Results 1 to 4 of 4
    Mar 05 2012
    11 Q5 2.0T, 18 Q7 3.0T, 89 Foxbody!
    Bucks County, PA
    Resealing the 4.2 intake manifold...
    I have a B7 S4 with the 4.2. When I took the intake manifold apart to get the top part powdercoated, the rubber seal inside wasn't cooperating. I cleaned off the rubber and gasket material and used my own silicone gasket maker. I don't seem to have any vacuum leaks or anything, but I was wondering if I am the only one who has run into this? Is there a better method of assembly?
    2012 Q5 and 2018 Q7
    Aug 25 2010
    Try asking on AudiRevolution in the B7 S4 section. Theyll know for sure
    Veteran Member Three Rings pee quu's Avatar
    Jan 25 2009
    Oceanside, NY
    I just recently split and resealed a 4.2 mani on my 2002 s6 motor. I just took RTV and ran a thin line over that gasket and where there was rtc originally and It seemed to work fine.
    2000 B5 A4 / C5 S6 V8 swap / B5 S4 driveline swap / PVW Nov 2016
    Established Member Two Rings RHawk's Avatar
    Feb 23 2018
    '19 Subaru WRX
    Mundelein, il
    Anaerobic sealer.... leave the rtv to 1970's Chevy motors
    Sent from my HTC6535LVW using Audizine mobile app
