Results 1 to 9 of 9
    Senior Member Two Rings jamezz23's Avatar
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    Car starting to start harder
    Hello I have a 2007 Audi and just a few days ago when I went to start it up, it had to crank about 10-15 times before it started. This morning it was a little more than that, but then after that I got the traction, abs, and blinking emergency brake like, car ran fine though. When I pulled into my driveway, I shut it off and restarted it and all the brake lights and traction lights were off and it started normally, I donít have any engine codes for this.
    I had this issue before but it was a little different , it was only when I put gas into it, it would take a more than normal cranks to start, and I had a gas cap not tightened warning. I forgot what I changed for that, but maybe itís the same thing and maybe itís the same. Just wondering if anyone has experienced the same thing
    Established Member Four Rings
    May 20 2017
    New Hampshire
    Fault codes buddy. Have you scanned the car?
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    Oof, sorry for the typos, I probably should have read it first. Wrote this out on a phone
    - - - Updated - - -
    I said I donít have any codes for this
    May 20 2017
    New Hampshire
    Did you scan it with VCDS or with a generic fault reader? Sometimes weird issues like EPC related faults can be stored in other modules like ABS. Worth a shot to check other modules besides engine.
    Iíd start investigating a possible MAF or throttle body issues if you have weird symptoms and no fault codes. Or maybe ECU related. Sorry I donít have a specific solution for you but at least it might get you started in the right direction.
    May 20 2017
    New Hampshire
    Any heavy rains lately? Water in the car? Water in the ECU box?
    May 20 2017
    New Hampshire
    Oh, any your hard to start issue after getting gas is almost always N80 valve related.
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    Yea, thatís the what I replaced, couldnít remember. Could it possibly be my issue again? Not quite the same symptoms but the hard start is what made me wonder.
    We havenít had hard rains at all recently, and what I used for a scanner was a simple cheap obd2 scanner
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2006 A4; 2007 Audi Q7 3.0 TDI
    Brandon, Suffolk, England
    Sounds like a crank position sensor to me. You might better fault codes with VCDS.
    Aug 20 2011
    Seattle Wa
    We had a similar issue with the car starting rough after filling up a full tank. Really weird. It just stopped doing it after a while.
    -James
    F T W L T B D W I C T W
    Instagram - jamesdrichey
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
