92 135343 10.92 0 10.92 66 10.92 2438.69 10.92 1.2
    May 07 2016
    Boulder, CO
    These numbers arent too far off from most of us here at elevation
    Sent from my
    Mar 28 2014
    Is there any power benefits to changing to the HPFP. Im Ultracharged on 93 octane and wondering if there is any additional power to be gained? Autotech advertises as much as 5 percent increase in torque.
    2014 S5 APR Ultracharged
    Feb 28 2010
    ft collins colorado
    Speak English lol No idea what I'm looking at but if JD knows then thank you for the baseline. Cable will be here Tuesday.
    Feb 04 2017
    Bronx NYC
    Sorry I tried to post the log from my phone and did not pan out like I planed lol
    Aug 09 2015
    Sarasota, FL
    hey log the one that says Lamda_railpressure_fuelpressure_pwm.u01
    These fields get logged:
    Engine speed
    Accelerator position
    Fuel pressure
    Fuel pump: activation
    Fuel pump: actual fuel pressure
    Fuel regulating valve: duty cycle
    Fuel supply system: high-pressure regulator
    Lambda probes actual: bank1
    Lambda probes actual: bank2
    you may also want to bring it to 7,300rpm, that's were fuel can get iffy. Your rail pressures seems to peak at 6,000rpm, and then drop slightly when it should be rising.
    -Loe P.-
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by Jgm22 View Post
    I was told by tuner that was false advertising. Because if it was true. that would be one of the cheapest 20lbs of torque money could buy once past stage 1 haha!!
    S4 B8.5 no track, just enjoying spirited driving.
